Question about Zebra TLP 2844-Z Thermal Label Printer
Can print from file but cannot from application
My TLP 2344-Z print perfectly from a file but when a try to print directly from my application the printer is blocked and a solid red light replace the green one immediately. From my application, if I print to a file and then send the file to the printer there is no problem. But when a use directly the OUTPUT TO PRINTER the problem appears. I have windows Vista.
  • 3 Answers
Check the DPI setting. With Zebra printers some print at a 203 DPI and others print at 300DPI. You will need to confirm what DPI level the printer supports and verify that the driver in the application is using the correct one. If you do the process to have the printer print its default config I believe it lists the DPI there
Posted on Nov 13, 2013
jigeo
  • 57 Answers
SOURCE: Solid red light after flashing firmware
These are the 3 things listed as being wrong for the status light being solid red:
1. Media is out. Reload a new supply. Press feed button to
continue.
2. Power-up failure. Switch power OFF then back ON.
3. Printer ready to receive flash programming during
firmware download.
There's a programming manual available for download on Zebra's website: https://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
It might help.
Posted on Apr 24, 2008
SOURCE: TLP 2844-z Flashing Red Light When I Try To Print
When the light flashes red, press the green button once. What happens then?
Posted on Oct 20, 2008
IrishDruid
  • 2712 Answers
SOURCE: Zebra Printer TLP 2844-Z - Will not print from application - prints SM 10 53 4D
Hold the feed button while turning on the printer. After a config label prints, turn the printer off and then on again, and try printing again.
Also, make sure the lid is closed far enough to engage the lid sensor. If the red light comes on again, press down a bit on the lid, hit the feed button and try to print again.
Posted on Oct 23, 2008
  • 124 Answers
SOURCE: Zebra TLP 2844-z green/red light flashing
Check their website. It should let you download the user's manual after you've logged in.
http://www.zebra.com/id/zebra/na/en/index/products/printers/desktop/tlp2844z.4.tabs.html
I work with these at my work-work, and the manuals are pretty handy to have!
Posted on Jun 15, 2009
  • 185 Answers
SOURCE: Zebra TLP 2844 Desktop Printer
The printer driver should be set to Continuous or it will think it is still Gap or Black Mark. Please adjust accordingly
Posted on Dec 20, 2009
Cannot print from my application
I am not able to detect bluetooth in Zebra rw420
Apr 27, 2013 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844 label gaps
you can try contacting zebra. im not familiar with that model.
Aug 25, 2017 | Zebra TLP 2844 Label Printer
Not printing from Smart Panel option
Because they can't talk directly to each other. Kind of like the scanner is speaking in German and the printer is Spanish....The application used for the scanner is bilingual, therefore the printer can understand what it is supposed to print.
Dec 22, 2009 | Epson Perfection 3170 Flatbed Scanner
When i print envelope the return address gets cut off
There are some parameters that must be correct before an envelope will print properly. The M/P tray on the KM-3035 should be configured for the proper envelope size, probably COMMERCIAL 10, (but could be another size...need to measure the envelope) and type should be set to ENVELOPE. When printing from the application,i.e. Word or Word Perfect, be sure to select the proper printer and configure the Print Set-up, print direction, size, etc...You will have these options by clicking file and then print from the application print menu.
Dec 07, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Hi, I am having Zebra TLP 2844 barcode printer.I have installed the printer in my machine. I have tried to take barcode labels.From application, for each and every label i need to generate the label in PDF...
The TLP2844 can print from any windows application providing the application can use a windows printer driver.
The page size oof the .pdf needs to be the same size as the physical label size.
Nov 03, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Labels not printing properly
El problema es que la impresora tiene diferentes parametros de impresion, de oscuridad o velocidad. Ajustalos para que sean iguales en el print server como en workstation. The problem is that the printer has different printing parameters, or speed or darkness. Adjust to be equal in the print server as workstation.
Jun 03, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Oct 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
44 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
