Question about Microwave Ovens
I have a spacemaker and everything went out on it....no light no time no anything.....is there a fuse to check or anything?
  • Microwave Ovens Master
  • 9,098 Answers
It's likely a blown fuse or TCO (aka thermal cutout / thermostat).
Yours should have a "mini-manual" (technical sheet) hidden either behind the grille or control panel. It's very helpful in locating and testing components.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on May 04, 2013
I have GE Spacemaker microwave JVM1740DM 1CC. It suddenly stopped heating up. Everything else works fine and there is no loud noise or anything.
hello, the problem is that a fuse has blow up, the is a large fuse inside a white box, or sometimes without the box, see it carefully and you see that it says something like 5000 volts or 8000 volts or 5 kva, you will see that is burned, by a new one and put it. I have done it several times. good work, dont need to go to the repairman.
Feb 28, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My ge profile spacemaker II microwave went dark, no lights of any kind and no sound or response when pressing any button. tried resetting the circuit breaker but no change
Did you check the internal fuse? Often when everything is dark the fuse that protects the microwave is blown. Take the old fuse to your local hardware store and they will have a replacement for you. Should cost less than $5.
Nov 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Everything on our microwave still works( Clock,lights, fan) except it will no longer heat anything you put in it
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Oct 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Our oven would not heat,everything appeared normal lights worked fan worked timer worked tried again on cook 3 closed door and lights went out and we have nothing,I have 120 volts at plug.
Check the voltage at the primary winding of the highvoltage transformer. If it is 120 volt.then controll board part is. Now check the magnetron and related components. If the fuse and the diode are ok replace the magnetron
Jul 14, 2009 | GE Spacemaker JVM1740 Microwave Oven
Everything quit working no power anywhere
Have you checked the fuse in the plug? Also there is an internal fuse that you have to remove the outer casing to get at. Please make sure the power is off and the plug is removed from wall socket before you start and do not power up until the casing is back on. Hope this helps.
May 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave not heating lights and keypad functional
You may have a fuse blown on the micro/ the vent and lights are a diffrent cercut , Try replaceing the fuse. its on the in side of the unit. if you need further assitance and you think you can do this I will be happy to instruct U DFD
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker runs but wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Jan 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge Spacemaker microwave jvm240 wv Micro hood combo.
sounds to me like the magnatron has shorted out. i don't know of a way to test them unless you have some high dollar equipment. a continuity test prob wont tell you anything. what reading did you get on the cap when you tested it?
Jan 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL Microwave Oven MODEL JVM1640 Help
please check control circuitand related circuit and wiring mains fuse and related circuit
Oct 04, 2007 | GE JVM1640 Microwave Oven
Microwave Ovens Logo
19 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
