Question about Wilkerson Air Compressor Line Filter M0802bl00
Need head gasket ss5l5 rand - Wilkerson Air Compressor Line Filter M0802bl00
Ingersol rand 80 gal 5 hp manual
follow the link
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/SCD-877.pdf
Sep 07, 2014 | Ingersoll Rand SS5L5 Ir Electric...
I would like the head bolt torque specs, just to retorque after startup
to be honest I always just snugged them down. Very seldom used a torque wrench. You need to check these often due to the fact that between the cylinders is a weak place for the head gasket. If you do blow one get you some garlock or similar gasket material and make a gasket. will work better and last longer.
Nov 27, 2011 | Ingersoll Rand SS5L5 Ir Electric...
SS5LS slow bulding pressure
typically on a ss5L5 the head gasket has gone bad. Disconnect tubing and remove the 6 bolts on the head . gently tap the head and valve plate. Mark these pieces before dis assembly for assembly. If you pick up both pieces as one , turn them over you will probably see a piece of the gasket missing at the smallest point between the 2 cylinders this gasket needs to be replaced. You can purchase a head and valve plate gasket or make the one you need if handy with tools. I've done it both ways.
Aug 29, 2011 | Ingersoll Rand Type 30 Fully Packaged Ir...
My ssl5l compressor builds pressure real slow now. Rings or Valves? it did get a little warm while sandblasting lately....
Very rare to have problems with rings. Blow-by would produce high pulsating pressure in the crankcase causing oil to blow out the oil filler plug/ dipstick. If normal crank pressure, suspect problem with valves or gaskets. Remove air filter cover and check for air blowing out of intake or very hot head or air discharge tube. Leaking valves or blown gasket will cause low volume/ low pressure and hot discharge air. Remove the in-tank checkvalve and look for carbon deposits /debris build-up. If the checkvalve and the interior or discharge hose are coated with oil deposits /carbon, most likely problem is valve plate/ gaskets /head. Good luck with your repair.
May 03, 2011 | Ingersoll Rand SS5L5 Ir Electric...
Standing in front of the SS5L5 pump pulley, looking at it,should it turn CW or CCW?
Easy to tell what direction pump turns. Look at pump pulley and notice and fan shape of the spokes. The pulley blows air across the pump. Most pumps turn ccw, however verify by looking at fan. Good luck
Nov 11, 2010 | Ingersoll Rand SS5L5 Ir Electric...
I have an IR SS5L5. We have developed a leak at discharge tube
SOunds like your compression fittings have failed on the copper line. I recommend changing over to a stainless steel braided flexable line. Try www.mastertoolrepair.com they have the stainless hoses.
Jun 01, 2010 | Ingersoll Rand SS5L5 Ir Electric...
Need to know type of oil it takes
I recommend type 30 all season full synthetic. It can be purchased on line, at an IR distributor and most Graingers.
Apr 14, 2010 | Ingersoll Rand SS5L5 Ir Electric...
AIR LEAKS CONTINUOUSLY OUT THE CRANKCASE VENT WHEN COMPRESSOR IS NOT RUNNING.
Sounds like a bad reed valve which are a part of the head gasket for a compressor. You can order the head gasket through IR or Grainger. But you need to have a Tech look at it. have a good day!
Aug 13, 2009 | Ingersoll Rand - Rand Type - 30...
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
A #10AWG wire can be use and 40Amp breaker can be use also. Your 5hp/230V/1/60hz motor amp is 30A.
May 30, 2009 | Ingersoll Rand SS5L5 Ir Electric...
Wilkerson Air Compressor Line Filter M0802bl00 Logo
21 people viewed this question
Top Wilkerson Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Wilkerson Air Tool and Compressor Expert? Answer questions, earn points and help others
