M11132 Mfp inf - Office Equipment & Supplies
What is the error code e7-80 on a Sharp ar-m450u ?
E7-80 MFP-SCU PWB communication error
Cause
SCU PWB connector connection trouble.
SCU PWB - MFP PWB connection trouble.
SCU PWB mother board connection trouble.
SCU PWB trouble.
MFP PWB trouble.
Mother board trouble.
Check & Remedy
Check connection of the SCU PWB, the MFP PWB,
and the mother board.
Check the ground.
Replace the SCU PWB.
Replace the MFP PWB.
Replace the mother board.
Mar 10, 2015 | Sharp Office Equipment & Supplies
Computer cant detect the printer
Go to C:/windows/inf and look for files called oemXX.inf oemXX.pnf.
Open the .inf files one by one and look for the EPSON label in them and when you find one just delete the .inf and .pnf file equivalent. There might be more than one EPSON files in the inf library.
Then unplug the printer, restart the computer, and the add wizard should pop again when you replug the printer.
Hope this helps.
Jun 21, 2011 | Epson TMT70 TMT70 C31C637001 Printer
Whenever i used to insert chip drive with chip it is showing autorun.inf virus
How to remove autorun.inf in your flash drive or hard disk
Sometimes for virus or trojan horse you may difficulties opening your drives. Your autorun.inf is infected if you find any abnormal language when you right-click on a drive. This autorun.inf file is hidden and you will not see the file even though you select to show your all files from Folder Options.
1. Goto Start --> Run and type cmd then click OK.
2. If you want to remove the infected file from drive C: then type C: then press Enter.
3. Type "autorun.inf" and press Enter.
4. Type "del autorun.inf" then press Enter. The file is in the drive but not showing or you can't delete it now.
5. Now type "attrib autorun.inf -s -h -r" and press Enter.
6. Now delete the file by typing "del autorun.inf" and press Enter.
7. Restart the computer.
Good Luck!
Mar 02, 2011 | Computers & Internet
I have a Dell Vostro 400 and two video cards. Only one card will work and it is an Nvidia GeForce FX 5200.The other one is an ATI Radeon HD 2400 PRO. These are the specs from the two graphics cards:...
you cant join two different platform vga cards. simply because they have their own platform and have separate drivers, so they conflict each other thus causing one of them shut off or disable..
Jun 01, 2010 | XFX NVIDIA GeForce FX5200 Graphic Card
Logitech webcam p/n 861092-0020 file not found in INF
You can get logitech webcam drivers from
http://www.logitech.com/index.cfm/support_downloads/downloads/&cl=gb,en
the inf file must be for another camera or a windows version get the latest and correct driver from the page above -link
Mar 24, 2009 | Logitech Webcam
Unable to delete the autorun.inf
hi azhar here form Karachi it is very easy. do, the below steps
reboot ur PC in safe mode with command prompt
when u bring a dos screen just move to ur drive mostly virus stayed in d: drive got d: drive and type
d:dir/ah and press enter
if u see there any auto run.inf file there also should be another file like .exe file or .bat or any kind of unknown , file so for delete the auto run file type attrib -s -h -r autorun.inf and press enter
then type del autorun.inf and hit enter here u go u have done.
do the samr process in all drives because mostly autorun.inf file make copy in all drives
remember autorun inf is just a file which help the virus to run autometicly
Feb 12, 2009 | Microsoft Windows XP Professional With...
In device manager Network Adaptor has yellow exclamation mark. "Windows cannot load the driver required for this device." My HP Pavillion laptop is under guarantee - was purchased Feb.2008.
Completely remove the LAN adapter and disable "Plug 'n Play OS" in the BIOS, as follows:
1) Remove the card from Device Manager, under Network Adapter
2) Delete C:\WINDOWS\INF\DRVDATA.BIN
3) Delete C:\WINDOWS\INF\DRVIDX.BIN
4) Delete the following files. Not all of them may exist.
  • C:\WINDOWS\INF\NET82557.INF
  • C:\WINDPWS\INF\NET559A9X.INF
  • C:\WINDOWS\INF\NET5579X.INF
5) Shutdown and restart the PC, and enter BIOS setup.
6) Find the option for Plug and Play BIOS, and disable it.**
7) Restart Microsoft Windows* 95 and use the Intel® installation diskette to reinstall the adapter.
Dec 14, 2008 | Computers & Internet
Comp drives not opening
this is because of autorun.inf file.
so run the following command-
go to run > type cmd >then type
cd\
attrib -r -s -h autorun.inf
del autorun.inf
d:
del autorun.inf
just execute the same command for all of ur physcal drives
and finally shut down ur computer
then open ur comp,now u can open ur drives by double click.
Mar 01, 2008 | Computers & Internet
50 people viewed this question
jasbo
jasbo
