Question about Stoves 900DFa Dual Fuel (Electric and Gas) Kitchen Range
Stove ac53350ab oven gas won't come on
We have a Frigidaire electronic ignition range about a decade old. The stove works fine. But lately we've noticed if we're using any stove elements the oven won't ignite and heat up. Conve
Sounds like the pressure regulator on the stove is going bad. The pressure regulator is located in the back. Your gas supply line should connect directly to it.
Dec 23, 2012 | Kitchen Ranges
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
I melted some butter in the oven, it dripped into the burner holes and now they won't light.
i would let do this by specialist,to clean the burner.
butter can also ignite or you can get gas bubbles,not safe
Jul 26, 2012 | Stoves Ovens
My tappan oven won't work. stove and broiler work fine. ignighter glows but it seems like there is no gas.
I would check with your manufacturer and see if a professional can diagnose the regulator and even the gas valve itself.
Jul 17, 2012 | Tappan Ovens
Gas oven won't turn on, stove top works fine.
check if the igniter is getting a 110 volt power if yes replace the igniter
Sep 05, 2011 | Kitchen Ranges
My GE gas oven won't heat up. The stove top and broiler work fine but when I turn the oven on, nothing.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 03, 2011 | Microwave Ovens
I have a Maytag gas stove model MGR5730BDW. The oven won't light. The broiler works just fine. The bottom ingiter glows orange and gets hot but the burner won't light.
Hello, Thank You for using FixYa. I will be helping you today.Just because the ignitor glows does not mean its good..switch the two around and see if the oven comes on. They still glow even when they start to go bad.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
Hoping someone can point me in the right direction. Oven won't light, but the stove top burners are fine. Don't smell any gas or any indication the oven is attempting to light....
next time send the brand name and model number so i can look up your machine,if it's a gas stove most likely it will be a bad ignitor,even if the ignitor glows it still could be bad,if the flame doesn't ignite and the ignitor is glowing change it out,if it isn't glowing pull out the ignitor and check it with a meter,common problem.
May 07, 2011 | Ovens
Stoves 900DFa Dual Fuel (Electric and Gas) Kitchen Range Logo
16 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Ismael Rodriguez...
wayne murphy
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
