Question about Refrigerators
Samsung rb1844sw refrigerator must be unplugged and plugged back in to make it cool. changed mother board and door switch so far.
5 Suggested Answers
SOURCE: My Samsung refrigerator will not cool
Call Samsung. I had the same problem when Best Buy delivered mine. The delivery people left the fridge in demo mode. The people at Samsung will talk you through it, it is very simple. The fridge should work fine then.
Posted on Jun 25, 2008
  • 1796 Answers
SOURCE: Samsung, RB1844SW refrigerator. After
Hi! When you unplug it from the power outlet and plug it back in, you mentioned that it starts up. What happens after that?? Please, be as specific as you can, Thank you.
Posted on Sep 24, 2010
heatman101
  • 43501 Answers
SOURCE: Samsung RB1955SW refrigerator is not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 30, 2010
  • 5370 Answers
SOURCE: I have a samsung rb1944sl.
If it cools for few minutes or few hours, then quirt cooling , but when you unplug and re-plug, it starts cooling and same cycle/ problem repeats.Then its main control board problem.But if main board is already replaced, then the other possibility is weak compressor or compressor low on refrigerant.When the compressor gets weak, it will not cool properly, or when Freon/ refrigerant is low in compressor then it will not cool the unit properly.----------- In some cases its noticed that new brand board comes bit faulty.So that can be also possible.In some cases its seen, the new board looks very good, but comes faulty.------- But if board is replaced properly and confirmed its not the problem, then compressor needs to be inspected and its refrigerant needs to be tested by tool. Local refrigerator repair tech only has this tools.-------- This will help.Thanks.Helpmech.
Posted on Sep 23, 2011
Samsung model RB1844SW. Refrigerator and freezer stop cooling. Unplugging and plugging back in resets and it works fine for 7-8 hours before the same problem occurs.
Check if the circulation motor /fan which blows air around the inside is working . It is located near the top of the refer. also check if air is circulating in the freezer there is a main fan in there which sends cold air from the freezer to the refer. If either fan wears out sometimes it runs for a while and sometimes not. the motor chatters sometimes before it dies. I have had defroster control timers go bad, causing this problem too, because the refer goes into defrost cycle and doesn't go back to refrigerate mode till the defrost cycle is over. if the timer clock stops it will do the same thing, and not go in to refer mode. Good luck, Bill
Jan 07, 2018 | Samsung Microwave Ovens
The ice maker will not quit dispensing ice and it no longer cools
For now unplug the pin plug at lower freezer door hinge and disable the dispenser control board until we see if the keyboard or the dispenser board is at fault. Sea Breeze
Feb 22, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Stops cooling ice melts and leaks water on the floor
That model refrigerator uses the mother control board for deciding when defrost is to take place. It has no defrost timer or Adaptive Defrost Control like other refrigerators. This sounds like *********** board part number WR55X10942 is malfunctioning. The board decides most functions of your refrigerator. Until the board is replace I do not believe the problem will resolve itself. Thanks, Sea Breeze
Sep 26, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerator will not reset after a power outage
just unplug it wait 5 minutes and plug back in. If this doesn;t work, replace the mother board.
David
May 16, 2009 | Samsung RS2534 Side by Side Refrigerator
Door ajar alarm ringing and refridgerator not cooling enough
it sounds like either a defrost problem or damper door problem it is very well worth fixxing
Dec 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
96 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
