Question about Garden
MTD 3 hp edger spark plug - Garden
AUTODOC01
  • 216 Answers
SOURCE: Edger #125E stalls after 3-4 second of starting.
sounds as thou the carb plate gaskets are torn these are sandwiched on eithewr side of the carb and they let it pump/**** the fuel a rebuild kit will have theses new gaskets depending on how mech/ inclined you are you may just want to let a shop fix it $75?? thats what i charge
Posted on Aug 26, 2009
  • 7 Answers
SOURCE: troy-bilt gas edger trencher won't start. Spark
Remove spark plug and pour 5mls or one teaspoon of premixed gas in the engine. Depress trottle to full with choke on "run", pull starter about 10 to 12 times If it starts and run for a while and then shuts off your carb needs servicing. If not remove muffler and look for a spark arrestor screen. This could be plugged up with soot. If it is, replace and this would have been your problem. While the muffler is off slowly pull starter rope and examine the piston if gas and oil oozes backwards as the piston moves to the top then the piston and rings need replacing.
Posted on Nov 10, 2009
  • 6468 Answers
SOURCE: how do i change the oil to my mtd 3.5 hp gas edger?
the fastest way to change the oil is to tip it on its side and drain nit threw the dip stick hole run it out of gas first if possible
Posted on Apr 08, 2012
  • 6468 Answers
SOURCE: my mtd 3 hp edger wont start ,
does it have spark remove the plug hold nit near the head and pull the rope is there spark?
Posted on Apr 27, 2012
adrnlnrush19
  • 3 Answers
SOURCE: weedeater pe550 no spark at plug
Check the coil.
Posted on Sep 05, 2012
What spark plug is used in an unidentified trimmer/edger?
Ryobi 4-Cycle Spark Plug-AC00164A - The Home Depot
www.homedepot.com/p/...4...Spark-Plug.../203222932
The Home Depot
Rating: 4.3 - ‎3 reviews - ‎$4.97
6 days ago - Keep your engine running smoothly with the Ryobi 4-Cycle Spark Plug forTrimmers. ... Use the replacement spark plug with any of Ryobi 4-Cycle engines. ... Replaces champion RY4C and torch CMR7A.
2-Cycle OEM Spark Plug (RDJ8J) - Sears Outlet
www.searsoutlet.com/2-Cycle...Spark-Plug.../product_details.jsp?pid...
Shop for a 2-Cycle OEM Spark Plug (RDJ8J) (49M0311P953) at Sears Outlet today! We offer low prices and great service.
Nov 28, 2015 | Garden
What can be making my edger turn off right when it sounds as though its going to start?
A faulty on off switch can cause this.spark plug foulage.fuel blockage.loose spark lead.broken power feed to spark.hope this helps
Aug 14, 2014 | McLane 3.5 HP Gas Edger & Trimmer...
Spark gap mtd 173cc mower
Contact MTD if your manual doesn't cover this, or buy a shop manual.
May 21, 2014 | Mtd 19 In. 173 CC OHV 3-In-1
My mtd 3 hp edger wont start ,
Apr 26, 2012 | Garden
How do i change the oil to my mtd 3.5 hp gas edger?
Apr 07, 2012 | Mtd 25B-520D200 CA Gas Lawn Edger
My edger tipped over briefly, now the starter cord is hard to pull and it won't start.
Try removing the spark plug and squirting some carb cleaner or starting fluid in the cylinder. Pull the starter cord several times for the piston to drive out the oil. Clean the plug and replace it. Try to start as normal. If you have starting fluid squirt a shot in the air cleaner to help make it easier to start the first time.
Nov 25, 2011 | Mtd 25B-520D200 CA Gas Lawn Edger
How do I change the oil on my yard machine? I don't have my manual, and I have a side discharge, mulching walk behind mower. I looked on the mtd website, but this model/serial# isn't available. ...
with the mover tilted on side, clean the area around the shaft with putty-knife (unhitch spark plug first) and there will be a square hole that a 3/8 ratchet will fit in, turn counter clockwise to UN-thread and oil will come from this hole.
Apr 23, 2010 | Garden
What is the spark plug gap on a 4.5 HP 21" cut
With out the model # of engine or plug not 100% certian but 99% of those mower engines run a .8 or .9mm plug gap you will be preety safe setting it at that
Regards
Brad
Feb 05, 2010 | Mtd Products Yard Machines 158CC Tiller
Have MTD model 464b 6.5 hp chipper/shredder purchased 3-28-01. It hasn't been used for 5 or 6 years. Loaned to son-in-law only to find out it won't start. Is there anything other than spark plug, air and...
Hi, I'm almost sure that if it sat that long that your fuel has turned to varnish and you will have to clean out the whole fuel system including carburetor with a good solvent before you will get it to run. This is assuming that you have spark to the plug
Aug 25, 2009 | Mtd Heavy Machinery
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
