Question about Daewoo KOR-6115 Microwave Oven
Timer not working - Daewoo KOR-6115 Microwave Oven
I have a basic Matrix microwave with a rotary timer. It still works fine, but about half the time the timer runs backwards, adding time instead of running down. How do I fix this?
That's a new one on me! Rotary timers are considered the Most reliable. Bought one in 1985. Put it in the barn ages ago, still working.
I think I would look the maker up, online, and ask them. Cleaning the timer dial Thoroughly, might work. With something like vinegar and baking soda. Or any kitchen cleaner. Even a can of air, to blow out dust and gunk. Good luck!
Jan 03, 2018 | Microwave Ovens
Microwave quit working, timer, number buttons timer, all functions on micro side of control panel quit working , timer numbers start etc.
Check to see if the fuse went. If negative then something is wrong with the electronic pad for the unit.
Nov 25, 2015 | Microwave Ovens
Cook works microwave timer stuck
If by "manual timer" you are referring to a knob that you turn to set the cook time, then you may have a failure of the motor that turns the timing mechanism, or a lack of power to it.
May 10, 2014 | Microwave Ovens
COOKWORKS MICROWAVE TIMER
Replacing the timer could solve the problem
Sep 25, 2012 | Microwave Ovens
Cannot hear sound when program ing , such as timer light etc
If you can operate the pad normally, the miniture speaker on the control board has failed or a bad solder connection on the circuit board.
Apr 05, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
INtermatic Model ST01 timer is to be used in a 3 way switch arrangement. The unit works in one switch position but fails to allow the light to turn on in the other switch position. Several other switches...
ST01C timer replaces one 3-way switch and the other 3-way switch remains.
The ST01C timer does not work exactly like a 3-way switch.
When the timer blue and red wires are connected together, they reverse whatever program is in effect.
When the timer is wired for single-pole, the red wire is capped off. When timer is wired for 3-way, the red wire is used to reverse the timer, thus causing the 3-way effect.
So if timer is ON, and red and blue wires are put together, the timer turns OFF.
That's why the remaining 3-way switch has to be rewired.
The remaining 3-way switch is rewired so it will connect and disconnect the red and blue wires, causing the timer to reverse program each time, and creating 3-way effect.
Other requirements of ST01C is that the black wire must connect to Hot wire, and the blue wire must always connect to Load. This means that you have to correctly pick which 3-way switch to replace, where the hot wire from breaker arrives.
Open following link for wiring diagram showing how to wire for 3-way:
http://waterheatertimer.org/ST01C-program.html#ST01C
All 3-way timers require rewiring second 3-way switch to create 3-way effect.
Jun 21, 2011 | Microwave Ovens
INTALLED A INTERMATIC TIMER AND EVERYTHING IS WORKING WITH THE EXPTION ON THE TIMER ITSELF. DO YOU HAVE ANY SUGESTIONS
1) First suggestion is for you to add a comment and say what model number Intermatic timer you are working with.
If this is a box timer, then model number shows on inside of door.
In any case, we are guessing at your problem without knowing model number.
2) If this is a box-type timer, main thing folks do wrong is reverse the line and load wires.
Line wires come from the breaker box, and Load wires go to the fan, light, motor.
Line wires have to be connected to the clock terminals or the dial will not rotate.
The clock terminals are usually visible as small white wires connect to two of the terminals. Again, this is dependent on model number.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 23, 2011 | Microwave Ovens
I don't have the Manuel to program a WESTEK TE22DHB timer. Can you locate one or tell me how to program it?
Many timers are sold under different brand names with different numbers.
For example Westek TE06WHB is same as Woods 59377
Sometimes different timers are packaged under same number, for example Utilitec TE06WHBL is shipped as the old Woods TD1300.
GE and Utilitec sell the same timer with different numbers.
Westinghouse and Stanley and Utilitec and Woods overlap.
I got manuals for some, and can sometimes cross reference if you describe the timer.
1) take a minute and add a comment with description of button layout with button names, or describe the dial and switches. Be as detailed as possible.
2) Look through timers on following links and see if your timer shows:
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/GE-timers-and-manuals.html
Daewoo KOR-6115 Microwave Oven Logo
22 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Ian Summerfield
Ian Summerfield
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
