Question about ASUS MNTR ASUS| LCD 19' 5MS VW193D RT Monitor
Monitor out range
''out of range '' in games
Display says 'out of range'
Do you remember making any changes to the computer recently?
This seems to be a connection problem or the cable is gone bad.
I would suggest that you connect the monitor to another CPU unit if you have this is to check if the monitor itself is gone bad.
Also make sure that the connection to the monitor is correct.
Also try connecting another monitor to the computer and check.
This issue may also occur if the signal from the video adapter exceeds the scan range of the monitor. The video adapter setting for updating the screen (the refresh rate) is incompatible with the monitor.
Sep 21, 2012 | LG Computers & Internet
Frequency out of range
the monitors resolution range is only to 1280X740 or 780
and your video card may also need an upgrade.
The game may require a higher resolution that is not compatible with the the devices mentioned.
Jul 08, 2010 | E-Machines eMachines Monitor E15T4
Out of Range
i have the same problem
Jun 09, 2009 | BenQ FP731 17" LCD Monitor
View sonic -E70fB monitor displaying H.V frequency out of range when ever i play a game on the monitor screen it is displaying h.v frequency out of range....how to solve this problem
view sonic -E70fB monitor displaying H.V frequency out of range
Jun 06, 2009 | ViewSonic G70F 17'' Monitor + Wyse Winterm...
Frequncy problem/out of range
Adjust your screen settings that are usually found in the front of most pc"s and on the side of most LCD monitors
May 20, 2009 | ViewSonic Graphic VG2021m LCD Monitor
Monitor out of range when a game is booted up
The maximum resolution for the MV540 is 1024X768 @60Hz refresh. The other monitor isn't giving you an error message because not all monitors have that feature, but both the monitors are unable to display whatever data the computer is sending. If the display is normal until you start the game, then the game itself is setting the resolution to something out of the monitors' range. You'd need to set the game up to play at a setting the monitors could handle. I've never played WoW so I have no idea if the game offers a way of selecting the resolution. The game may simply require more graphics capability than your monitor can provide. Most systems now are using 17 or 19-inch flat screens or CRT's, and they offer more resolution and refresh rate options.
Jul 29, 2008 | Compaq MV 540 15" CRT Monitor
Game comes on. You can hear it but you can't see it
Reinstall the game the resolution for the game maybe out of range for the monitor, this will set the resolution back to defualt. does the monitor say "out of range or out of frequency" when the screen goes blank? if so it is the monitor being incompatible with the current resolution setting. if you changed monitors recently this may be why. Otherwise it is not compatible with your existing graphics card
Jul 02, 2008 | Computers & Internet
Analog Out Of range (LG Flatron L1750T)
some games need high resolution. Monitor resolution not supporting for this game.
Powersaver mode showing when the main PCB of the monitor failed. check this link to get the service center info
http://www.lgservice.com/
Nov 21, 2007 | LG Flatron L1750S 17" LCD Monitor
Over Range
change the graphics card it may con't support the display
and install directx.
Nov 15, 2007 | Sceptre X7SV-Naga (Silver) 17 in. Flat...
Most commonly, this problem is caused by an incorrect refresh rate setting. LCD monitors typically DO NOT support refresh rates higher than 60hz - and this is no exception. Try running the game in "safe mode" if it has one. Adjusting the in-game video settings should solve the problem, just look for a screen refresh rate or any video-related setting with a number followed by "hz". Set it to 60, everything should be fine.
It could also be that at some point the game changes resolution (this frequently occurs if there is an in-game movie or cut-scene). In this case the resolution settings for the in-game movie might be at fault, check them if you can.
Sep 23, 2007 | Computers & Internet
ASUS MNTR ASUS| LCD 19' 5MS VW193D RT Monitor Logo
15 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
