Question about JVC Audio Players & Recorders
Auto adjust JVC jl_a1 turntable with new belt but runs too fast. How to adjust?
  • Mark Giles Apr 28, 2013
    Looks to be no adjustment however problem resolved by bending up the lever for the 45/33 change mechanism to push the belt up higher and sit on the centre of the spindle at the 33 speed seetting. Ran at the correct speed at this point. Hope this helps others faced with the sme situation.
  • JVC Master
  • 5,348 Answers
You could have got the Belt in the wrong position. If correct try looking underneath the turntable for small presets. They might be hidden or covered up. If you can't see them you will have to take off the bottom and look on the PC board for them.
Posted on Apr 29, 2013
3 Suggested Answers
freetek
  • 5568 Answers
SOURCE: replace belt on a JVC L-A21 turntable auto return
Some years ago, I found only one supplier; now there are several:
Turntable drive belts
Posted on Nov 18, 2010
  • 3 Answers
SOURCE: JVC Turntable model AL A1 BKX , need to know how to adjust speed
I have just fixed this problem on my Aiwa PX3800 with improvisation.
The platter was rotating too slowly, I didn't know how much too slow only that the records sounded wrong.
I imagined the belt, motor and platter as a bicycle gear and so simply increased the gear... I achieved this by winding a thin strip of a electrical insulation tape around the motor head to increase it's radius (like changing up to a larger front cog on a bicycle gear).
I could then time the rotations and remove a layer or two of the tape accordingly until I have achieved a perfect 45rpm. 33 is still way out but I only listen to 45s!
Be sure to trim excess tape from the motor head with a craft knife/scalpel or it'll stick to the platter.
Poor man fix up.
Posted on Dec 23, 2011
My JVC turntable has no plug, just a 10-13v lead
Probably as long it produces DC. However you will have to adjust the speed. As the unit was set for a certain voltage which wouldn't change. It will either go fast or slow depending on what the original voltage was. The speed adjuster will either be two presets one for each speed that could be located under the turntable base (covered by a sticker) or on the power board of the deck. Or they might be on the motor itself.
Apr 26, 2014 | JVC AL A158BK Turntable
AL-A1 turntable won t turn
take the platter & belt back off, then check to see if the motor spins, if it does the belts the wrong size or put on wrong, if it doesn't spin then you better get your butter & jam out, to put on your toast.
Jan 19, 2014 | JVC Audio Players & Recorders
I have a JVC L-L1 turntable. The linear arm is quite sluggish and is actually making records skip. Any ideas other that replacing the motor?
I have this exact turntable. If the tone arm looks like it's not moving or not moving fast enough, it will make the record skip. It is NOT the turntable drive belt that is bad. It IS a 2nd belt that makes the tone arm assembly move. That belt is only about 1 3/4" diameter. I have yet to find one for mine. Turntable drive belts are readily available, but not this belt for some reason.
Jan 01, 2011 | JVC Audio Players & Recorders
JVC Turntable won't turn, motor works, can't remove platter
http://www.vinylengine.com/library/jvc/jl-a20.shtml
Looks like this is a belt drive model.
http://www.turntablebasics.com/belts/jvc.html
This site claims to provide installation instructions with belt purchase. Good Luck.
Jun 20, 2009 | JVC Audio Players & Recorders
Turntable spins too fast at both speeds
this is belt driven turntable....have you tried adjusting it via the pitch control or even getting another belt for that turntable....
Apr 12, 2009 | Audio Technica AT-LP2D Turntable
JVC L T11 turntable spins to fast jerry, rigged adapter
where can I get an 11V -13V DC adaptor to power JVC turntable AL-E300?
Feb 02, 2009 | JVC Audio Players & Recorders
Poor man fix up.
Dec 17, 2008 | JVC AL A158BK Turntable
Sony ps-lx250h belt-driven turntable runs too fast.
Is there an adjustment knob? if so use that! if not it will have to be adjusted from under the turntable!
this should fix ya!
Dec 12, 2008 | Sony PS-LX250 Turntable
103 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
