Question about Saeco Magic De Luxe Espresso Machine
Saeco Magic Deluxe flashing water light, & not draining
I inherited a saeco magic deluxe that does not drain water. That is, with the tank full, and machine powered on, the empty water tank warning light flashes and the green temp light comes on after about two minutes. When the steam/hot water knob is turned counter clockwise the pump powers on but nothing comes out. I have made sure water freely flows from the tank when the button underneath is depressed, and I have repeatedly re-seated the tank onto the machine while the pump is running by lifting the tank 1/2 inch and then letting it back down. When I do that a few tiny air bubbles come up, but thats about it. What should my next troubleshooting step be, and if it turns out to be a bad pump, where can I purchase one? Thank You!!
  • 29 Answers
The pump could be out or it could just need primed. Saeco sells a cheap hand pump that you insert into the receiver and force water into the system while the pump is pumping. This will often prime the pump and get things going. Call 1 800 933 7876 and tell one of the customer service reps you need a priming pump.
Posted on Aug 06, 2007
mirran
  • 515 Answers
SOURCE: help saeco deluxe sup 012
I have in Italian
Posted on Jul 13, 2008
  • 11 Answers
SOURCE: saeco magic de luxe espresso machine
Ok, so you can download a new user manual for your saeco coffee machine here http://www.coffeeshrine.com.au/user-manuals/
let me know if you have any specific question following this.
Posted on Nov 13, 2008
  • 6 Answers
SOURCE: Temperature control on Saeco magic deluxe
No it cannot. I am not sure why you would want the water hotter. It is designed to be at the perect temperature for passing through the brew group for coffee brewing, its kind of a simple science.
If your machine has been producing less hot coffee gradually, that marks an issue. Try descaling the boiler per the manufacturer's inscrutions even if the warning light isnt on. The other option is that the thermal fuse mounted to the boiler is bad and turns off the boiler prematurely, those cost about $15 and are simple to replace. Lastly, the boiler heating element may be 'burnt out' new boiler is $120+
Posted on Sep 04, 2009
  • 1089 Answers
SOURCE: Steady Brew Group Light: Old Saeco Magic deluxe
Open the door on the right. The brew unit is the thing with the handle that has the push on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Posted on Jan 10, 2010
  • 39 Answers
SOURCE: Water pump in Saeco Magic Deluxe
If you haven't cleaned the brew group, or decalcified the unit I would start there. This is something I do every 4 to 6 months (or anytime I notice the flow of coffee to start to slow down). This normally restores the flow to the original flow level. If you have already done these things you may want to give Saeco support a call and see what they suggest. They are extremely helpful, although very difficult to get on the phone as the phone system they use is horrible and hangs up after you hold more than a certain amount of time.
Posted on May 06, 2010
My Saceo magic deluxe has issues. no steam or hot water will come out just a loud noise and the water light keeps flashing red but the tank is full. Please help
Machine could be scaled up. clean the steam and coffee outlets then descale whole system.Other possible causes could be a faulty pressure pump.
Mar 25, 2012 | Saeco Magic De Luxe Espresso Machine
Panel won't light on Saeco Magic Delux
Sounds like a board issue. It was something that happened on the Saeco Magic Deluxe's enough to be noticed. The board is not available for magic deluxe's with oval buttons.
Parts for your magic deluxe
May 29, 2011 | Saeco Magic De Luxe Espresso Machine
How do you connect saeco magic deluxe directly to water source?
I have only seen one Saeco that you can use a direct water supply with, the Royal Coffee Bar. I have seen people use a fish tank level control to jery rig a water supply.
Dec 10, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Delexe water light flashing
The brew unit is blocked, check the shower screen under the red o-ring.
Dec 03, 2009 | Saeco Magic De Luxe Espresso Machine
What year is saeco Magic deluxe model.
They have being around since the early 1990's.
Mar 18, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Deluxe - Coffee Cold,Lights not working
The thermoblock (boiler) element is burnt out and must be replaced.
Feb 10, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco magic de luxe espresso machine
Nov 07, 2008 | Saeco Magic De Luxe Espresso Machine
Magic De Luxe Frother won't work!
means you do have the hot water button pushed and not just the steam function.
Follow this SAECO
Jun 03, 2008 | Saeco Magic De Luxe Espresso Machine
Filter in saeco magic delux
little magnet keeps that red light from coming on.
magnets probably gone bad, need to buy a new water tank. As far as i know saeco does not sell the magnets seperate.
could also be a blockage sending the machine into alarm.
May 08, 2008 | Saeco Magic De Luxe Espresso Machine
Magic Deluxe
Yes, The only thing the filter in the water tank if that is the filter you are talking about is just improve water taste quallity. If you are talking about the filter in the brew unit then no do not use it without the silver filter(s) in place.
Aug 11, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
848 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
