Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
GE D52GW12 52 in. Rear Projection HDTV-Ready
I had the same problem with GE TV. Sparks, smoke.. I found a gray box (4x2x2) in the left rear of the computer board (facing the back of the tv) marked with a 4 digit number 3682 (I think). the top corner of the box was charred. Is this an expensive replacement. I didn't see any recall on the GE site for this TV but this is truely a major fire hazard.
  • 5 more comments
  • Rick-Ohio Nov 06, 2007
    Same issue exactly......actually caught the plastic on fire....
    With the back panel off, I tried to see if I could replace the part or if I have to replace the whole board. I was unable to figure out if the part can be replaced. (same 2x2x4) peice...
  • Anonymous Nov 26, 2007
    Mine gave a high pitched whine and then went black, accompanied by a sharp smell of smoke. Further attempts to turn it on returned the same whine and smell. I'm loathe to open it if it's still something they'll fix.
  • Anonymous Dec 24, 2007
    I have the same problem. It started to turn off after a few minutes, but if I tried again after a few minutes, it would turn on fine. Now it won't turn on at all and I can smell burnt electrical.
  • Rick-Ohio Jan 06, 2008
    For anyone trying to help.....the only part numbers I could find on the piece is 3C30-065...49656
    There is a cable coming from the front that allows for a screw adjustment of the screen and focus....
  • Anonymous Feb 10, 2008
    My set started turning itself off. It would then fade on and off. Now when I turn it back on, I hear a sizzling noise followed by a burning smell. The power light then fades off.
  • vtrogers Feb 23, 2008
    GE D52GW12 52 in. I have had this tv for just over 3 years and the exact same thing just happened to us this week. TV cut off and on, orange flashes reflected on the wall, zapping sound, burning smell. Beyond heartbroken as we love this tv! I will definitely check out the consumer recall site but does anyone know if this is fixable?
    Problem Solver:
  • 8 Answers
Please report these problems to the consumer product safety commision. I beleieve this common problem with large sparks and flames warrants a recall.
https://www.cpsc.gov/cgibin/incident.aspx
Posted on Feb 07, 2008
2 Suggested Answers
6ya staff
SOURCE:
early1234
earl norman llanera
  • 871 Answers
SOURCE: GE D52GW12 52 in. Rear Projection HDTV-Ready
hi
i agree with you about the fire hazard and i had many feedbacks about this tv, mostly conscious about fire hazard too.
i would suggest that in light of owning a high-def tv, it would be significantly appropriate to place this in a room with airconditioning as to diminish the heat this hdtv produces.
about the issue of the hdtv turning off, if you suspect the transformer and other parts to be the reason for the tv to malfunction, why not bring it to a certified service center which handles GE hdtv. i would say that it may be a pain but as to think of the outcome, it may be worth it.
hope this helps.
Posted on Jan 21, 2008
Need flyback for GE D52GW12
Tries Tv repair World.com,Ebay.com for the Flyback transformer.
Mar 06, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
TV would not power on at all now.
FIRE DANGER RECALL
http://www.fixya.com/support/r987312-call_number_recall_or_refund
Mar 14, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
hi
hope this helps.
Jan 21, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
I have a projection tv that has a module that sparks on the circuit board when it is turned on.
Most likely in the high tension module some wires are too close to the board - move the components apart and put some ceramic insulators. But in any case fix it quickly or you risk burning your house down.
Nov 12, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Sparks off part labeled gs 22
If you can post a pic of the component I can identify it for you and list where to get the part at.
Oct 26, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Sparks and burning plastic
Leave the back off and try to power the set on...be ready to pull the plug. Whatever is sparking/smoking is your bad part. On this TV I would suspect the flyback transformer or grey rectangular polyester capacitor mounted in front of a heatsink on the left.
Jul 06, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Actually my tv is a HDTV 1080 WS 73713
The DM is the metal box on the left side - It says DTV 1394 inputs on it - any thing else just let me know
May 28, 2008 | Mitsubishi WD-62725 62" Rear Projection...
GE D52GW12 52 in. Rear...
You need a new replacement flyback. They cost about 50 dollars at the following link , and they provide free tech support so you can do the repair yourself which takes about 30 minutes from start to finish and requires only basic soldering skills. Heres the link.
http://servicemanuals.vstore.ca/
May 16, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE rear projection HDTV
I Have the same problem with mine. when i go to turn it on the green lite comes on then blinks then shuts of. I was told that it was the bulb's so we open up the back to see. we tried to see if it would turn on, when we did one of the circuit board started to smoke!
so if any of you knows what model that circuit board is could you e-mail me at b[email protected]
Jan 20, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
381 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
