Question about Home
Fire place help
Won't turn on
    Scholar:
  • 27 Answers
Yes you absolutely can! What you are looking at, where you're sticking the gas key into, is called a ball or Dante Valve. These gas valves have two sizes that the ball could be. They are either 3/8" or 1/4" in size on the end. I'm betting 10:1 the valve you have is a 1/4" because your gas key is spinning around and is for a 3/8" valve. If you go to this website http://www.cunninghamliving.com/fireplaceloglighterskeysandvalves_1.aspx and I would suggest buying the 8" or 12" long gas key you should be fine. The reason I suggest buying the 8" or 12" gas key is because you have stone on the face and the ball might be recessed in there quite a ways.The gas keys that Cunningham sells, or if you have an Ace Hardware or search for "Dante Gas Key", they will be what we sell called a "universal gas key". These universal gas keys will work on either a 3/8" or 1/4" ball valve.
Now, if after getting a universal gas key it is still spinning then you need to get a hold of a plumber. It could be that the ball valve is stripped and that is why it is spinning on the ball valve.
So try the cheaper less expensive fix first and you should be fine. If that still doesn't fix it then get a hold of a local plumber and tell him you might have a stripped gas ball valve and it might need to be replaced. Hope this helps you. Cunningham Living Website Your Home for Gas Grills Outdoor Kitchens Gas...
Posted on Jun 18, 2014
4 Suggested Answers
kencotx
  • 4 Answers
SOURCE: turns over won't fire
need more info :engine getting gas up in cylinders,this car known for bad fuel pumps
Posted on Feb 07, 2012
airjer995
  • 5332 Answers
SOURCE: 94 gmc sierra 4.3 v6 manual, won't turn over, can hear fuel pump start when accessories turned on..won't fire, girl who needs help
The first thing I would check is fuel pressure. This type of fuel injection requires a minimum fuel pressure in order to operate. If fuel pressure is as little as one psi below minimum the vehicle will not start. You can try squirting a couple of shots of carb spray into the air snorkel while somebody cranks the engine over. If the engine starts and then dies you now you fpdeffinetely have a fuel issue. If the engine still won't start check for spark. Let me know what you find. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Posted on Feb 08, 2012
candegood767
  • 4 Answers
SOURCE: 2000 nissan maxima won't fire
IF IT'S FLOOED BAD ,YOU CAN SMELL THE RAW FUEL, YOU MIGHT HAVE TO REMOVE THE SPAK PLUGS AND DRY,CLEAN THEM OUT THEM,OR IF SO REPLACE THEM ALL
Posted on Jan 23, 2013
I over heated,the serpentine belt snapped. Opened the hood to find steam rapidly coming out of both the antifreeze and out of the engine right by the head gasket. It wasn't smoke not blue or black jus
Perform a compression test on your cylinders. One unfortunate result of overheating is the blown head gasket. Without compression your motor will not run. Tester are not super expensive or some stores will lend tools.
Jul 09, 2013 | Cars & Trucks
Changed coil ignition module cap and rotor a week ago, now doing same thing again, it'll turn over all day long has fire but won't start like it has no fire.
are you getting FUEL ? are you sure ? you might need to replace both the air& fuel filters !!!!!!!!!!!!!!!! fuel pump may be bad !
Mar 08, 2013 | 2000 GMC Jimmy
Have a 2000 GMC Yukon Denali. Won't fire.
Make sure that the belt isn't extremely tight and they the belt tensioner isn't liked up by pulling in the belt. It should move and spring right back. Make sure engine isn't locked up. And please explain what happen with the vehicle. The fact that you replace plugs and wires and fuel filter for a car that's not turning is throwing me off. So right now we are going all over the place. But definite look at belt and tensioner I've seen a few times that a bad tensioner will make the belt wrap around tighter inhibiting the engine from turning.
Jun 26, 2012 | GMC Yukon Denali Cars & Trucks
94 volvo 960 wagon engine turns over but it won't
have you check for injector pulse? if no pulse or no ignition fire, most likely it is the ECM.
Jun 13, 2012 | Cars & Trucks
Feb 07, 2012 | GMC Sierra Cars & Trucks
My 1996 850 volvo wont start the engine turns over but wont crank
ok, turning over and cranking are the same thing, what your saying is it won't fire, so , 2 things make a motor fire, electric and fuel, so starting with the easiest remedy , remove the distributor cap, and inspect the rotor and connection points that are inside the cap, check for any debris built up , sometimes you can clean them good enough to get the car to fire up, if it does , normally you would replace them , ( not that expensive) remove the number one cylinder spark plug, and once out put the spark plug wire back on it, ( your going to need help with this step) with insulated pliers , hold the plug and place the bottom of the plug against a grounding point (any bolt on the motor will do,, but try and keep it away from the carb as its Hopefully going to spark) have someone try and turn the car over as if to start it, look for spark at the end of the plug, if you have spark,, replace the plug and try and start the car , if it won't,, move onto the fuel problem, you need to make sure that the car is getting fuel, remove the fuel line to the carb turn the key for a second, you should see fuel splashing out, if yes ,, you should be able to start the car , if no,, check the fuel filter first , then the fuel pump,
Jul 22, 2011 | Volvo 850 Cars & Trucks
1993 gmc 1500 350cid - engine turns over but will not start. Fuel is good
Hello and welcome to FixYa!
If it's not turning over then the problem will be on the firing. If there's no current to the plugs, the engine won't fire up. Few things to look at to resolve the issue... First, the ignition coil can be faulty. Second, The ignition switch can be faulty. Third will be the starter. If it's faulty, it won't kick the flywheel. One good reason why it won't turn over.
Hope this helps and thank you for using FixYa! Have a good one!
Apr 28, 2011 | 1991 GMC C1500
Truck wont crank. we have put new distributor cap, rotor button, coil pack, plugs, wires, and fuel pump. we also checked our firing order.
you said you repl dist cap that means you don't have a crank sensor you have electronic ing module. remove your elec ing module have it tested most auto parts stores could test your module, or check your coil at the neg terminal. should have power. if not you lost your primary volt from your batt.your secondary power is coming from your electronic ing module from the module to the pos terminal on the coil, when the eng cranks,from the coil to the dist cap , from the dist cap center to the rotor then out to the plugs,this all happen pervided the timing belt or timing chain is ok. the cumbustion chainber needs 3 things , thats fuel, air, and spark.
Apr 17, 2011 | 1996 Chevrolet K1500
Home Logo
115 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
