Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Ice maker freezed up and freezer not keeping items freezed up
Just recent, my ice maker wouldn't make ice, so I took it off and cleaned it, at which time I had ice on the back panel by the ice maker and some ice just to the right of the fan. I took some hot water and got the ice off, in which to take ice off I just rupped the hot hand towel on it till it was all off, then I took the bottom tray and took some ice that was at the bottom part by the fan on both sides. I then put everything back, I didn't hook up the water line to it til the next day, but after doing it their was no water running to fill the tray, so this tells me that the line is frozen up, but if the ice maker has no water running to it, why won't my freezer keep things frozen. I did notice some snow like ice to the back panel when checking it. Can some one assist me and briefly tell me what is the problem, maybe I can fix it with having to call a service man.
  • Anonymous Mar 18, 2014
    Water in ice tray
My ice maker seems to be leaking water right behind from cover plate.this is making rest of ice in front stick together,other then that it works great. Is there something I can tighten.
Jacqueline.
Posted on Jun 29, 2008
  • 828 Answers
Your automatic defrost system is not working which is the indication of the frost on the back wall. When the freezer does not come down to temperature it also affects the ice maker. This kind of problem is from a bad timer, defrost heaters or defrost thermostat. I do not think you want to tackle this problem yourself. Call a service man from an appliance store that handles your product and give him the same information you gave here with the exception of the removal of the frost on the back wall.
Posted on May 27, 2008
SOURCE:
How long to freeze bucket
Homemade Ice Cream Freezing Methods - RecipeTips.com
www.recipetips.com/...tips/.../homemade-ice-cream-freezing-methods.as...
Rating: 5 - ‎2 votes
Jump to Ice Cream Maker Using Ice - This type of freezing process is known as a "stir ... Place the covered ice cream can in the bucket, making sure it is ...
equipment - How long do I need to freeze the freezer bowl ...
cooking.stackexchange.com/.../how-long-do-i-need-to-freeze-the-freezer...
Dec 30, 2010 - Is a couple of hours in the freezer enough, or do I need to wait until tomorrow morning? ... This really depends on your freezer and your icecream bowl. Usually ... How to clean ice from ice cream maker bowl without thawing?
[PDF]Frozen Yogurt-Ice Cream & Sorbet Maker - Cuisinart
Jan 14, 2016 | Ice Cream Makers
Ice maker not making ice
Sounds like either your condenser is blocked or you have a refrigerant leak
Jan 05, 2014 | GE HSM25GFTSA Side by Side Refrigerator
ICE MAKER
to solve the frozen food problem, turn the temp back to 4. this should be the factory recomended setting. the only dispensing crush ice is probably a bad solinoid. you will find this behind the back wall. it engages to lift the thin metal rod on the bottom of the ice bucket to dispense cubed ice. and the ice being frozen in the bucket is probably a bad ice flapper in the door. it's letting warm moist air into the ice bucket that is freezing
Apr 23, 2010 | GE GSH25JFR Side by Side Refrigerator
Hi, My Amana Refirg is about 30 years old-refrig on bottom freezer w/ice maker on top. The ice maker was skipping and would not stop by raising the arm. Consequently is ceased, now however the freezer is...
do you see alot of frost on the rear panel of the frzer if so it has failed to defrost and repair is req or do a manual defrost until a tech can get to you if no frost sorry sounds like you have a weak tired compressor or leak of freon and being 30 yrs old it is not cost effective to repair this item....
Aug 19, 2009 | Amana Refrigerators
I have a FRS26ZSHB FRIGIDAIRE. I replace the ice maker and the valve and it still does not make ice.
do you have water at the dispenser if so when you replaced the icemaker did you replace the harness that clip that usually come with the new item. If not the freezer may not be cold enough for the imkr to freeze properly are the item you put in the freezer soft or take a long time to freeze may have a freon issue
Aug 19, 2009 | Frigidaire FRS3R5EMB Side by Side...
Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
May 01, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Freezer does not freeze some items completely and ice maker not
Replace the defrost timer. Take your make and model number to appliance part store and get a defrost timer. Relatively cheap and usually easy to change...
Jan 04, 2009 | Amana Refrigerators
Amana ARB9058CS Bottom Freezer - tremendous frost build-up in freezer on left side near ice maker at top of drawer
  1. I am not expert but this exact same thing happened to me - same model of fridge. The line which brings water in is frozen. I don't know how to solve it permanently, but if you take out the two produce drawers you can see where the water comes through. Put a hair dryer blowing on it for a few minutes and it will get it going again.
Aug 17, 2008 | Amana ARB9058CS Bottom Freezer...
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
247 people viewed this question
Top Whirlpool Refrigerators Experts
Bruce Denton
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
