Question about GE RanCenter Burner And Cap Wb16k10053
Teba burner caps
Where can I find burner caps for my teda gas hop
GAS OVEN WILL NOT GET HOT
see this instructions and fix it. God bless you
  1. eHow
  2. Home & Garden
  3. Home Appliances
  4. Other Home Appliances
  5. How to Troubleshoot a Gas Range Oven That Won't Heat
By Kefa Olang, eHow Contributor
Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
Other People Are Reading
Things You'll Need
  • Toothpick
  • Paperclip
Instructions
    • 1
      Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
    • 2
      Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
    • 3
      Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
    • 4
      Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
    • 5
      Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
Jul 18, 2013 | Ovens
Teba cooker manual
The oven is not heating up in my teba cooker, the fan is working but no heat? Any cluster. Everything elsi is working fine
Aug 22, 2010 | Microwave Ovens
Prpane back to ng. Changed top burner apertures. Is there anything else I should do for the gas supply
The range burner orfices need to be changed to the natural gas ones. I am assuming when you say "apertures" you are talking about the burner orfices. If so then you have already changed the range burner orfices. There is also a orfice that usually needs to be replaced for the oven burner and top broiler burner (if you have a top broiler). And then there is usally a pressure adjustment required on the appliance gas regulator. This is usually adjusted by simply removing the regulator cap and turning over the spring tension plug inside and then re-installing the plug and cap.
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Where can i get a manual for a built in teba fan oven. It has reset itself and the timer switches off after 2 minutes and I cannot reset to not use the timer so cannot cook anything in the oven.
Try pressing the stop/cancel button, this should clear the error, if this does not work unplug for 5 minutes and then plug back up , this should clear the display and the oven should work.
Nov 14, 2009 | Ovens
Kitchenaid gas stove left back burner won't light. hear clicking
I have one of the kitchenaide gas ranges and if the burner cap is not set on PERFECTLY straight, the gas doesn't flow properly and will not ignite. Try lifting and replacing the cap back down on the burner and see if this solves it.
Mar 05, 2009 | KitchenAid Kitchen Ranges
Top burners spark intermittently with burner valves shutoff
Remove the burner caps (where the gas and flame come out) and wash in warm soapy water, using a plastic toothbrush like brush to scrub thoroughly.
Also clean/scrub the burner bases and ignition knob on the top of the cooktop.
When you reassemble, make sure the burner caps are properly seated in the burner bases.
Jan 20, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Need to know part nos. of gas burners and blackcaps, PLEC36S9ECA
try to bring the small part wen the place the burner cup(black cap) in the store wat brand u have also use other brand but bring it to put it in actual.
Nov 28, 2008 | Frigidaire PLGC30S9EC Stainless Steel Gas...
Jenn-Air Gas stovetop
try to clean the burner and then try it.
Sep 21, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
GE Spectra XL 44 Self Cleaning
Ray, sometimes the burners get gunked up. Remove the cap and burner and see if the small orifice that is located by the spark electrode is clogged. Clean it out with a paper clip. Make sure the burner cap has good contact with the burner. Catriver..post back.
Dec 06, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas cook top
Most of the time when I come out for a service call with this problem, it is usually because the burner cap is not seated properly on the base. Look at the burner and make sure there are no uneven gaps. Most of the time you will have to rotate the burner cap till a notch or pin "seats" into place. Most burner caps just sit on the bases, and so they get knocked off or moved when the cooktop is cleaned or installed. Hope this helps!
Oct 30, 2006 | Miele 36 in. KM342 Gas Cooktop
GE RanCenter Burner And Cap Wb16k10053 Logo
29 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
