Question about Car Audio & Video
Pin diagram red,yellow,black wires to which pins
One Wire
  • 126 Answers
SOURCE: connex 3300 mic wiring
I opened up one of my Cobra HighGear mics and here is how it is wired:
1. shield (Bare copper wires) --- twist them good and tin with a little solder
2. audio (White)
3. transmit (tx) (Red)
4. receive (rx) (Black)
Blue and Yellow are unused.
Dean
Rollin CBs
Posted on Jan 28, 2008
  • 30 Answers
SOURCE: Chrysler Part No. P56038933AB Radio Wire Color code
1982 to 2001 wiring harness color code Chrysler.
12V constant pink or pink/white stripe
12V accessory red/white stripe
Antenna/Amp turn on white
12V Illumination black/yellow stripe
Left front + dark green
Left front - brown/red stripe
Right front + purple
Right front - blue/red stripe
Left rear + brown/blue stripe
Left rear - brown/yellow stripe
Right rear + blue/ orange stripe
Right rear - blue/white stripe
there is no ground wire in the harness, the metal braided strap is the ground.
use a ring terminal,speed clip, and screw to attach the ground wire from new radio
when replacing infinity radios and speakers, there are 4 wires instead of 2 at the speaker plug. the large gauge blue and black wires are the power supply for the amp, the other 2 are signal wires from the deck and will match up to the wire color codes above. simply cap off the power and ground and use the other 2 for speaker leads.
One thing i hate to see is someone who just hacks off the plugs behind the radio because they are too cheap/lazy/dumb to buy a wire harness adapter for the nice new aftermarket deck they just bought. ive seen everything from masking tape to house wire nuts used to connect wires, and they never last.
there is only 1 reliable permanent way to connect wires together - SOLDER AND SHRINK WRAP!!! whether you're connecting wiring for a radio, fog lights,repairing a cut wire, etc solder those wires, you'll be glad you did when you never have a problem with that circuit again.
This is a listing for part #'s for dash kits wire harness adapters
all part numbers are metra unless otherwise noted
dash kit 99-6700, 99-6701 and 99-6500 will work for most cars
wire harness adapter 70-1817
reverse harness( to replace factory plug that have been cut off) 71-1817
speaker adapter plugs 72-6510, non amped 72-6513 when equiped w infinity system and bypassing fact amps
no antenna adapters are required until you hit 2002 model year.
beginning in 2005 chrysler switched to a high speed LAN system in all its cars and trucks. there is no longer a switched ignition lead in the harness.
Good Luck
Leadispenser
Posted on Aug 27, 2008
  • 14 Answers
SOURCE: need wiring diagram
This is a general wiring diagram for most head units.
Should be what you're looking for.
Posted on Dec 17, 2008
  • 14 Answers
SOURCE: DEH-P80MP need wiring/color description
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/103539332INSTALLATION%20MANUAL%20DEH-P80MP.pdf
Installation guide for your model with wiring diagram.
Hope this helps.
Posted on Dec 25, 2008
SOURCE: need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Posted on Jan 07, 2009
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
pcbheaven.com/wikipages/How_PC_Fans_Work/
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT
www.informit.com > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
pinouts.ru/Power/atx_v2_pinout.shtml
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
Dec 16, 2015 | Cars & Trucks
2000 KIA SPORTAGE STEREO WIRING DIAGRAM
You can use the attached diagram for assistance, but here goes:
1. Blue/Yellow (Pin 1) - Illumination (+12V) (when headlights on)
2. Black/Yellow (Pin 1) - Main Power (+12V)
3. Light Green/Black (Pin 2) - Memory Power (+12v)
4. Black (Pin 11) - Ground
5. Blue/Red (Pin 9) - Left Front Spkr Return (-)
6. Green (Pin 19) - Left Front Spkr Signal (+)
7. Brown (Pin 10) - Right Front Spkr Return (-)
8. Light Green/Yellow (Pin 20) - Right Front Spkr Signal (+)
9. Blue/Orange (Pin 7) - Left Rear Spkr Return (-)
10. Green/Yellow (Pin 17) - Left Rear Spkr Signal (+)
11. Green/Red (Pin 8) - Right Rear Spkr Return (-)
(Note here that the wire color at the rear speaker is
Green/Blue - not sure if this is a misprint (see diagram))
12. Yellow (Pin 18) - Right Rear Spkr Signal (+)
Nov 10, 2013 | Vehicle Parts & Accessories
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
I need the wiring for the mic
Here is the wire diagram for several common mics in relation to a 4 pin CB. Most recent 4 pin CB's such as Midland, Cobra, Connex, Uniden, etc can use 4 pin mics. The wiring is actually depending on the mic rather than the CB so long as the CB's are 4 pin as well. Once you go back to late 80's the 4 pin design was a little different. Anything new it is simpler.
Stock Mic 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - 4 wire 1- Shield 2- White 3- Red 4- Black
static - 6 wire 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500 Cobra CA Series 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - 4 wire 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta 1- Shield 2- White 3- Brown 4- Green
Turner RK56 Road King 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Regards, Tony
Apr 07, 2011 | Connex Radio Communications
Need main wiring schematic for 2000 ultra classic speedo,speedo reset ,tacho, wiring wires got pulled out of plugs need help.thank you
Looking at the plugs on the meter side of the harness: for the speedometer there is a three position plug. Pin #1 is Orange, Pin #2 is White/Green and Pin #3 is Black. for the Tachometer there is a six position plug, Pin #1 is Orange, Pin #2 is Pink, Pin #3 is Black/Yellow, Pin #4 is Green/Red, Pin #5 is Yellow/Red, Pin #6 is Black
Jul 19, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
I need a wiring diagram for this stereo
FOR 16-PIN HARNESS
Pin Number Wire Color Function 1 White Left Front (+) 2 Green Left Rear (+) 3 Violet Right Rear (+) 4 Grey Right Front (+) 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front (-) 10 Green/Black Left Rear (-) 11 Violet/Black Right Rear (-) 12 Grey/Black Right Front (-) 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
FOR 9-PIN HARNESS
Pin Number Wire Color Function 1 Not Used Not Used 2 Black Ground 3 Grey Right Positive 4 Grey/Black Right Negative 5 Blue/White Amplifier Remote 6 Red 12 Volt Switched 7 Yellow 12 Volt Constant 8 White Left Positive 9 White/Black Left Negative
MAY THIS HELP YOU
Jul 04, 2009 | Sony CDX-GT210 CD Player
Wiring problem on Cobra HG-M75 CB Mic
Pin-1-Shield-Ground
2-Yellow-Audio
3-Red-TX
4-Black-RX
notes:The blue & white wire not used.
Jul 03, 2009 | Cobra HG-M75 Microphone
I need the wiring diagram of pump it has 5 pins coming out of pump
hello, i holding a wiring diagram central locking system,model 201,it have a 6 pin,
  • pin no.1 brown goes to ground
  • pin .no 2 black ignition on
  • pin no. 3 red permanent 12 volt
  • pin no. 1 yellow trunk lid switch
  • pin no. 2 blue driver door switch
  • pin no.3 green passenger door switch
hoping it"s help to solve your problem,ty
Apr 28, 2009 | Mercedes-Benz 190-Class Cars & Trucks
Fitting a towbar for a caravan with 13pin europlug
black socket, black 7 core wire
pin 1 yellow left indicator
pin 2 blue, rear fog light
pin 3 white earth
pin 4 green right indicator
pin 5 brown right side/tail light
pin 6 red brake lights
pin 7 black left side/tail light
Grey socket grey 7 core wiring
pin 1 yellow, reverse
pin 2 blue, supplementary feed (ignition)
pin 3 white, earth
pin 4 green live feed (battery +)
pin 5 brown not connected
pin 6 red supplementary feed (ignition)
Pin 7 black earth
On the discovery there is a purpose made plug behind the panel on the drivers side rear, behind the rear lamp
i think the relay you have bought is for lamp failure you just need a normal 4 pin 30 amp relay.
Good luck Davelee
Mar 19, 2009 | 1997 Land Rover Discovery
Car Audio & Video Logo
254 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
