Question about Bosch Kitchen Ranges
No heat Although the broiler works, when I set the oven temperature , it says preheat but never heats. The oven worked perfectly two days ago. We turned off the breaker and reset it, but still no heat. There is no heat in the convection mode either, although the fan works.
  • Anonymous Mar 16, 2014
    The broiler works fine, in self clean mode it works to a fashion probably because the broiler is coming on. after we ran self clean still no heat in the oven for baking or roasting.
  • Bosch Master
  • 3,287 Answers
The home's circuit breaker is not the problem if part of the stove / oven works. What is more likely to be the cause is a problem such as an "open" or "burned out" heating element or socket.
The control is "on" and sending power to the element. The control reports "Preheating" but since the heating element itself is no longer a complete circuit - it fails to heat. As mentioned above, it may be a problem with the socket that the heating element plugs into - but could be a problem with any wire between the control and the heating element.
I would suggest shuting off the circuit breaker for the stove / oven. Check to be sure it is off by turning on a heater that worked previously. If it stays off, you're ready to continue. Carefully inspect the heating element itself for damage. The surface of the heater should be uniform - smooth over the entire length. You may not be able yo view the back side of the heater - but you may be able to run your fingers gently over the surface to feel for damage. If damage is found on the surface, this would indicate that a new element is required. Once replaced, you should expect it to work again as new. If unable find damage, removal and inspection of both the oven's socket and heating element contact blades should be done. If found to be burned or damaged, replacement of the socket, heater or both may be needed.
Obtain replacement parts designed for you make and model stove / range. Contact an appliance repair service if unsure how to check / make these repairs.
I hope this helps & good luck!
Posted on Apr 27, 2013
Testimonial: "Thanks so much for taking the time to help us. We will take your advice and hopefully be able to get a handle on the problem. If all else fails, we'll call an appliance repair service."
3 Suggested Answers
SOURCE: Oven and broiler: no heat
Flipped the breaker switch! Although we had looked at the breaker first thing, and it was not flipped off, plus everything else on the range was working: we found out it is actually a double breaker, with one half controlling just the oven, and it can be just partially flipped and you don't notice it. So as soon as you toggle it off and on again, you are back in full power.
Posted on Apr 09, 2009
jyackle5
  • 8197 Answers
SOURCE: We have a Kenmore Elite
You will need to test the oven thermal fuse AP2126991 first and make sure it is good. If so, test and see if the clock assembly is sending power to the elements. If not, you will need to replace the clock assembly AP2127066. You can test this with a multi-meter AP3440648. Here is a link on how to use a multi-meter. Hope this helps. http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4810-how-check-continuity-ohmmeter.html
Posted on Jul 30, 2011
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Apr 04, 2014 | Frigidaire 30 in. Electric Gallery Series...
I have a Whirlpool Self Clean oven Model number:RBS305PDS17. I used the self clean feature and now my oven will not heat up. All the digital controls work such as preheat and temperature, however there is...
Error code E2F3 indicates oven overheating, i.e. sensor is not cutting off heat. Replace the sensor, about $75 online. If you have done this more than twice, or if oven is acting strangely (for instance, broiler comes on during "bake" preheat), replace control board OEM part #8302994, about $170.
Aug 16, 2010 | Whirlpool Ovens
When I set the temperature and press "Start" to preheat my oven, it doesn't get warm. I pulled the broiler drawer out and don"t see anything illuminating. My oven doesn't heat up. I don't know if this is...
If your electric oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 05, 2010 | Whirlpool SF357 Gas Kitchen Range
My oven has increased only 65 degrees in almost an hour....what does it mean when it heats up, but SLOWLEY??
The broiler element on the top of the oven comes on during the preheat cycle to speed things up and then only the lower element keeps the temperature steady. One of those elements is bad, probably the broiler. Try using the broiler and see if it works. If not, you need to disconnect the elements from the oven and check them with an ohm meter. If gthe elements check out ok, then it must be the temperature sensor/thermostat.
Jun 25, 2009 | Frigidaire FEB27S5A Electric Single Oven
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
Oven elements just stopped working
If I understand your use correctly, you were using the oven to heat the space? Or for baking?
Regardless, it sounds as though the elements have failed. If you used the oven for heating the space (with the door open) the broiler element comes on during preheat of the oven to get the oven to temperature more quickly. The elements are NOT designed to heat a space, and will quickly burn out if used in this manner.
Jan 23, 2009 | Ovens
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
My GE XL44 doesn't heat up to full temperature.
There are several things to check.
1) check the broil element
The broil element participates in the preheat and if the element isn't working it will take forever to reach temp.If the element is good 2)check the broil relay
If the relay does not activate when you press"broil" the control needs to be repaired.They are a few more things to check but you can start with the above.
We rebuild these controls.
Regards,
Howard http://www.appliancetimers.com
Apr 13, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven doesn't heat
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Mar 26, 2008 | Kitchen Ranges
Kitchen Ranges Logo
218 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
