Question about Oster Fpstdh0101 4tray Electric Food Dehydrator
Manual pdf I need a manual for Model: FPSTDH0101
Need manual
No make, no model, no help :>)
Google
make model manual
or check the manufacturers website under Support - Manuals
most are available online. Here is one to be going on with
http://cdn-10.nikon-cdn.com/pdf/manuals/noprint/D90_ennoprint.pdf
Apr 01, 2016 | Cameras
Need the manual for model 534?
SINGER 534 MANUAL Pdf Download. - ManualsLib
www.manualslib.com > Brands > Singer Manuals > Sewing Machine > 534
View and Download Singer 534 manual online. Stylist Sewing Machine. 534 Sewing Machine pdf manual download.
[PDF]White Sewing Manual Model 534
www.masepmadit.com/white-sewing-manual-model-534.pdf
vw instruction manual, white 534 serger: sewing parts online understandable ... techmanual white superlock serger model 534 repair manual compiled pdf.
Jan 07, 2016 | Sewing Machines
No manual came in the box? How can I get a manual. I have Lennox computer system!
Free Linux Unix tutorial for beginners Learn Linux commands
https://www.linux.com/learn/tutorials
You will need to find which distro you have and then continue from there. Most are fairly simple and if you get stuck either of the communities on the websites are extremely helpful.
Oct 14, 2015 | Oster FPSTDH0101 4-Tray Electric Food...
Need a manual
Need to know what you need a manual for?
Apr 17, 2015 | Audio Players & Recorders
Oster Fpstdh0101 4tray Electric Food Dehydrator wattage
well, I'm guessing on the tag or label it shows something like this
120V ~ 60 hz 10.5 amps or
120V ~ 60 hz 10.5A or
120V ~ 60hz 11A (some manufactures round up if it falls into the same wire gauge)
120Volts ~ 60hz 1260w or
120Volts ~ 60HZ 1260 watt
120V stands for normal operating voltage
"~" means ac current
60 herzts stands for how many cycles
So if your unit shows only amps, it's really simple to figure out wattage
take the voltage shown, in my example it's 120, then multiply the amps, in my example it's 10.5. So 120 X 10.5 = 1260 watts
W = V * A
and vice versus, if it only show wattage and you needed to know what gauge wire you needed to run a receptical to operate it
AMPERAGE = VOLTS / WATTAGE
Mar 07, 2013 | Oster Fpstdh0101 4tray Electric Food...
I need a manual for oster food dehydrator
go to the yahoo search bar and type in manual for oster food dehydrator if you have a make and model on it it will make the search more accurate ..in most cases you can find an online manual in a PDF file format...hope this helps.
Aug 26, 2012 | Oster Fpstdh0101 4tray Electric Food...
Oster  Fpstdh0101 4tray Electric Food Dehydrator Logo
96 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
