Question about Dryers
Omega ceiling fan
How to change light bulb in fan
Crossedwires
  • 44 Answers
SOURCE: How to Change light bulb (yes, really...)
If yours is the same as the model 04890 that I looked up on the net, you will unscrew the center nut of the light fixture being carefull to not let the fixture drop to the floor. Once you have the center piece off you will be able to unscrew the bulbs and install new ones. Be carefull and be sure power is off before you do this.
Posted on Feb 09, 2008
SOURCE: hampton bay ceiling fan , model # 55295
I had the exact same problem. To solve it, I had a friend hold the area of the fan that the globe screws into. I wore rubber dish gloves to get a good grip and pushed up slightly on the globe as I turned counter-clockwise. My friend held the other part and turned clockwise a little as well. It took a lot of pressure for it to finally come loose and then we just turned it about another 90 degrees and the globe slips right out of the groove.
I couldn't believe how hard this was to do.
Posted on Feb 14, 2009
  • 7 Answers
SOURCE: changing light bulbs in Hampton Bay model AC 527 Ceiling fan
press up while turing it counter!
Posted on Mar 29, 2009
SOURCE: Minka aire ceiling fan
My Minka Aire remote is not working. When I use the remote nothing happens. When I turn on the switch using light switch nothing happens. I had it installed two years ago. Battery never replaced.
Posted on Jul 17, 2009
SOURCE: minka aire concept II ceiling fan bulb replacement
The glass dome is tightened firmly in the factory, so removal is difficult. When removal is attempted to, the metal housing to which the dome is attached will spin with it, making removal impossible. To see what I'm talking about, look in the small space between the dome and the bottom of the blade housing - it looks like a metal flange, but this is only the bottom of the reflective metal canister that holds the light. Note that there are 4 "dimples" around the circumference of this housing, facing inward. These dimples are what hold the glass dome in place. The trick is to use a rigid piece of wood or metal about the size of a 12" ruler and place the corner of that ruler in one of those dimples - FIRMLY. Then, a second person can get some leverage on the glass dome and "unscrew" it from the housing (counter-clockwise). The purpose of holding the ruler-sized material against the dimple is to keep the housing from spinning with the dome. This is easier said than done, but it will work.
Posted on Jan 23, 2011
How to fix ceiling fan light
Make sure the light wire is connected to the receiver & bottom of fan.You should set the light to the on position when using the remote and leave it that way.
Sep 10, 2015 | Hunter 52" Ceiling Fan With Light And...
Minks aire mojo ceiling fan light will not come on
Try changing the bulb. Make sure the bulb is touching the connector in the bulb socket.
Aug 15, 2014 | Minka Aire Ceiling Fan
Minka Aire Ceiling Fan light wont come on
Probably needs a new remote receiver.Contact Minka Aire @ 1-800-307-3267
Apr 30, 2013 | Minka Aire Ceiling Fan
52" Vaxcel Fresco II Oil Burnished Bronze Finish Ceiling Fan cant change downlight
why not, cant you figure out how to change a light bulb? Look carefully at the way it is made, look for screws to remove a plastic or glass cover to get access to the downlight ,which i assume is a light that points down.
worst case senario is you have to read the owners manual under how to change the light bulb
or call up customer service and ask them how or at least how to call techinical service.
In all fairness , a down light may not be a light bulb that points down , but some kind of compact flouresent light bulb.
check if vaxcel has a web site. they might have instructions on how to change a down light bulb.
Feb 23, 2013 | Hampton Bay 24002 Ceiling Fan
My hampton bay ceiling fan it a rounded light and I don't know how to get to the light bulb to change it?
ther are three small screws that need to be loosen, once these are loose, the globe will come off and you can now change the light bulbs
Oct 18, 2009 | Madison Avenue 04889 Hampton Bay Ceiling...
Como Fan MInka Aire light bulb burned out
remove the cover and unscrew the bulb. get a replacement especially designed for a ceiling fan.
Sep 07, 2009 | Minka F603-WH Ceiling Fan
Changing light bulb in ceiling fan
At the top of the pull chain there is a metal piece; this is threaded on a bolt. Unscrew the metal piece and lower the globe to expose the bulbs then remove and replace the bulb(s). I recommend flourescents as they are more economical, run cooler and last linger than incandescents (regular bulbs).
May 17, 2009 | Hampton Bay 24002 Ceiling Fan
Change light bulb
I have a fan just like that one to change a light bulb all you have to do is unscrew it from the fan itself and if that dosnt work then unscrew the plastic cover or unscrew a screw on the plastic cover
Dec 30, 2007 | Madison Avenue 04889 Hampton Bay Ceiling...
Dryers Logo
87 people viewed this question
Top Dryers Experts
