Question about Worx Garden
How to untangle line under axle
Line stuck under axle and broekn off and cannot unwind it
2 Suggested Answers
  • 2976 Answers
SOURCE: clothing stuck under agitator, how
Most agitators will just pull straight up. If not, remove the top cap and remove the bolt inside.
Posted on May 07, 2011
Untangling a shimano sienna 1000
well the easy way is to CUT old line off then replace with new,but you can untangle line carefully and reuse it tho this takes a lot of time
Aug 27, 2014 | SHIMANO AMERICAN CORPORATION Sienna 1000...
How to untangle window cable in 2000 buick lesabre passenger front door?
I have never done your year Buick, but if it is a metal cable I did help a friend with a BMW that had that system. I have a 1992 LeSabre service manual and it tells you to replace the assembly (typical GM solution)
I the cable is tangled, and kinked, it will fail again even if you get it back together. Again if it is like the BMW, there is a spool that the motor drives. the cable comes to that spool from two directions and each end winds in the opposite direction. So when one cable is wrapping on the spool, the other cable is unwinding, when you reverse directions, the cable does the same.
Hope this helps, have you done an internet search?
Jun 11, 2014 | 2000 Buick LeSabre
4x4 high low gets stuck in neutral
this is a Part time 4wd system
and is not to be used on hard pavement.
not posting road surface makes answers, IMPOSSIBLE
its for ice, snow or dirt never pavement pure. ever.
or risk windup or worse
BTW 4wd means the front axles is locked too. (hub locks)
Suzuki even has a TSB showing how to unwind a kick or sammi.
amazing how this needs to be said but. here its,
ITS NOT AWD.
http://www.fixkick.com/part-time-test.html
Feb 14, 2014 | 1986 Suzuki Samurai
Tangles when trying to ball to work with
try to wind the new yarn on a paper towel roller and as you use it that will unwind easier.. you can put the roll on a horizontal mount that will allow it to feed out untangled..your monut could be attatched to say, an end table..it could be a short peice of broomhandle..
Feb 02, 2014 | Bernat Boa Yarn
Model: 21647 chain is stuck for light
When you say stuck I assume you mean it is stuck in the fan. You have to carefully unwind the fan to release the chain pulling slightly as you unwind.
If the switch itself is broken they are an easy fix from any home repair or electric supply house
Mar 11, 2012 | Hunter Caribbean Breeze 21647 Ceiling Fan
Right rear wheel stuck and and father and bf think the emergency brake line is stuck or possibly the shoe lining is stuck? any suggestions how to help?
If you can slightly jack up one or both rear wheels on level ground and put your arm just behind the rear wheel at the axle and you will feel and see several lines going to the back of the wheel.
One will be a thin steel tube ( hydralic line) NOT IT.
Another will be a flexible cable going into the plate behind the rear wheel
THATS IT !
You should be able to see the cables if you get on the ground under the rear bumper. The cables should run arcoss the axle to each wheel.
Grab it and pull back and forth real hard several times and it should release then do it to the other side. (Don't grab any electrical wires).
Make sure you have somebody with you when doing this. Hope this helps. James Booth. PLEASE RATE!!!! THANKS SO MUCH!!
May 20, 2011 | Chevrolet Aveo Cars & Trucks
Echo trimmer srm-230 pull string to start trimmer is stuck. I try pulling on it and it only comes out about an inch.
The pull string is probably tangled up. There are usually vents which enable you to see into the machines pull string assembly. Loosen the fasteners and pull off the cover exposing the pull string. You can unwind and untangle and then it should recoil perfectly. If that does not work continue to dismantle the pull string assembly because you probably have a broken starter pawl which is located on the back of the pull string assembly.
Aug 10, 2010 | Garden
My Van has no heat it is only letting cold air com out and the temperature to let you know the temperature in the van and outside does not work how can I fix it
check the heater control valve in the heater hose lines!! its probably stuck! or the vacumn hose that goes to it is broekn
Jan 13, 2010 | 2002 Dodge Caravan
How do i untangle the pull cord on my leaf blower, it is jammed inside (210MPH/450CFM Craftsman)
just tack the recoil off they are usually easy to remove do to the nature of the part then you should be able to unwind and untangle. in the future dont let go of the cord until it is wound back up that will elininate the back lash and tangling
Oct 31, 2009 | Craftsman 4 Cycle Blower/Vac
My passenger side seat belt on an 04 santa fe got twisted somewhere down where it enters the plastic, I cannot use the seat belt now, it is stuck. The dealership said the tensioner is bad and its $700 to...
dear friend your problem is not a major one as you can repair it yourself.remove the meganism from the vehicle, carefully dismantel unitbut try not to let spindel unwind.untangle belt and re-assemble.
Jul 17, 2009 | 2004 Hyundai Santa Fe
Garden Logo
57 people viewed this question
Top Worx Garden Experts
Tim Whalen
ray gallant
Wayne McNeil
Are you a Worx Garden Expert? Answer questions, earn points and help others
