Question about Dewalt Audio Players & Recorders
How to use dado set
I was given a used six inch dado set , I. Not sure if its all there or how to set t up.
2 Suggested Answers
  • 5 Answers
SOURCE: Could I use a 8 Inch DADO 3/4 inch wide blades.
Yes, as long as you have a 10" craftsman skill saw.
Posted on Apr 17, 2011
How do I convert 14cm by 22.5cm into inches
2.54 cm equals 1 inch so this is about 5.51 inch by 8.85 inch.
If this is a screen size, note that sixe given is usually the diagonal.
Mar 02, 2015 | Televison & Video
Why engine over heating what to do to solve the problem
Clarify your question please. What king of engine and what's it in or are you talking about a 6 inch dado set or an Amana????????????????????
Jul 06, 2014 | Amana - AMA656030 - 6" Dado Sets
Cuts unevenly
This is probably because the offsetting tapered discs in the dado are not lined up to compliment each other and your dado is tipping more to one side than the other - if the blade was tipping to the left and right the same amount, both sides would cut to the same depth and the deepest part would be right in the middle. In an extreme case, if the blade tipped only to the right and not to the left, then the left side would cut the deepest and the bottom of the cut would curve up (shallower) to the right.
The same effect could be due to your arbor not being set exactly at 0 or 90 degrees. The angle indicator on the saw is usually not very accurate. Put a regular blade in, raise it up all of the way, then check for squareness between the table and the side of the blade (using a known good square). Adjust the tilt until you are good, then put the adjustable dado back in.
Sep 04, 2012 | Oldham 7005012 7 Inch Adjustable Dado...
I bought a craftsman dado blade set but can't find the instructions and I have no idea how to use it. Is it possible to get instructions
Dado blades are used in a variety of saw applications. Commonly tables saws. The manual for your table saw should identify if the saw is capable of using this blade-set Never used dado blades in a saw that is not intended for them as this can result in severe injury to yourself and or damge to the tool. If your are unsure if your saw can accomodate dado blade please post your make and model of saw and someone will try to help you.
Dec 29, 2010 | Craftsman Garden
How do I install a dado blade? Does the inside large collar need to come off?
Because of the larger hub assembly, the collar will need to be set aside. Be sure to use a dado insert in the table and get a carbide tipped tool if you can afford it. Make shallow cuts or the work piece will grab and be thrown off of the table. Always make a test cut on similar waste to make sure that it has been set correctly. Make or buy a push stick if you don't have one already. It also make copious amounts of waste! Have fun!
Nov 10, 2010 | Dewalt DW744X 10" Portable Table Saw
What kind of dado blade can I use on my craftsman 10 inch table saw model no. 137.248100/ with stand
You have a 5/8" diameter arbor. You can use any dado blade that will fit. That said here's a few things to bear in mind.
8" diameter dado stacks are pretty standard for 10" contractor table saws. A dado stack is typically about 13/16" wide at most. It makes sense that the wider your blade is, the more power it takes to cut through the wood.
If you were to use the full width capacity of your Dado stack (13/16") a 10" diameter stack would bog down. A 8" stack has a faster rotation at the cutting edge because of its smaller radius. So, you don't bog down when you're making a wider cut if you use a smaller diameter.
If your machine was really underpowered, you could go down to a 6" stack which would cut your power requirements even more, but limits the depth of cut.
If this post was helpful, please vote. Thanks.
Mar 28, 2010 | Craftsman 10" Table Saw
New dado set understand the shimms and chipper work
The shims are placed between the blades and chippers in a stack. they are used to make very small adjustments to the final dado width... So usually you set up your dado set for a specific width of cut according to your blade chart, then make a test cut... If you need to widen the cut very slightly, add some shims in between the blades as required to get a good fit on whatever material you are joining or putting into the dado etc.
Hope that makes sense!
Please rate this solution on FixYa!
Apr 12, 2009 | Delta 35 7670 8" Stacked Dado Set
Dado blade installation
Yes. normally an eight inch stack dado set is used on a 10 inch saw. You will also have to purchase or fabricate a special throat plate (non-metallic) to accomodate the extra thickness of the dado set.
The number of blades used, and therefore the thickness, varies depending upon the task at hand.
Make sure to use the factory supplied nut and washer to capture and tighten the dado set securely on the arbor.
Be very cautious in the use of dados. Do not raise the set higher than 1/4" or so until you are familiar with the use of a dado set. Try to avoid so-called "wobble" dado sets. They are IMHO more prone to dangerous kickbacks and harder to adjust than a stack dado set with dado shims.
Mar 21, 2009 | Delta TS200LS Shopmaster 10 Inch Portable...
I bought a Dado blade set dd208 and there are no instructions
I'm hesitant to even answer, not knowing your skill level. But understanding that you will probably have a use for an item you purchased, and use it one way or another, here's a primer...
Be careful! Never push your hand directly toward the rotating saw such that if the workpiece kicks back your momentum will carry your hand into the blade. Begin by raising the blade only a little above the table surface and run a pass with clean wood over it to get the feel of the resistance a stack of dado blades gives. Consider making a groove in two or more passes if you need to raise the blade more than 1/4" to cut it in a single pass. Use metal dado shims to adjust the precise width of cut. Tighten the stack in a balanced way, such that the carbide teeth are not in contact with one another. Stay away from wobble dado sets. Etc. Etc. Etc.
You may wish to have a look at this website, whose author has obviously given the subject considerable thought: http://www.newwoodworker.com/usngstkddados.html
Finally, be carefull. If you think a single saw blade can tear flesh, imagine what a 3/4" wide swath will do to your hand. Think about your setups. Use test pieces to get them right. Then pay attention while you run your dados. And try to avoid plunge cuts, especially on anything shorter than a couple of feet in length. When you can, use a miter jig in the slot to hold any work you have to pass cross-grain over the dado.
Be careful, feed smoothly, and hold your workpiece firmly against the fence while it passes over the blade.
Nov 29, 2008 | Saws
16 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
