Question about Behringer Nu1000dsp 1000w Power Amp With Dsp & Usb
Where is the fuse on behringer nu1000dsp?
Teh instrument stopped running. im looking for the fuse to check if burned. thanks for answer
2 Suggested Answers
  • 5603 Answers
SOURCE: I'm looking to run 5
You could use the Left inout of one of the stereo channels. You can pan it with the balance control as needed... HOWEVER remember these are LINE LEVEL signal levels into the stereo jacks... so if you are using instruments with low output you MIGHT have to use a preamp to go into these jacks. Try it... nothing ventured, nothing gained. Using a keyboard into these jacks would NOT be a problem.
Posted on Sep 02, 2011
110 volts 220 volts
if you lucky the fuse is burned....
in the back of the console thar a hiden fuse chack is it burnd
Dec 16, 2013 | Behringer Music
I have two Behringer Eurolive B415DSP speaker, one of them stopped working out of no where. To my best knowledge, the problem is that it doesn't turn on. I had the Fuse check already and thats not the...
This is alimentation fault of the amplifier inside the box. Dismount the amplifier block and take a look first if there are some burned pieces. If it seems all ok, better bring it to a electronics/ tv service center.
May 18, 2011 | Behringer Eurolive B415dsp 600w 15" PA...
Hey, I have a pair of CPL46 speakers, im looking at getting a behringer PMP6000 powered mixer to run them, just checking if this is a good idea, thanks
You can find the spec sheet for the speakers here. The Behringer is rated 600 watts RMS at 4 ohms, right at the high end of the recommended level for the speakers. So it looks like a good match.
Mar 21, 2011 | Audio Players & Recorders
I have an Behringer Xenyx 1222FX that won't power on but when switching on the phantom power light does illuminate. Checked all fuses and those are fine
The phantom power light wouldn't illuminate unless the unit was powered on. Possibly the main power indicator light is burned out.
Jan 11, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Behringer Vmx200 DJ Mixer ...does it have a fuse?...... I AM HAVING PROBLEMS WITH MY SOUND.....
Yes, it has a fuse, however, if anything lights up or works the fuse is OK. Most problems are with cables or improper configuration of the unit and associated equipment regarding types of cables and grounding. Read you manual regarding cabling.
All your equipment should be fed from teh same receptacle. Powering devices from opposite ends of the room outlets is a sure way to have problems.
Oct 10, 2010 | Behringer Vmx200 DJ Mixer 2 Channels with...
I have a Pmp5000 889406987784 Eurowpower PMP5000 1200-Watt 20-Channel Mixer and Speaker Output A has no output. What has happened?
Usual problem is the Channel A amplifier has burned and blown the switching transistors. Usually an internal board arc occurs and unless very skilled at board work of clearing the burned area and replacing the components you are better to replace the HCA2400 amplifier module... about $160
Sep 19, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Im looking for a curcuit diagram for the switchmode power supply in my Behringer PMP3000.
If the supply failed I can tell you which parts to replace... and if it failed there may be a failure in the power amp that caused it. You can contact be directely at fredy2 @ aol.com... put Behringer in the subject.
The supply when it fails takes out eleven components including two expensive IGBT transistors. If the rearmost amp fried, add at least four more components and a lot of work carving out burned board and wiring around the blown circuit traces.
May 30, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I have recently purchased a Behringer Eurolive 1800 sub, what outs or sends do I use on my mx3242x to the amp
You use the balanced MAIN outputs. They are XLR and you should run those on balanced lines to your AMP which should have EITHER XLR inputs or TRS balanced 1/4 inch jacks to receive them.
DO NOT use mono inputs on your amp... make sure they have balanced inputs.
Note, for SAFETY of your equipment, ALWAYS power any connected stuff from teh same receptacle or power distribution system.
Apr 03, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Im try'n to hook a ''Duel fex pro'' multiband sound enhancement processor model ex 220, to my berhinger xenyx 1222fx mixer?
Use four (4) TRS cables. Connect from the
AUX "send" (left and right) to the input of the effects unit with two of the cables. Use the other two cables to connect from teh effects out jacks to the AUX "returns" left and right.
Mar 23, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Behringer Nu1000dsp 1000w Power Amp With Dsp & Usb Logo
37 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
