Question about KitchenAid P Series Trash Compactor - 15" - Black on Stainless Refrigerators
The door on my kitchenaid trash compactor is slightly crooked, digging into wooden cabinet cutout on left side. Any ideas on how to adjust door?
SOURCE: Trash Compactor Problem
Had a similar problem with mine. I took it apart and found that the nut that is on the bottom end of the ram screw was loose. I tightened it and it fixed the problem. That was about a month ago. Now it is doing it again. I'm going to tighten it again this weekend and apply Loc-tite to the threads.
To get to the nut, you have to lay the compactor on its side and remove the plate from the bottom. You'll see a chain that goes around the motor sprocket and both ram screws. You need to tighten the nuts on the ram screws.
Hope this helps.
Steve
Posted on Jan 17, 2008
tech master
  • 120 Answers
SOURCE: kitchenaid superba 42 side by sside water dispenser
usually when i get a kitchen side by side i trouble shoot the wtr valve first by using a cheat cord that applying volatge directly to the vlave to see if it opens but usually the wire harnes under frezeer breaks the wires so my money is on the wires under the frezerr door cut the sleve off and chec the wires one by one the one to the water is broken
Posted on Nov 03, 2008
SOURCE: KitchenAid KSBP25FKSS Side by Side Refrigerator Ice & water dispenser ondoor not working
I had the same problem and had to have the entire door replaced. I thought it was a random thing since sometimes it would just start working again, but finally it just stopped for good. The wires that
are below the door on the left hand side (you can see them better when the lower front piece is removed) were severed and they can't be put back together without replacing the door. My repair guy (the refrig. was still under warranty) told me it was a design or installation defect and that he has seen it time and again. Evidently, when they install the wiring, they don't leave enough room to stuff the wires out of the way of the closing door and eventually, it severs them over time.
Posted on Feb 02, 2009
aborcass
  • 2651 Answers
SOURCE: Find a replacement for Kitchenaid KEMS376S ~ tricky dimensions
your local dealer shouold have available to them all the manufacture specs and which unit would fit your needs.
Posted on Mar 09, 2009
espressonist
  • 1711 Answers
SOURCE: I have a kitchenaid superba
This problem happens very often and the solution is very easy. When it is at the down position there is a limit switch Directional switch Part Number: AP2984168 made by WHIRLPOOL , which becomes bad. So when the ram is down the switch supposed to give signal in order to return back. However since the switch is bad or out of its place the motor still working on until the overheat switch turn it off for protection.
So you need to disassemble and reach for the limit switch and check if it is in its place then it is bad and you must replace it. Try not using the compactor until then since this will damage the motor or something else and the damage will be more serious, now you have only the switch.
Here below we have a link with the part layout of your compactor and the above switch.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=263605&diagram_id=110326#d110326
Posted on Nov 01, 2010
I have a kitchenaide compactor. The ram is down and the door is open completely.
Sounds to me like you may need to turn off the breaker and hope it resets to the open position. or if you can see the plug you can unplug it.
Aug 24, 2014 | KitchenAid Architect S Series II...
I want to install a vinotemp Model: VT-TC32SB. Currently, there is a trash compactor in the space. If I pull the trash compactor out, can I just slide the fridge in place? The countertop and cabinets are...
Hi, It depends a little bit on how your trash compactor and cabinetry are currently set up. Some people have a tough time getting the trash compactor out/cooler in because of the lip that comes down off their counter. However, if you can pull one out, you "should" be able to just slide the other one in. Likewise, you'll need to be sure there is an electrical outlet available in the space. Usually, this isn't a problem as your new Vinotemp will plug right in where the trash compactor was plugged in. But in very old houses sometimes the trash compactor was wired right into the electrical. As long as your counter/cabinets were designed with enough room to move units in/out, this change should go smoothly for you. Best of luck!
Aug 30, 2011 | Refrigerators
I've got a GE trash compactor (GCG1580PSS). The door is stuck, presumably because the ram is stuck in the down position. If power is turned on, it will run until it shuts down (faint smell of...
Look up and down, may have an installation apparatus hooked into the counter top and the floor. Go to manualsonline.com to download owner's manual which should have installation information in it. Hope that helps..
Jul 19, 2011 | GE Profile GCG1580LSS 15" Built-In Trash...
Does 15" trash compactor need
If the current rating on the name plate is 15A or better, I would have it on it's own breaker
Dec 27, 2010 | KitchenAid P Series Trash Compactor -...
Trash Compactor Model GCG1500LOBB. the foot
I also found that after 2 years my GE Profile Trash Compactor (purchased in June '07), the pedal was hanging down on the left side. I searched the internet and called GE to no avail.
After a few attempts, I finally solved the problem by removing the screw on the left side and adding a metal "L" bracket, with the bottom of the L flush against the back of the front panel. That way, when you depress the pedal, the screw can't pop out of the metal it's attached to.
Dannys00
Dec 21, 2009 | GE Profile GCG1580LSS 15" Built-In Trash...
Trash Compactor will not start
key stays on but won't continue running, starts to run and then quite
Mar 13, 2009 | KitchenAid P Series Trash Compactor -...
GE Profile trash compactor is stuck
This has happened a couple times to me and the fix is fairly simple. The problem is the trash ram is pushing down on the edge of the metal of the trash compartment because the door is partially open. The solution is to back-up the ram the the door will close.
To back-up the ram, you will need to pull the compactor out from under your cabinets and unplug it. Turn the compactor on it's side to expose the bottom. There is a plate on the bottom that covers the motor gears. Remove the plate and turn the large gear counter-clockwise to back-up the ram screws (at least this is how it works on my model works). The gears are a little greasy so you may need to add some after messing with the gears.
Good luck.
Oct 21, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Trash Compactor Removal
I noticed that my compactor attached to the countertop above it at the front, but that it is also possible to do the same at the back. Can you get access under the cabinet at the back of the compactor and check it out?
Jul 13, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
KitchenAid  P Series  Trash Compactor - 15" - Black on Stainless Refrigerators Logo
105 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
