Dab 201 Woolworths troubleshooting
DAB/FM radio. I wanted to reset it to reprogram the channels. Pressed system reset and auto scan. Was scanning and locked up. Tried to stop the scan and now the screen shows 'gobbledegook' mix of strange characters. Can't get it to respond and not working at all. Turning it off and removing batteries no help. What should I do please?
SOURCE: new sony hifi system with dab radio model cmt-spz90db
Posted on Feb 10, 2008
  • 71 Answers
SOURCE: how to reboot hitachi dab radio
Sounds like what happened to my Sharp DAB receiver recently . - Swtch OFF completely from all power sources and proceed with the recommended RESET function.
Move set and/or aerial to be sure of a good strong signal before attempting a complete re-start and full AutoTune as per the instruction manual.
This operation certainly cured my problem although I never have found out what caused the failure in the first place!!!
Posted on Feb 29, 2008
welcomejee
  • 10594 Answers
SOURCE: I have lost instructions
Please download required Instruction Manual from HERE.
Posted on Feb 03, 2009
  • 53 Answers
SOURCE: No sound from Evoke-1 DAB radio.
I've seen a few (Pure & other brands) like this.No communications between the micro and the dab module . could be either thats at fault.. Doubt it would be an economic fix. sorry.
Posted on Nov 07, 2009
  • 60 Answers
SOURCE: Matsui matdr100 DAB Radio stopped working.
Hi, click on this link and look at page 8. This tells you how to reset your radio. Hope this resolves your problem.
http://www.partmaster.co.uk/company/partmaster/manuals/Matsui%20MATDR100.pdf
Posted on Dec 06, 2009
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
How do I set the fm volume to be the same as dab?
This depends on the Music System. Check the manual, check in settings and see if there is volume normalizer or try keeping the eualizer in defult, or reset the system.
Oct 04, 2014 | Car Audio & Video
Can not get DAB radio too work on my Vita audio but FM radio works fine
This may be because you live in an area where DAB reception is currently poor, but to check this, please use our postcode checker (see 'check your DAB coverage' panel on the right) to see which DAB stations you should be able to receive. If reception for your area appears to be good, then it may be down to local conditions or building materials. Buildings constructed from steel and reflective glass are not good for radios with internal aerials as they reflect and greatly reduce the strength of signal. In such a case an external aerial will greatly improve reception, but most importantly, if you are using the supplied telescopic aerial, you should ensure that it is properly fitted and fully extended upright.
Secondly, when our products are first powered up from new, they automatically scan the DAB network to see which services are available. During this process it is important that the radio is not touched and that the aerial has been correctly fitted and extended as instructed. If this has not been done then it is likely that not all stations will be detected and only the strong ones displayed. To correct this a new AutoScan/AutoTune or System Reset should be performed as instructed elsewhere in our Q&A's.
questions answers
Sep 04, 2014 | Audio Players & Recorders
Dab signal
I suggest you scout around the neighbours for a DAB you can borrow to test the signal in your usual place. Your own radio could be faulty.
One of my DAB radios worked fine on FM even though one day it just stopped working on DAB for no apparent reason. The board to repair it is priced not to sell...
Sep 17, 2017 | Audio Players & Recorders
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
Retune Panasonic SA-EN38DB DAB radio + ipod dock
Original manual found - note the Model No. is listed as SC-EN38DB i.e. complete system (main unit = SA-EN38DB; speakers = SB-EN38; remote control = N2QAYB000245):
"Press and hold (PLAY MODE) until 2DAB AUTO SCAN' appears. When a frequency is tuned by Auto scanning on this unit, the ensemble corresponding to the frequency is displayed for approximately 2 seconds"
Nov 17, 2009 | Panasonic Electronics - Others
Users manual copy of a Grundig satel.antenna positioner AP 201 ?
Do you still want it ?
I have copied it on pdf
tvsateq@gmail.com
Oct 08, 2009 | Grundig FR200 AM/FM/SW/DAB Radio
Deleting memory on Mikomi DRF350x Dab radio
To perform a system reset on a Mikomi DRF350X:
1) Turn on
2) Switch to FM using the 'DAB/FM' button
3) Disconnect power (e.g. unplug the PSU from the mains)
4) Push and hold 'Enter' whilst reconnecting the power
Mar 12, 2009 | Electronics - Others
Acoustic solutions pd2 dab radio
press and hold the dab/fm button for 2 seconds, then press enter, it should say system reset, then re scan by doing the auto scan button , job done .. kev
Dec 11, 2007 | Audio Players & Recorders
65 people viewed this question
 Grubhead
Grubhead
