Reset BPL Studioline 21
The TV automatically scans channels, and doesn't stop.
SOURCE: Sharp LC-52D62U HDTV won't tune-in channel 21.
I finally got Sharp to repair the TV. It was under warenty but they said if the problem wasn't with the TV they were going to charge me for the service call. I told them I wanted a new TV. They sent the tech instead of a new TV. He replaced the turner card and it worked!! Now I get all the channels as well as channel 21.
Posted on Mar 01, 2008
  • 400 Answers
SOURCE: I HAVE 21 INCH LG FLATRON TV CHANNELS CHANGE
It is possible that there is other equipment which uses a similar frequency, this can be a cordless phone or a gate remote or other device capable of transmitting frequency
Posted on Mar 09, 2009
dave1645
  • 834 Answers
SOURCE: No Channels found after scan for new channels
was it working before ?
Are you on cable ? run your scan in cable mode
Are you on an Antenna run your scan in air mode
Posted on Dec 04, 2009
SOURCE: i want the remote controller
hi chalapathi4a, i too having BPL FST21 model. When my dad purchase this TV he didn't get the remote control. Is this model having remote control? Please let me know. If this model comes with remote control then i will also try to get the remote control for my TV.
Posted on Nov 25, 2010
gopakumarg43
  • 74383 Answers
SOURCE: My Toshiba tv keeps jumping from channel to channel on it's own
Hello
Check whether any control buttons on the front panel of the TV is strucked or not. It is best to replace all microswitches of the front panel of your tv. You have to open your tV and detach the control panel printed circuit board, desolder out one microswitch among them for a sample, and go to buy a new one. Replace all the switches at the same time. It won't cost more. They are very cheap to buy. You can bought it from most of the electronic spare part selling shops at your town. OK.
Posted on Feb 04, 2012
Testimonial: "Hello Gopakumar Gopalan I checked the buttons on my tv and they all appear ok. I have found now that if I keep the 'P' button depressed on the tv and select a channel with the remote that it stop scanning so there must be something wrong with the tv panel buttons as you suggest"
Bpl tv fcr 21
Check and replace its main system memory IC. It is faulty.
May 12, 2013 | Televison & Video
Tv won't stop scanning
If the TV is scanning continuously, it may not be able to find any channels with a strong enough signal to select. You may need a better antenna connection
Dec 22, 2012 | Televison & Video
Scan doesn't work on Acer AL2671W
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Aug 16, 2017 | Acer AL2671W 26 in. LCD Television
Hannspree TV tuning from aerial problem.
do you mean if you hooked up the tv with the aerial antenna can not get any channel? ok if just a white raster only and doesn't scan or tuned even manually and auto search, the cause is bad tuner.
Sep 06, 2012 | Hannspree Televison & Video
I have a Toshiba 32a33 TV, I have tried to program channels into the TV but it doesn't work. I tried to do it both manually and using the automatic channel tuner but it doesn't work. What should I...
Either the tuner or the video IF stage circuit of your TV is faulty. Tuner has no repair, can be replaced as a unit. If the fault is with video IF stage, it can be repaired. But, both the work is skilled one. You must have through knowledge in electronics, and work experience to do this work.
Jul 21, 2012 | Televison & Video
Bought a 2nd hand N64 & don't know how to set it up on the tv as no instructions.
You now need to find a channel on your TV that ins't used for anything else (eg an old vhs player or non-digital tv) then whilst on that channel you need to go into your TV's menu, there is often a button both on the remote and TV itself for this. This is where you turn on your N64 if you haven't already. You then will need to go onto automatic tuning (or if you prefer, manual tuning, in the programme section (if you dont have a programme section, just srcoll through each section till you find automatic tuning) your TV should then start to search for channels, after a little while of searching it should find the N64's frequency it may be a terrible picture that is mostly fuzz you can either carry on the tuning to see if it'll find it better or just head straight to fine tuning (if you decied to keep going you can still fine tune for the best picture quality possible and also if the TV doesn't find it just follow the previous steps till it locates the N64 again) once fine tuned you will need to store this new channel and then you can go ahead and enjoy countless hours of fun on the worlds best gaming console. (If the automatic tuning doesn't find the N64 at all try manual tuning). If you have any other issue with the console itself just drop me an e-mail at garleet@hotmail.co.uk. Hope I was a help.
Jan 20, 2012 | Video Game Consoles & Games
I have Onida TV Model 21 inch , I accidentally enable the features of volume lock, hotel mode and channel lock and I cannot reset the same. Due to this, I cannot increase volume of telivision
MIGHT WORK IF YOU:
Turn off tv with remote, that is standby, then turn off tv with switch or unplug from wall. Wait a few minutes until led lights go off on tv. plug tv back in. try pushing vt on remote and power button on tv at same time.
If this doesn't work try contacting a local retailer, they always have a list of codes for their salesmen.
Jan 07, 2012 | Televison & Video
I have BPL 21 Studioline 1000W, problem is suddenly the picture is becoming a thin Horizontal line at center, sound is perfect, when i beat with hand behind the TV picture is back to normal state, picture...
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
The fault is the FAILURE OF THE SOLDER IN THE VERTICAL IC OF THE TV.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Jul 25, 2011 | Televison & Video
Hi, i have 14 "
As I see it, your problem has something to do with your remote. I bet you have pressed the "auto search" button of your remote that's why your TV keeps on searching channels automatically from channel 76 down. Here's what you've got to do:
1. Get your remote control
2. Turn on your TV.
3. Press the "auto search" button to stop your TV from automatically searching channels.
4. In case it works, I'd advise you to look for channels manually using the number buttons or the "previous" or "next" buttons.
5. If it doesn't work still, contact your technician or your service provider about it. They are of great help for you!
I hope it helps. Thanks a lot.
Jul 23, 2011 | Televison & Video
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
