Question about Motorola Mobility Mbp16 Digital Audio Monitor With Lcd Display
Motorola baby monitor
Parent Units will no longer pair with the baby unit. I have followed directions, and still no success.
How can i reset baby monitor?
For Baby/Home/Pet Monitors, Cordless/Corded Phones, Digital Photo Frames
1-888-331-3383
Mon-Fri 7:00AM-7:00PM CST
(Baby/Home/Pet Monitor email)
Mark
Motorola Support
Sep 01, 2014 | Motorola Mobility MBP16 Digital Audio Baby...
Hello I have a Angelcare baby monitor model ac1100 and have had it 1& half years it hasn't put a foot wrong and all of a sudden the tv monitor side of it is not working properly! It stays a blue screen and...
If you can only see two lines appearing on the screen this may indicate that the parent unit is searching for a signal from its partner and cannot locate one. Check that the nursery unit has fresh batteries and is switched on. If all ok with the nursery unit you may need to "re-pair" the two units together as per instructions. Note that the maximum distance between the Parent Unit and the Nursery Unit is approx. 100 metres indoors. In reality the Signal Strength Indicator on the parent unit should show the strength of signal between the Parent Unit and Nursery Unit. The Out of Range Indicator should alarm when the two units have lost connection and the Out of Range Icon will be visible in the Parent Unit screen. However these units sometimes require a "re-pairing" exercise to get them to communicate with each other again. Ensure both units have fresh batteries.
HOW TO RECONNECT THE PARENT AND NURSERY UNIT
In the unlikely event that the connection between the Nursery Unit and the Parents Unit is completely lost, please follow these steps to restore the connection:
1. Turn both the Parents Unit and the Nursery Unit OFF
2. Turn the Nursery Unit ON
3. Press and release the left wing 4 times. The nightlight will fl ash.
4. Turn the Parent Unit ON. A blue screen will appear with the NO SIGNAL icon in the Parent Unit Settings Bar
5. While pressing the TALK BACK button on the right hand side of the Parent Unit, press and release the POWER button on the left hand side of the Parent Unit
6. If successful, the video capture will appear on the Parent Unit's screen again. The connection was successfully restored
Jan 18, 2014 | Baby Gear
Motorola baby monitor won't link
I would say try disconnecting the battery and waiting fifteen seconds, then reconnecting the battery.. If you can't disable the batteries...
I would recommend seeing if there is anything interfering with the wifi between the monitors.
Oct 22, 2012 | Motorola Mobility Mbp16 Digital Audio...
Tomy baby monitor srv 400 instruction
Page 1 SRV Series (Model SRV400) Q & A'sQ. My Parent and Baby (Camera) Unit have lost contact, what should I do?A. It may be possible that the encrypted code pairing both units has corrupted, to reset the code please
follow these instructions;
1. Place the Parent Unit next to the Baby Unit.
2. Activate both Parent and Baby Units by pressing their respective ON/OFF buttons for greater than
2 seconds.
3. Press the Mode/Enter Key to enter the Parent Unit's Main Menu screen.
4. Using the four-directional Navigation Keys, select the 'Add/Remove Baby Unit(s)' option and
press the Mode/ Enter Key to confirm your choice.
5. The current status shall now appear, showing all four Camera Units shaded grey;
6. To reconnect the Camera unit to the Parent Unit, using the Parent Units Navigation Keys ensure
the green circle is highlighting 'Camera 1'. Now press the Mode/Enter Key
7. Select the 'Add' icon with the plus symbol and press the Mode/Enter Key.
8. The screen will show the Parent Unit at the bottom transmitting a signal to Baby Unit
Jun 05, 2012 | Baby Care
The 2 units are not pairing, the parent unit just continues to flash, despite running through the re-pair process
there is a very important step missing from the previous instructions.
turn both the nursery and parent units off.
turn on the parent unit.
hold menu for 5 secs until it beeps.
turn on the nursery unit.
press the 'clear' button at the very top of the nursery unit that is part of the halo where it meets the white plastic of the unit.
the parent unit waits for the signal then pairs.
every other guide i've found misses out this critical part of the process for some reason and i was just about to give up until i saw a guide on the angelcare facebook page linking to youtube showing 'extra features' of the angelcare monitor.
Sep 05, 2011 | Angelcare Ac401 Single Baby Movement Sound...
My graco monitor has one red light and a row of green, instead of all green, and it is not making any sound anymore
Try pairing the parent and nursery units again. First, turn off all of the units. Place the broken parent unit within 5 feet of the nursery unit. Turn on the parent unit. Turn on the nursery unit. Within a few seconds, the top 4 green LEDs should shut off. Then you'll hear a few beeps and the connection LED should turn from red to green. If this doesn't work, power off and try again using the AC adapters instead of battery power. I did it without plugging in the parent unit but the battery died as soon as the units paired up again. It's working fine from the docking station though.
Dec 15, 2010 | Graco Imonitor Digital Baby Monitor
Hand held monitor not working
Sounds like the units need to be paired. Start with all units off. Then turn on one of the parent units. Press and hold the menu button until it beeps. Quickly turn on the nursery unit and press and hold the button on the nursery unit that has the parent unit icon below it. After a couple of seconds the units will pair. Repeat this process with the other parent unit.
Dec 12, 2009 | Angelcare Baby Care
Base unit appears to be working, but neither of the charged handsets will work. Both are showing red and beeping, but will occasionally go green for a second before going back to red and beeping.
The units aren't paired. Call Graco at 800-345-4109 to have them walk you through pairing it. I'll try to explain what they just walked me through:
-Turn off all units. Make sure nursery and 1st parent unit is plugged directly into wall.
-Hold negative volume down on 1st parent unit. Keep holding it down.
-Press on button on 1st parent unit and let go.
-When you hear a beep, let go of negative volume button on 1st parent unit and then press it again.
-When you hear the second beep, let go of the negative volume button.
-If you have done it correctly, the 1st parent unit should have one red light at the bottom and the rest of the lights should be green.
-Turn on nursery unit and the 1st parent unit should pair with it.
-Repeat the above with the 2nd parent unit.
Nov 18, 2009 | Graco Imonitor Digital Baby Monitor
Motorola Mobility Mbp16 Digital Audio Monitor With Lcd Display Logo
91 people viewed this question
Top Motorola Mobility Baby Gear Experts
Motorola Mobility
Motorola Mobility
John Gardner III
John Gardner III
Level 1 Expert
Are you a Motorola Mobility Baby Gear Expert? Answer questions, earn points and help others
