Question about Car Audio & Video
Will this amp run two 10" subs
I have Rockford fosgate 10" woffers and a friend gave me this Jensen amp will it run my tens?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
Need to know the wattage for the subs and amp
Posted on May 10, 2013
Shuttle83
  • 1139 Answers
SOURCE: Rockford Fosgate P2502
Hello tejano71, I would suggest that you check your grounding and if possible run an extra ground from the battery ground just to make sure. Then I would use an DC line voltage filter between the power supply and the AMPs. If this does not work. You may have an issue inside of the fosgate AMPs. To troublehoot these you will need a voltmeter (set to the AC setting), audio tone generator (multiple settings from 20Hz to 20 Khz), two dummy speaker loads (set to proper impedance and wattage), and an oscilloscope (to see if clipping is occuring). After you have these items, connect the dummy loads to the AMPs and then connect the ground wire to the AMPs, and connect the power supply to the Amplifiers. Put one of the oscilloscope leads across one of the dummy loads and the other oscilloscope lead across the other dummy load. at this point connect the Audio Frequency Generator and set it to 20Hz and increase it to 60Hz as you also increase volume at each frequency looking at the oscilloscope for any signs of clipping continue to increase as you get higher in frequency. You should see very little clipping. If clipping is seen the actual unit may have a voltage regulator problems. If the unit has voltage regulation problems, I would suggest that you take the unit to a repair shop for further investigation, I have repaired quite a few of these units and for the most part regulation on these items sometimes can go bad with very little warning. Let me know if this solves your problem, or at least points you in the right direction. Thank you, Shuttle83
Posted on Sep 05, 2007
SOURCE: Rockford Fosgate 800a2 To 2 SVC 2ohm subs
Ok.. Bridge the two sub into 4ohm than bridge to amp.
So. this how it goes.
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
Posted on May 29, 2008
  • 4 Answers
SOURCE: How much would installing a headunit, amp, and subs usually cost?
hows it going so you need it to be installed or you can install this yourself? well the best bet fund to get stuff done cheap is t get the stuf you will need to do an install like a install wiring kit and tools and post a installer help on craigslist.org iin your local area would be the cheapest way or just go to your local audio stereo shop thanks again and i hoope this help have any more questions please feel free to contact me if you need a step by step install i can help you in that and save you big bucks thanks again. always forward jcbproducts
Posted on Dec 03, 2008
etirbynnor
  • 655 Answers
SOURCE: Rockford fosgate 800 a2 amp power?
Hello desperate2le,
Watts delivered is a function of the voltage times the current. If the amp was 100 percent efficient, it would need 33 amps at 12V for 400 watts. At 14.4V, it would only need 28 amps. Of course, amplifiers are NOT 100 percent efficient, only about 50-60 percent in many cases, but somewhat higher for monoblocks, maybe 80-90 percent. So you're looking at a fuse in the 60-80A range. In the absense of a specific fuse size from the manufacturer, I'd start the primary fuse at a 60A and if the amp blows it on power up/immediately/frequently, move up to an 80A.
All of the Rockford-Fosgate 2-channel bridgeables I've ever seen show using the left positive (+) and the right negative (-) for bridging. But if it's not shown right on the amp, I'd call or email RF for the correct connection. The new amps do show it.
Hope this helps.
Posted on Apr 28, 2009
  • 10 Answers
SOURCE: how do I hook up one sub to my rockford fosgate p3001 amp
Hey i have looked over many rockford manuals,(i own a 300.1 my buddy owns a 325.1) and for there mono(.1) amps there hooked together on the inside so channel A+ and B + are cencted on the inside the amp. So you ither hook one 2ohm sub to channel A or you can hook 1 4ohm subs to channel A and 1 4ohm sub to channel B. There 2ohm stable so any lower will eventualy burn the amp out.
Posted on Jan 19, 2010
Bridging two12" subs and one 15" sub to my Rockford fosgate T 1500bd amp
assuming all 3 subs are 3-4 ohms, running all 3 in parallel (the 3 positive leads all attach to the amp positive terminal, and all 3 speaker negative leads connect to the amp negative terminal) will bring you at or above 1 ohm, which the amp is capable of handling. With 1500 watts, you will want to use 8 gague power leads for the amp, 12 gague speaker cables, and an inline 120 amp fuse between the amp and the battery, within 1 foot of the battery.
Jan 11, 2017 | Rockford Fosgate Car Audio & Video
What amp should I use?
Yes they information available on them they are still around. You will need a class-D 300 watt RMS amp to run them at perfect power if i remember right they are 150 watt RMS,, 450 watt max per sub.// just never mind the max it means nothing. They are a 4 ohm sub i believe so you would want to get a 1 ohm stable amp. two 4 ohm subs can be run at 1 ohm wired in series. they are actually made by audio vox corp.to wire them is easy ill give a link to do so easy to use. and handy. let me look for some info on your sub...? Yes there is info out there here is another link. Need additional help give a shout.
Rockford Fosgate Woofer WiringWizard JENSEN XS1010 Specs
Mar 07, 2016 | Jensen XS-1010 Car Subwoofer
Does anybody know what watt this is. it's sosed to be a 2400 watt and why does it have 2 ports on each side to hook up speaker wire And what's the best way to run it with a 800 watt Rockford fosgate
dual voice coil subs hook up mono on amp, from amp - from right side + from left side of amp run to sub n then jumper wires from one side of sub to the other side goes negative jumps on positive and positive jumps on negative
Apr 03, 2015 | Rockford Fosgate Car Audio & Video
How to wire kicker 07cvr124 4ohm duel voicecoil 12in sub to my rockford fosgate 4channel punch 600r amplifyer
run the positive from one voice coil the the negative on th other than take th left over positive from one voice coil and the negative from the other and bridge it to the amp use the blue sub wire but u will have to buy a 1 unto to splitter to hook up ur rcas from amp
Mar 28, 2012 | Rockford Fosgate Car Audio & Video
I see someone asking about this amp running a single 15" sub, how about running 2 10" subs?
Do you know how many ohm's the two 10" subwoofers are ? That is important as there are many ways to wire multiple subs. If you dont know then post what make and model the subs are.
Post back and I will try to be of further assistance.
Thank you for choosing Fixya!
Feb 15, 2010 | Rockford Fosgate Punch 401S Car Audio...
Rockford fosgate amp keeps shutting down when volume is cranked
your cd player cant handle all the power, time to upgrade to a cd player with at least 80w10
Jun 12, 2009 | Rockford Fosgate Punch P5002 Car Audio...
What kind of noise it will bang or should i go with class d amps
If you run a pair of subs to each amp at a 4ohm bridged load per amp you will get the full power of the amps delivered to your subs-roughly 450 watts per sub as punch amps are all under rated-that sh%&t gonna bump hard - thats an incredible setup from an equipment standpoint- i run 1600watts on a pair of 15z and its freaking obnoxiously LOUD and yours will be moving more air than my 15s so it should be just mind numbing - go for it !!!!!!!!
Jun 04, 2009 | Rockford Fosgate Punch 800a2 Car Audio...
I think my ex blew my amp
model number? im thinking 401s? if so that should be the only light on
Aug 07, 2008 | Rockford Fosgate Punch P5002 Car Audio...
Sub hook ups
There's a lot more factors involved than that.
  • Power capability of the subs
  • Type/size of the sub box
  • Allotted space in the vehicle for the sub box
  • Voice coil impedance of the subs versus the capability of the amp
  • Etc.
Jun 19, 2008 | Rockford Fosgate Punch 500a2 Car Audio...
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
Sep 26, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
Car Audio & Video Logo
23 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
