Question about HP Pavilion Computers & Internet
Webcam sound - Pavilion HP Computers & Internet
  • HP Master
  • 7,627 Answers
A bit vague? HP Model number , Internal or external webcam? OS you are using, what are you using with the webcam, software, would be helpful.
Posted on Apr 27, 2013
No sound
Webcam Audio Getting sound to broadcast with streaming video using a webcam requires a few components to work in unison. Because most webcams do not have a microphone built in, you will need to buy a microphone for your computer or locate your microphone input if you have one built in (some laptops have these). The audio and video are two separate functions and must be diagnosed as such. b> Webcam Software b> If you have a webcam set up correctly and you are streaming video, then you are already halfway there. This details only how to make the sound work, so please refer to an article related to webcam video if you do not have that working already. The webcam audio and video both communicate with your computer via your webcam's software application. Due to this, you will find that there are settings specific to your webcam software for sound. Because there are various software applications that can act as an interface for your webcam, you will want to do a product-specific search on the Internet for your application's settings. Most often you will find the settings for sounds under Tools or Settings, then choosing Options or Preferences. Regardless of the application that you are using to broadcast your webcam video, you will need to ensure that your microphone is plugged into the "Microphone In" jack on your computer or laptop. The microphone input jack is commonly colored pink. b> Microphone Connection b> With your microphone plugged into the "Microphone In" audio jack, test the audio inside your webcam's software application. Most webcam applications allow you test your microphone by reading a sentence and watching a graph move as you speak. If you see this happening, then you have correctly hooked up your microphone. If you have a Windows PC you should also see if your computer recognizes your microphone by clicking on "Start" > "Settings" > "Control Panel" > "Sounds and Audio Devices." Under the "Audio" tab you will find a section for "Sound Recording." From there you can select or change your "Default Device." b> Hardware Troubleshooting b> In the event that your microphone is not recognized by your computer, continue hardware troubleshooting by contacting your computer's support staff. With a properly connected microphone and some minor adjustments in your webcam's software application, you should be broadcasting audio with your video in no time. Hope this helps.
Jan 22, 2013 | Gear Head Gearhead quick webcampro...
How do i get sound on my hp pro webcam
Check it exists in Control panel / Sounds,speech etc / Sounds and audio sounds / voice.
If you see anything greyed out then uninstall webcam / re-install driver, Do NOT plug webcam in until driver is loaded.
If you do see the driver listed, ensure you have selected "webcam" for voice recording.
Playback is usually thru your PC speakers.
May 18, 2010 | HP Webcam
My webcam works great but no one can hear me
You need to go into the webcam properties and test the webcam, you will soon see if the audio has a probem.
To access webcam go to Start / Programs / webcam / properties and test from there.
Dec 30, 2009 | Logitech Webcam
How do i get my asus k50 webcamera to produce sound?
webcams dont have mics...the mics are built into the bezel around the screen and are controlled by the sound drivers. You have to use the webcam software to link the sound drivers to your webcam software so the two work together when you are on video messaging. Check into the webcam software documentation. I know that when I was setting up my webcam in Gmail, it was linked to the sound drivers automatically.
Sep 02, 2009 | ASUS Eee PC 1000H Laptop
Sound problem
The easiest way is to deactivate your input sound on your computer. so for sure no sound will go through your webcam out. It depend to your computer system.If you are windows user you can do it in control panel-sound option-input.
Regards
Jul 09, 2009 | A4tech PK-635 Webcam
Picture received no audio
Check if ur PC sound card works Fine. If it does Then Open Sound Settings In Syatem taskbat and set LINE IN as recording Plug.Increase The recording Volume of LINE IN.Make sure u plug ur Microphine cable of the webcam into LINE IN slot of ur sound card.Then Check...........
May 26, 2009 | Creative Labs Live! Cam Video IM Pro...
No sound on video capture
i dont think webcams can record sound. i think you need to buy a microphone, too
Apr 29, 2009 | Micro Innovations MCNIC50C Webcam
4 LED USB 2.0 WebCam problem
I hooked up my webcam through the usb. the mic picks up sound and it gives off sound. When I open the camera under my computer it shows video. When I use skype it says to shut down all programs that are using the webcam, but here is the problem, there is nothing open, and nothing else using the web cam. Any suggestions on how I can fix this? Thanks!
Sep 30, 2008 | FMI Portable Webcam
Audio on Webcam is distorted - seems to be recording at a slower speed and palying back at normal spped
as a workaround you can use the headset, you just need to configure your messenger again to use the sound from the mic input instead from the webcam.
May 28, 2008 | Logitech QuickCam Pro 5000 Webcam
Computers & Internet Logo
14 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
