Question about Tools & Hardware - Others
Nikota i have a &' sander/polisher with the rubber pad and nut but it doesnt have an adhesive pad on it. should i buy th pads with adhesive or is there another rubber pad i need top buy?
b0sslady2001
  • 357 Answers
SOURCE: How to attach sand paper to the Kirby Turbo Sander attachment?
There is a plastic guard around the edges that comes off. Then, there are clamps that hold each end of the sandpaper. If you can't see the clips, then the guard is still on and needs to be removed. Hope this helps...
Marci
Posted on Jul 25, 2008
stug_57u
  • 99 Answers
SOURCE: pad on 9045B sander
Remove the bottom faom pad, which should just be held on with phillips screws. Under this you will see the eccentric weight that has a screw in the middle. Not sure if it is left hand thread or not so be carefull. It is normally thread locked aswell so be firm but fair when unscrewing it. Once it's out you should be able to lever the weight of by applying equal pressure to each side of it. It will be centered on a woodruff key so be cartefull not to lose it. Also, in between this part of the base and the main body of the machine there is a rubber skirt that is clamped to both parts. Unscrew the band clamping the skirt to the base and I think you should be able to pry it apart then.
Posted on Oct 25, 2008
SOURCE: Need to convert pad to hook & loop sys. Is product made to fit this sander pad ?
Thought about what my orbital sander is like, then went to a craft store and bought a large sheet/pad of velcro and cut it to fit the 6" rubber disc pad glued it to the pad and then bought hook and loop sanding discs. And you wondering why I didn't use my orbital sander?? Because I needed to get into tight spaces and the orbital sander is a bit too large for this, plus it's too heavy to use working overhead .
Thanks for your site and for asking if problem still exists. Appreciate it.
"Necessity is the mother of invention" Truer words were never spoken
Els439
Posted on May 30, 2009
messstat
  • 365 Answers
SOURCE: where can i buy new brushes for the vec236
I believe this is a "throw away" tool :o( if not, there'll be a screw-type "door" in the chassis of the grinder...get the brushes out and try your local ACE or TruValue hdwe.
Good Luck
Posted on Jun 14, 2009
  • 20 Answers
SOURCE: I have a Waxmaster 900 type 2 auto polisher by
try machine mart
Posted on Jul 31, 2009
When I bought my sander it has what i would describe as a rubber pad onj the sander. Is this the sanding pad?
That sounds right. It is probably the type that uses adhesive backed paper. You stick the paper to the rubber pad.
Jul 14, 2012 | Dewalt DW 411 HAND PALM SANDER
Hi can I use my Dewalt polisher and change to sandpapper if so what parts will i need for instance glue new flexable pad sticky 220 papper can you please elaberate a little what in going to need thanx ...
I'm not sure I understand your question, but I'll give it a go.
The DW421 is a sander already. If you want to change it to a polisher, you can buy polishing pads to go on it.
If you have a Dewalt polisher and want to convert to a sander, you can buy sanding disks to fit your polisher. They are installed on the spindle and I believe you can get a backing pad for it also.
Hope that helps
Mar 19, 2011 | Dewalt DW421 5'' orbital sander
The base has lost its stickiness and no longer holds the velcro pad that you attach the sandpaper to.
I had same problem. Go to the hardware store and buy some Velcro strips. One side has adhesive, just put that side on the mouse. I had to put several strips on then cut around the shape of the mouse. Sandpaper for the mouse sticks to it great. Just be careful when pulling the used sandpaper back off that you don't tear off the Velcro. I threw that little pad away that was originally on the mouse.
Dec 09, 2010 | Black & Decker Mouse Sander/Polisher
The velcro pad on my mouse sander will not stay on the sander
Go to the hardware store and buy some velcro strips. Had to throw away the pad.
Nov 08, 2010 | Black & Decker Mouse Sander/Polisher
I replaced the rubber sanding pad but the screw keeps backing out during operation.
Some pads come with a new screw that has loc-tite on them. If you used the old screw when you put the new pad on, the loc-tite was probably dry and flaking off. Put a small drop of loc-tite on the threads, snug it down and let it sit over night and it won't come out anymore.
Sep 15, 2010 | Bosch 3107DVS Electric Sanders & Polishers
How do I remove the rubber pad from the 31-7 sander? Which way should I turn the the allen wrench?
hold pad and turn the screw counter clockwise to loosen. Let me know if you need more assistance.
Mar 24, 2010 | Bosch 3107DVS Electric Sanders & Polishers
Sandpaper will not stick to pad
Use a quality adhesive backed sanding disk, and clean the pad area with isopropanol/alcohol. This should allow the adhesive disk to stick.
I recommend 3M adhesive disks.
Jan 24, 2010 | Bosch 3107DVS Electric Sanders & Polishers
Sandpaper will not stick to rubber bed bosch
This is generaly due to previous adhesive buildup on the backing pad OR, the face of the backing pad is breaking down and cracking.There are two ways to handle this. You can try scrubing the crud off the pad (I wouldn't) or, you can get a new backing pad for your sander. At this point, you might want to go with a velcro type pad or hook and loop as they call it (cleaner and no goop). Check your local home depot for pads. If you cannot find one, I would suggest you call Klingspor abrasives Co. They have area reps all over the United States. I know, as I used to be one of them.They carry,.. and will send you pads via UPS. Just make sure you don't try to put a 6in pad on a 5in sander or vice-versa as the pads are weight-mated to the sanders. If you do, you will burn up the motor in your sander rather quickly.
Jan 24, 2010 | Bosch Power Tools Sanders Orbital Sanders
Els439
May 29, 2009 | Black & Decker Tools & Hardware - Others
Orbital sander flicking the sand paper off
You did not specify how the sanding discs are meant to be attached to your sander's backing pad.  My experience with this type of problem is material from the sanding process builds up on the backing pad and does not allow the sanding discs to adhere properly.  If you have a velcro type system, clean the hooks on the sander's backing bad by soaking the pad's face in a plate of paint thinner for 20 to 30 minutes then use a wire brush to remove the rest of the paint physically.    For adhesive pads clean the sander's backing pad surface with denatured alcohol.  Do not use isopropryl or rubbing alcohol as this may not be 100% alcohol and could contain a lubricant like glycerin.  When the sander's backing pad is completely dry and clean it will hold adhesive backed pads fine.    Flaky paint is best scraped off before sanding, use a wide putty knife or a paint scaper to remove large flakes before sanding.  This will minimize airborne dust and cleanup.    For best results with adhesives, always keep your surfaces  clean!    Good luck and happy sanding!  Michael Mittelsdorf
Jan 07, 2009 | Bosch Power Tools Sanders Orbital Sanders
Tools & Hardware - Others Logo
21 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
