Where can the bios chip be found on a hp compaq nc6320 laptop.
  • 335 Answers
Hello Daniel,
I have included a link to an image of the mainboard for your laptop. It clearly shows (with arrows) where the bios chip is located.
http://bios-repair.co.uk/images/Laptops/HP/Notebook/NC6320-Mainboard.jpg
Hope this Helps!
Joe
Posted on Apr 27, 2013
SOURCE: can't reinstall xp pro on my hp compaq nc6320
Stephane, I ran into the same problem after wiping out my Compaq nc6320 and trying to install XP Pro. The fix is to disable SATA Native mode. To do this: Enter F10 Setup then System Configuration>Device Configurations>SATA Native Mode and disable it, save the changes and now you should be able to install XP Pro. Remember, when I did this the drive was blank, I don't know if that makes a difference or not. Best of luck! Bryan P.S. If you want to enable SATA native mode after you have installed XP Pro check out this link: http://forums1.itrc.hp.com/service/forums/questionanswer.do?threadId=1042050&admit=-682735245+1161793137260+28353475
Posted on Oct 25, 2006
mellomania
  • 121 Answers
SOURCE: HP Compaq nc6320 Boot Disk
in case you can get a non boot disk , u can install it by using a start up floppy disk for win9x
Posted on Nov 15, 2007
SOURCE: Describe your HP Compaq nc6320 PC Notebook Problem
i have a Compaq nc6320 when i plug in the power cord the electricity led doesn't want to turn on i have changed the cords and the adapters and i doesn't power on or even charge the battery, did any one have an idea what to do in this problem?
Posted on Apr 10, 2008
sparkyuiop
  • 91 Answers
SOURCE: HP Compaq nc6320 PC bios password
Ok, as long as the high security level has not been set in the bios then the following will work to reset / disable the bios password.
1. Remove the battery and mains adapter.
2. Remove the memory cover on the back of the laptop and remove the 2 keyboard screws.
3. Open the laptop and at the top of the keyboard you will see 4 sliding tabs. They are located between the 'Esc & F1 keys' 'F4 & F5 keys' 'F8 & F9 keys' and 'F12 & delete keys'. Slide these down and lift the keyboard up and pull forward slightly so as to disengauge the bottom lugs. Be carefull as there is a ribbon cable at the bottom that does not need to be tugged or removed.
4. You will now see at the bottom behind the keyboard a small battery connected to the motherboard. Gently pull the small white plug upwards untill it is removed from the board.
5. Wait 5 minutes and re-connect the small battery plug.
6. Re-install the keyboard and push back the clips. You do not need to replace the screws yet.
7. Apply the DC jack and power on - DO NOT INSTALL THE MAIN BATTERY.
8. Turn the laptop on while pressing f10 repeatedly but slowly - Do not hold it.
9. If high security is disabled you should now be in the setup screen, select 'Restore Defaults' and press F10 to save.
10. The password is now removed.
If this does not work then HP say that there is no other way to reset it. Im not sure about that, there probably is by some method of de-soldering the bios chip. However the above method worked for me so I hope it does for you. Please rate if you have any luck.
Sparkyuiop.
Posted on Dec 03, 2008
How to recover the bios/cmos password on my hp compaq nc6320 t5600 1.83ghz ?
To reset the BIOS password read the information from this link.
In case of your HP Compaq laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Oct 26, 2010 | HP Compaq nc6320 Notebook
CPU frequency nc6320 change when ac power in
Try to rebbot the computer then before entering winwdows, if you are using windows click F2 or F11 on some PCs to enter the BIOS Settings. On the BIOS SETTING you can see options. Click on the Set Bios Defaults then press YES then Escape.
Feb 02, 2010 | HP Compaq nc6320 Notebook
Crack bios password on compaq nc6320 - please
You can crack dell bios password with Windows Password Recovery Tool 3.o . Here is a good post to help you:
http://www.windowspasswordsrecovery.com/crack-dell-laptop-password.htm
Oct 09, 2009 | HP Compaq nc6320 Notebook
HPnc6320 Bios lockout.
download the manual from the internet, it will give you all that information.
Feb 14, 2009 | HP Compaq nc6320 Notebook
Try unplugging internal battery for a minute or two it worked for me.
Sep 01, 2008 | HP Compaq nc6320 Notebook
Big problem
to clear cosmos(reset bios) remove rtc battery for a few minutes then replace ;restoring bios to factory set.
battery looks like large digital watch battery.usually located(but not always) underneath keyboard.
Mar 18, 2008 | HP Compaq nc6320 Notebook
HP nc6320 hardrive problems
go to the bios pressing F10. Click on the configuration> and then disable the ( Sata Native Mode). THis should work. Try it.
Dec 22, 2007 | HP Compaq nc6320 Notebook
Nov 15, 2007 | HP Compaq nc6320 Notebook
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
