SOURCE: C707TU LAPTOP DEVICE DRIVER WIN XP BASED
I don't know if you are using a cd from HP whith the windows xp software on it, because I done something like that before and didn't work, you have to find a cd from hp with windows hp software intallation on it otherwise you will have problems, after the installation you can search for the update drivers from hp.com.
I AM NOT GETTING DEVICE DRIVERS FOR C707TU FOR WINDOWS XP OS. PL GIVE ME THE LINK FROM WHICH I CAN DOWNLOAD ALL THE DRIVERS LIKE AUDIO, DISPLAY, MODEM, LAN CARD, WIRELESS LAN ETC. ETC.
SOURCE: satellite a65 problem with atheros wireless driver after XP Pro SP2 installed
Perhaps what is required is to install the drivers separately and use those from the manufacturer, Toshiba. Incidentally, there are 18 versions of a Satellite A65, which one is yours pls? (Versions start from S1062...S1762).
Pls start here and select Portables, Satellite, and A65 + Version, then click on "Show Results" button.
Alternately, you may want to jumpstart and try this for the RTL8139 and/or this for the Atheros WiFi. Both are for Windows XP.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
SOURCE: Acer aspire 3690 ethernet driver
you don't have an exe or an install file...how can you make it work please answer me
I hope this helps.
If this Answer goes some way towards helping to resolve
your Query, Problem or Fault, please take the time to Rate it. Doing so helps
Solution Providers, like me, better understand the needs and the point of view
of Askers, like you, and guides us in exploring the best ways to provide the
most comprehensive, useful and high quality Responses and Solutions we can. If
you need further help, please do not hesitate to post another Question or add a
Comment to this Question.
Thanks for using FixYa.
