Question about Acer AL1916W 19" LCD Monitor
Acer AL1916W Beeping
Hello my viewsonic CRT recently died and I went to wal-mart to buy a Acer AL1916w 1st the input was screwed so I had to start in VGA mode now whenever I try to open a game like World of Warcraft or Cs my computer beeps until I close it internet works fine its only when I open a graphic intense game I guess I have a 6800 Nvidia GT with the newest drivers can anyone help me ? ps. beeping driving insane
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Acer Master
  • 848 Answers
Acer AL1916W Beeping? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
490781400200R ILPI 031 Acer 790691400610R Power Supply Backlight Inverter
Posted on Dec 11, 2014
Try setting to the native resolution of 1440 x 900.
Posted on Aug 16, 2007
SOURCE:
I have the acer AL 1916w monitor behind the monitor there are four holes available . i want to mount this monitor on the wall . so pls help how will i mount on wall by using this hole or any possibilities...
They are Metric screw M4 or M5 from HD or LOWE's,
When you buy a wall mounting kit, it should come with the monting screw, do some research to what kind of mounting kit you are going ti buy that will have the mounting pattern that fit your monitor or if it has variable pattern that will accomodate your monitor.
User manula and support; http://support.acer-euro.com/drivers/monitor/al1916w.html
Watch out for caps going bad in your monitor also.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 20, 2010 | Acer AL1916W 19" LCD Monitor
How do you hook up sound to the computer. I have
The ACER AL1916W does not have built-in speakers, you need to get powered speaker system for your PC.
This is the spec of the AL1916W: http://reviews.cnet.com/lcd-monitors/acer-al1916w-lcd-display/4507-3174_7-31652355.html?tag=mncolBtm;rnav
Mar 30, 2010 | Acer AL1916W 19" LCD Monitor
How do i remove input not supported from my screen before i put the screen in the garbage
You get the 'not supported' due to the video resoltion from your PC is higher than what the monitor can support.
AL1916W has 1440 x 900 Native Resolution
Nov 25, 2009 | Acer AL1916W 19" LCD Monitor
"Input Not Supported" after adjusting screen resolution
What resolution are you trying to run? The native resolution for your monitor is 1440 x 900, setting to that should fix your issue
Jul 13, 2009 | Acer AL1916W 19" LCD Monitor
Acer AL1916W monitor the screen is cracked in the middle.and I want to replace the screen thank you.
You may have to order that directly from acer. These crt for monitors are not interchangable.
Jul 01, 2009 | NEC MultiSync FE991SB 19" CRT Monitor
SCHEMATIC LCD MONITOR AL1916W FROM ACER
Schematics are in the Service manual here → https://www.mk-electronic.de/hersteller/PDFDokumente/Acer/Display%20Product(DP)/19/AL1916Wc.pdf
Oct 12, 2008 | Acer AL1916W 19" LCD Monitor
Sound
If your monitor have inbuilt speaker, then you need not to plug it, because the monitor cable will work for that. I have ViewSonic 19" with inbuilt speaker and its working without any extra cable or connection.
Thanks
Iqbal
Mar 23, 2008 | Acer AL1916W 19" LCD Monitor
Unable to use intex external TV tuner with acer 19''
Frontech external Miracle TV tuner not working with LCD(ACER 15") monitor. Error msg "input format not suppoting". But CRT monitor (samsung 14") is working with the same.
Pl give advice [email protected]
Jan 11, 2008 | Acer AL1916W 19" LCD Monitor
Input not supported when trying to play a game
the game will need to be set to the same screen resolution as your monitor or the best that suits, beccause of it being widescreen, so look in the graphic or video settings in the game, or change the resolution of your monitor to suit the games highest setting. This is done by right clicking on your desktop, down to properties and then the settings tab in the next window and then move the slider at the screen resolution box.
Apr 25, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
277 people viewed this question
Ekse
Alun Cox
