Question about Jandy AQUALINK RS TELELINK KIT
Reset I have just replace my exerior Qqualink RS6 P&S board and reset interior/exterior boards (Jnady one touch) but it displays " Firmware R13" unable to reprogram. What;s next?
    Top Expert:
  • Jandy Master
  • 8,163 Answers
Make sure the backboard is for onetouch and not a PDA is so need to exchange
Posted on May 28, 2015
FILLS, DOES NOT WASH, THEN DRIES
GE GLDT690TBB Fully Integrated Dishwasher with 7 Wash Cycles Including SaniWash and SpeedWash, Nylon Racks, Stainless Steel Interior, Countdown Display and QuietPower 56 Quiet PackaBlack- Recent Questions, Troubleshooting & Support
Oct 07, 2015 | GE GLDT690TWW Fully Integrated Dishwasher...
Mastertemp 300 reads 128 r13 when breaker is turned on, then goes blank. any ideas? just replaced control board, transformer and ICM.
Do you have automation?
If so, Is it in Auto?
You still need to, Manually press the Pool or Spa ON button.
The 128, then the R13 are = Normal.
They are just confirmation of firmware numbers and the Revision of the software Logic.
Then if the Heater is NOT on, display will go blank.
May 14, 2015 | Pentair Mastertemp 300 Natural Gas Pool...
Aqualink rs6 loses date and time
if it loses time and date when turning off power needs new battery in aqualink 9 volt old style round nickel cadium on back of PCB board on new models
Apr 12, 2014 | Jandy Aqualink Rs4 One Touch Control...
Pc Er Error code
Jim, Pc Er is a Communication circuit failure on main board or
Communication circuit failure on control panel board
Could be a loose or corroded connection, a bad mother board or a bad display board. Before doing anything, unplug the refrigerator for 5 min and plug it back in. This may reset the motherboard. If not, check the comm cable at the display and the motherboard. if ok, then you will need to replace either the motherboard or the display board. There is no way of determining which one to replace.
Apr 10, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Reset
make sure red 4 pin plug is all the way plugged in and wires aren't touching
Apr 27, 2013 | Jandy AQUALINK RS TELELINK KIT
R13 code
controller temp sensor possible bad or control board on controller bad try using solar section for heat
Apr 01, 2013 | Pentair Mastertemp Heater
Kenmore Microwave Oven, Model#66568680891
you should change the touch panel and or the control module.check to make sure the power supplied is correct and all connections to the board are all secure.
Feb 24, 2010 | Microwave Ovens
I have a jandy rs6 pool control, and all the lights are lit on the indoor remote. The display screen says "6700 rev c" and nothing works on it.
I have the same system and have had this problem several times. You need to replace the board in the control panel of the indoor remote. The part number is PCB 6473-E. It will cost $400 - $600 if you buy it online and replace it yourself. You may be able to find just the board itself for $200 less.
Jan 09, 2010 | Jandy Pool & Spa
Auto shut down function not working (Jandy Aqualink RS6)
Jandy relays are known to stick. You can diagnose this yourself with a screwdriver. Remove the four screws on the outside panel. You will see a series of black rectangular relays and a lot of wires. Typically the pump relay is the one in the upper right. It will certainly be the one plugged into the left hand socket at the bottom of the circuit board.
Be sure to do all of this simply be looking. You can move the twisted red/black wires a bit to determine which relay is plugged into the first socket. Try to notice on the bottom of the relay a small black tab that is sticking out. When out, the relay is on. If the pump is running, this tab is out. If you then put the controller into service mode and the lights go out without the tab popping back in, you have a bad relay. If turning the pump off does not put the pump light out, you have a bad board.
In most cases, the relay is bad and it is a simple fix.
Nov 24, 2008 | Jandy AQUALINK RS TELELINK KIT
Jandy AQUALINK RS TELELINK KIT  Logo
89 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
