Question about Toshiba 42H81 42" Rear Projection Television
Toshiba 42H81 Red Vertical bar on right side
TV setis about 5 ys old, never had a problem with it. Turned it on one evening and after about 5 minutes the pictre kind of became blurry, almost looks like a 3-D picture without wearng 3-D glasses. Blueish-red with a red vertical bar to the right side. Tried touch focus but it came up as an error, not able to adjust. Any ieas what is wrong an how much it is going to cost to repair? Thank you.
  • mark stephens Aug 06, 2007
    how difficult is that for someone to do who has never worked on a tv before, but who is mechanically inclined?
  • 63 Answers
The symptom suggest a faulty converge ic.you need to replace that ic ( stk392-110 ).
Posted on Aug 06, 2007
SOURCE:
Fuzzy picture and vertical lines on right side, even after WARMING UP for 30 minutes.
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400
Oct 02, 2009 | Toshiba 42H81 42" Rear Projection...
How to center a screen?
Horizontal centering is performed in the service menu. Beware! You can mess up a lot of stuff in this menu.
Aug 02, 2009 | Toshiba Televison & Video
Vertical line on my 46" toshiba lcd tv
The only logical solution for the problems people are having for the toshiba regza's tv's is to get into a class action law suite..., they contiue to sell tv's with defective parts and refuse to help the customer that spent large cash to find out they last if your lucky 2.5 years, they are junk and anyone with one will soon find out./.......
Apr 03, 2009 | Toshiba Regza 46RV525U 46 in. LCD HDTV
Green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
Video input
Needs Hyper board repair = replace bad caps
PCB not available to buy outright........................T.
Nov 10, 2007 | Toshiba 42H81 42" Rear Projection...
42h81 RPTV
Rebuild hyper board = replace bad caps on board................T.
Nov 04, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 42H81 Rear projection "Convergence problem"
Also,check micro fuses F851,F852,etc.
and with a good digital meter, check resistors feeding B+ to
convergence circuit.
I have been using Stk392-110T made by Toshiba with no re-calls.Hitachi also has an upgrade IC.
And be sure to check your soldering of IC pins--good connect,
with no short.....T.
Aug 13, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 42H81 Blinking on and off light
Very common problems with this TV set. Toshiba even has a technical bulliten on this and several other models of tV set. The negitve terminal of C809 and C810 need to be soldered, as there are no eyeletes in the printed circuit board. This problem could also take out the fuse, F860. Replace if necassary. Good Luck
Mar 31, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
114 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
