Question about Home
How do i remove shower drains - Home
  • 11 Answers
Normally they unscrew but if the are set in Mortar or have something else around them, that would need to be removed because that material, whatever it is, is binding the drain from unscrewing. Call, text or email Shane at 801.554.4142 / rsownbey@msn.com
Posted on Apr 27, 2013
How to remove hair/dirt from shower drain?
Buy a cheap pair of hemostats at your local hardware store. Get the long one.
Jul 07, 2014 | Home
Hair in a Jacuzzi Drain
take the drain plug out and remove the hair. Once you remove the hair from the drain your water will drain from the shower.
US Parts Center
Mar 09, 2014 | Jacuzzi - Bathtub - Alcove - Navona -...
Shower leak due to soft pan, bad support
The best way to repair is to completely remove the shower surround and pan. Build a better support and repair the drain then reinstall. Leaking water will ultimately ruin the actual floor of the camper.
Feb 23, 2014 | Forest River 2012 Rockwood Windjammer...
Clogged shower drain
Shower drains are all designed to be opened and cleaned, usually hair builds up, if there is a visible screw remove it and lift the drain cover, if you can get fingers under the cover try lifting it off to clean it. If its stiff and its made of plastic do not use metal tools to lift it. Instead pass a trouser belt under both sides and use this to pull it up, then clean it.
Dec 04, 2013 | Home
Shower not draining iflo waste
The domed drain plug has to be removed periodically, disassembled, cleaned, and reassembled. Be sure to disassemble it in order so you can reassemble it correctly.
While the drain plug is removed, apply drain cleaner in accordance with the directions
Nov 10, 2013 | iflo Home
One of the screws is stepped on the drain in my shower. How do I get the drain off to clean it?
they have a stripped screw removal tool in hardware stores or drill the head till you can remove the cover then using pliers remove the remaining scew shaft
Dec 09, 2012 | Home
Need to remove silicone from 4 part shower stall to repair & reinstall
I think you should contact to a professional who can remove this shower stall very easily without any risk. You can also have a look at shower enclosures for having such bathroom stuffs in affordable price.
Jul 14, 2012 | Home
My shower (fiberglass) drain is leaking and needs to be replaced. I can pop off the drain cover to reveal a pvc collar that is glued down and unmoveable. I have ripped the ceiling open underneath the...
There are a few different drain styles available. If you pop the drain cover off of the shower, does it look like a brass ring pressed up against a rubber boot? If this is the case, that brass ring will have to unscrew first. if this is not the case, There will be a large nut on the underside of your shower that holds the drain in place. Often times, a helper is very beneficial to hold the top part of the drain assembly in place while the other person unscrews the bottom portion. You may say a few choice words during the process, as sometimes an older drain becomes hard to unscrew. There is a special tool for removing the drain, and it is relatively inexpensive. If the pvc is glued into the drain, a section of pipe will have to be cut away to get the tool around the strainer nut. Plan on replacing the trap and strainer. If it is pvc, you will need a coupling, trap, plumbers putty to go around the strainer where it meets the base of the shower, a new strainer, and possibly a couple street 45's and a couple of 45's. Don't forget the glue, primer, and a short piece of pipe.
Nov 08, 2009 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
Home Logo
57 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
