Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Adjustments No problem ... Just need to access engineering code. How do I get in to my TV?
    Genius:
  • 1,694 Answers
Order service manual,however, most techs go with "If it ain't
broke......................is there something specific you are trying to accomplish? Be happy to try to help.....................T.
Posted on Dec 26, 2007
Adjustments for picture size unavailable
Option 1 - reorder the remote online
Option 2 - test different universal remotes and codes. The easiest way is to use the smartphone universal remote apps. You may eventually find the right code for your television that allows you to access the menu and the feature you are looking for.
Good luck.
Dec 02, 2015 | Emerson Televison & Video
Zenith tv is blurry
There are two adjustments on your flyback. If there is not an access in the back of the set to turn the adjustments then you need to take the back off of the tv. One adjustment is for brightness and the other is your focus. Just slowy turn the adjustment right or left until the picture gets clearer and your done.
Mar 19, 2013 | RCA F27442 27" TV
1) I have a Sony KV-32FS13 that has a green tint in the picture. Does any oneknow how to access the service menu for this model? I tried other adjustments and I can't get rid of the annoying green...
Code 5 is "AKB error". AKB, or auto kine bias, is a cicuit that monitors the three color guns of the picture tube (red, green and blue) and tries to adjust them for proper color balance. If it can't, the picture is blanked (usually) and the timer/standby light blinks 5 times. When the color drives aren't balanced, you see a color tint in the picture like you're describing.
There might be a problem in the AKB circuit, or the picture tube may just be old enough that the AKB circuit has run out of adjustment range. If the tube is at fault, you should consider replacing the set. A new tube will cost nearly as much as a new 32-inch LCD TV, and you'll need to pay someone to install it and set it up. There are special tools required to perform the convergence which gets the color guns aligned with the face of the tube so they hit the right colors.
If you'd like to try tinkering with the service menu adjustments, this site explains how to access the menu and gives a list of settings.
Jan 02, 2011 | Sony KV-32FS13 TV
How do I adjust the screen to the TV - I've looked in the MENU options and can not adjust the height of the screen. In other words - I can not read the score ticker on the bottom of the screen
Your sanyo tv may have service mode adjustments. It can be taken according to the sevice code options, which can be get from service journals available in the market. no menu adustment is there to adjust the picure linearity, height , subbrightness control so on. All adjustments are coded and have critical measurements which can be adjusted through service mode with the help of remote control. The remote control should be orginal to access service mode. Duplicate may not work properly.
Oct 14, 2010 | Sanyo DS24425 24" TV
Onkyo TX-SR706 Setup Display Problem
For adjustments to receiver you can always run a component or composite cable to your plasma tv. After adjustments are made just return to HDMI input.
Feb 24, 2010 | Audio Players & Recorders
How do I access the menu without a remote?
You don't. A good "universal remote" available from Radio Shack (Phillips) for about $15 will provide access to all TV adjustments. Easy to program for all TV models, VCR's, DVD players, etc. About $35 + S&H for the Sharp remote replacement.
Nov 14, 2009 | Sharp 27J-S100 TV
Red horizontal curvy lines
You need to turn the voltage on the red tube down slightly, also you would need to adjust focus to compensate for the lower voltage to the red tube. On the left and right bottom side of speaker cover are two round covers, take them out and there are 2 1/4" hex screws take them out carefully take cover off, there is another service cover same hex screws remove. You will see the focus block on the right side, tubes are labled on block. 2 knobs for each tube. Make voltage adjustments while tv is on a black screen, then for focus, turn color all the way off in the menu, and adjust focus until it looks right in black and white. These adjustments should only be very small; if alot of adjustment is needed, you may have other issues.
May 29, 2009 | Sony KP-51WS500 51" Rear Projection...
Tilted picture on screen
Tilt correction under setup menu use up down buttons to adjust and center * button to save setting
Apr 13, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Rca 32v432t
You need the factory remote only for this model of set!
Contact the service rep for your set and order a new remote.
As for the service mode, most RCA sets require an external service interface.
In many models of sets, the results and commands are in HEX. You will need the service manuals, hardware interface, and instrumentation to do proper setups and adjustments.
As for accuracy of adjustments, from factory these sets were very accurate. If there are changes, this is due to failing parts, and not from adjustments going out. The setups are all uPC controled and are exact. The set should be serviced to make it work properly, and not adjusted to offset faults.
Jerry G.
Dec 23, 2007 | RCA 32V420T 32" TV
Night and indoor scenes are too dark
If the set is less then 2 years old it should still be under warranty. As I understand there is a 2 year warranty on this set. There is some adjustments to adjust on and inside this DLP TV set but they are not customer adjustments and should not be attempted without a service manual. They are on a service menu for the tech to access and adjust. My best suggestion would be to contact the manufacture from a contact number in the owners manual or from the store where you purchaced the set from or from a number I found for a main contact. Main support number 800-294-6400. Good Luck
Mar 20, 2007 | InFocus ScreenPlay 61" Rear Projection...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
24 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
