How to set frost protection on a delonghi hvn2532b heater
2 Suggested Answers
SOURCE: set time on delonghi oil filled portable heaters and set start and finish times
It was very tough to find the actual manual online for your modle in English. However, you can call Delonghi customer support:
DeLonghi Customer Support: (800) 322-3848
Delonghi does have manuals for some models on their site. Take a look at this link, the model might be similar enough to yours to be able to get the information you need.
http://www.delonghiusa.com/search_results.cfm?sp_q=oil+filled+heater&sp_p=all&sp_f=ISO-8859-1&sp_w_control=1&sp_w=alike&sp_a=sp1003e79d&sp_c=5
Hope this was helpful.
have a great day!
Posted on Oct 29, 2008
What does the alarm symbol mean on Delonghi portable ac on pacan125hpec
The appliance has a self diagnosis system to identify a number of malfunctions. Error messages (!) are displayed on the appliance display. If (Lt) is written it means low temperature; the appliance is fitted with a frost protection device to avoid excessive formation of ice. The appliance starts up again automatically when the defrosting process is completed.If (Pf) is written it means probe failure; If this is displayed, contact your local authorized service center.If (HL) is written it mean high level; the internal tray is full and you should empty the internal safety tank, however if it pops so often, contact the service center.
Aug 21, 2016 | DeLonghi Heating & Cooling
How do I use the Delonghi trv0715 1500w Vento High speed convection heater
The owner's manual is available as a PDF here: http://www.delonghiusa.com/index.php?product&nid=107 .
Many recommend you plug the heater in and turn it on in a well-ventilated room (like a garage) for the few hours of use. If you are using the heater to warm a room, plug it in with the thermostat set to maximum and set the power selector to 3 until the room reaches the desired temperature. Then rotate the thermostat clockwise until you hear a click. You can set the power level to 1 or 2 to conserve energy while maintaining the current temperature settings.
If you are trying to avoid frozen pipes in an area, plug in the heater and set the power selector to 3 and thermostat to *.
Always remember to keep anything flammable away from the heater (loose drapes etc.) There is an overheating protection circuit built into the unit. To reset it, you need to call the DeLonghi service center.
I hope this helps.
Mar 05, 2011 | DeLonghi Heating & Cooling
I inherited this heater with no manual and am in need of some instructions on how to properly use it and how to set temperature etc.
Go to Delonghi web site http://www.delonghi.com/ select country you are in. Select Customer servivices and then Down load instruction manuals. Hope this helps.
Aug 09, 2010 | DeLonghi TRN1015T Solaris Oil-Filled...
Delonghi Dragon Two, oil filled rad trips the main elec fuse
If it is tripping the breaker in the panel, there is a direct short in the heater. Scrap it before it causes a fire. Seriusly
Oct 24, 2009 | DeLonghi 6707E Oil Filled Radiator Heater
Actual output on settings
MODEL DELONGHI TRD0820ER 2KW OIL FILLED RADIATOR
YOU HAVE THREE SETTINGS
1. 900 WATTS
2. 1.1 KW 1,000 WATTS WHICH IS ABOUT 1.096 WATT
3. 2.0 KW 2,000 WATTS
Nov 25, 2008 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Set time on delonghi oil filled portable heaters and set start and finish times
have a great day!
Oct 29, 2008 | DeLonghi 6707E Oil Filled Radiator Heater
Delonghi DR18T Timer Replacement
before you replace the timer, check and see if the timer has a battery in it. if it has, then change the battery. it will work fine.
Jan 25, 2008 | DeLonghi DR-18TG Oil Filled Radiator...
Frost, ice on coils DeLonghi DDE50E Dehumidifier
expected? of course! this is not ur solution try draining all the water to the sewerage if u cant try to pump it out with a vacuum cleaner (that can pump water) or a pump then turn on the Dehumidifier every time it frosts turn it off untill it defrosts or u can heat up the basement with a bellower and the Dehumidifier wont frost
Feb 05, 2006 | DeLonghi DDE50E Dehumidifier
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
