Nibo 888 how do you change the date setting for clock-in/clock-out on the NIBO 888D machine?
Date and time arror
When you turn your machine on for the first time, the display
prompts you to enter the current date and time. After entering,
it will not appear anymore.
NOTE: When turning on the machine after turning it off for a
long time, you need to reset date and time.
1 Press Menu until "Machine Setup" appears on the top line
of the display.
2 Press the scroll button ( or ) to display "Date & Time"
on the bottom line and press Enter.
3 Enter the correct time and date using the number keypad.
Month = 01 ~ 12
Day = 01 ~ 31
Year = requires four digits
Hour = 01 ~ 12 (12-hour mode)
00 ~ 23 (24-hour mode)
Minute = 00 ~ 59
NOTE: The date format may differ from country to country.
You can also use the scroll button ( or ) to move the
cursor under the digit you want to correct and enter a new
number.
4 To select "AM" or "PM" for 12-hour format, press the or
button or any number button.
When the cursor is not under the AM or PM indicator,
pressing the or button immediately moves the
cursor to the indicator.
You can change the clock mode to 24-hour format (e.g.
01:00 PM as 13:00). For details, see "Changing the Clock
Mode" on page 2.10.
5 Press Enter when the time and date on the display is
correct.
6 To return to Standby mode, press Stop/Clear.
Changing the Clock Mode
You can set your machine to display the current time using
either a 12-hour or 24-hour format.
of the display.
2 Press the scroll button ( or ) until you see "Clock Mode"
The clock mode currently set for the machine displays.
3 Press the scroll button ( or ) to select the other mode
and then press Enter to save the selection.
4 To return to Standby mode, press Stop/Clear.
May 14, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Clock wont set on Panasonic DMR-EZ48V
set time & date.try change memory ic or" repogram for reset the machine.
May 30, 2012 | Panasonic Televison & Video
How do set the time and date on machine
Press and hold CLOCK until the message window displays C, and the default day is announced.
To change the day setting, press MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
Press CLOCK. The current hour setting is announced. The correct day setting is saved.
To change the hour setting, press MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
To change the minute setting, press MEMO/REPEAT or ANNC/SKIP until the correct minute is announced.
Press CLOCK. The current year setting is announced. The correct minute setting is saved.
To change the year setting, press MEMO/REPEAT or ANNC/SKIP until the correct year is announced.
Press CLOCK. The new day, time and year are saved. The correct year setting is saved.
To check the clock, press CLOCK.
The above is from page 5 of the manual at
http://att.vtp-media.com/ecp/documents/product_Product/223/UserManual/944/1739_manual.pt2_i6.pdf
Jun 21, 2011 | AT&T ATT1739 Digital Answering Machine
Need to reset time ,day and date
Setting the Clock
You’ll need to set the clock so that it can
announce the day and time that each
message is received. Press Play/stop to exit
Setting the Clock at any time.
1 Press and hold Clock until the
Message Window displays C, and the
2 To change the day setting, hold down memo/repeat
or ANNC/Skip until the
correct day is announced. Then
release the button.
3 Press and release Clock. The current
4 To change the hour setting, hold down memo/repeat
correct hour is announced. Then
release the button.
5 Press and release Clock. The current
minutes setting is announced.
6 To change the minutes setting, hold
down memo/repeat or ANNC/skip until the
correct minutes setting is announced.
Then release the button.
7 Press and release C. The new day
and time are announced.
To check the clock, press and release
Clock.
NOTE: In the event of a power failure,
see the instructions on the bottom of the
unit to reset the clock.
Record a memo /
Repeat all or part of a message
I hope this helps! here is the URL to the information provided
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
Feb 09, 2009 | AT&T 1717 Digital Answering Machine
Need to change the date and time
message is received. Press "Play/Stop" to exit
1 Press and hold "Clock" until the
"Memo/Repeat" or "ANNC/SKIP" until the
release the button.
3 Press and release "Clock". The current
"Memo/Repeat"or "ANNC/SKIP" until the
release the button.
5 Press and release "CLOCK". The current
down "Memo/Repeat" or "ANNC/SKIP" until the
7 Press and release "CLOCK". The new day
"Clock".
Nov 26, 2008 | AT&T 1717 Digital Answering Machine
Cassette Stuck in Sony Hi-Fi RV-888d
Actually when audiotape struck (Click-Click-Click), rewind and forward 2-3 times or manually rewind and forward 2-3 times with the help of pen. After you can play the cassette
I am also use the same music system (MHC – RV 888D)
Mar 21, 2008 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Time and date
Here's the link where you can download the manual.
http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=162
I think it will be easier for you to read their directions than for me to try to explain this.
I hate to beg, but so many people don't rate solutions. We don't get paid for this we just like trying to help. If you found this information helpful I hope you'll take a moment to rate this solution.
Dec 30, 2007 | AT&T 1717 Digital Answering Machine
Time and date
Setting the Clock
message is received. Press P to exit
1 Press and hold C until the
or until the
release the button.
3 Press and release C. The current
or until the
release the button.
5 Press and release C. The current
down or until the
C.
Oct 04, 2007 | AT&T 1717 Digital Answering Machine
How do you set the clock/calendar on the Canon MP25DV?
on the bottom of your calculator is a reset button, with a paperclip or a pen press that button. Then, press the calendar, clock key. next, press the equal sign key until the date is flashing type in the date using 11172006. press the equal sign again and the date is set. Next press the calendar, clock key again the time should show up (12-00-00)press the equal sign again until the time starts to flash. enter in the time using 0903 (9:03) press the equal sign again. Time is set. to display the date and time when not using the calculator, press the calculator, clock key 2x's. to go to compute mode press the red CE/C button.
Nov 04, 2006 | Canon MP-25DV Calculator
87 people viewed this question
 Grubhead
Grubhead
