Question about Jandy AQUALINK RS TELELINK KIT
Reset I have installed a new exerior RS6P&S board and hit exterior/interior reset buttom, but interior one touch screen displays "Firmware RevB13" can not get memu to show to reprogram? What can I do?
    Top Expert:
  • Jandy Master
  • 4,262 Answers
Make sure red 4 pin plug is all the way plugged in and wires aren't touching
Posted on Jan 30, 2016
Charge complete
i had that same exact problem, with my razr so i just went out and bought a new battery for like 15 dollars, and now it works like a charm thanks........
May 02, 2013 | Cell Phones
Reset
make sure the backboard is for onetouch and not a PDA is so need to exchange
Apr 27, 2013 | Jandy AQUALINK RS TELELINK KIT
Dropped my Garmin 260 it functions but not able to get satelite reception. a screen keeps popping up that says GPS firmware updating 1% then 10 seconds later it jumps to GPS firmware complete and show the...
Try a master reset: After you know the batteries are fully charged!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on the nuvi 200,series device: Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
Nov 14, 2009 | Garmin nuvi 260W GPS Receiver
1997 buick park ave 4 door right front door handle won,t work from the outside
Order the exterior door handle AND the clip that attaches the rod to the exterior handle from your local dealership ( any part in the salvage yard will have at least as much wear as the one U are replacing ) Also order a can of touch up paint matching your car. After you have the parts and have painted the new exterior handle, roll down the window and remove the interior door panel. ( instructions have been posted at 'replace door lock buttom' ) Two nuts, one on each side, hold the broken handle in place and must be removed ( DON'T loose them ). Loosen the rod from the clip at the top to allow a bit more room, But take note on the way it is attached ( you will need to reattach the rod to new handle ) To install new mechanism put the new clip on the rod, carefully place the gasket and the new handle in place and install nuts to secure. Test the door handle and make sure it works. Reinstall interior door panel.
Jul 06, 2009 | 1997 Buick Park Avenue
Firmware screen
shorted wire to controller or plugs if all ok bad pcb board
Jun 12, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
How to reset my copy counter to my kyocera km-1500
Sorry you cannot reset your counter if you pass the 10,000 copies, if you are under you can, but just to let you know that you can reset the counter only for 1 time, you can do that by entering the maintenance mode of the machine and reset the counter.
hit 1087 twice it let you go to maintenance mode then start touch the screen up or down till you see the counter life reset, then hit start buttom, then highlight the buttom that come on the screen and hit start or reset and u will be fine.
to exit the maintenance mode hit reset buttom twice till you see 000 on the screen, then hit number 1 then start.
Best regards
Mar 01, 2009 | Kyocera Mita Office Equipment & Supplies
GE Profile does not run.
Just to be sure... check your owners manual to see if this unit has a "showroom switch". It's a little switch that turns off the compressor, etc. but lets everything else light up so the sales persono on the showroom floor can show it off. Some customers have hit the switch to "on" during cleaning by accident.
Sep 29, 2006 | GE Profile PSS26NGS Side by Side...
Jandy AQUALINK RS TELELINK KIT  Logo
48 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
