Question about Canon EOS 600D Rebel T3i Digital Camera
Bright light background - Canon EOS 600D Rebel T3i Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
What is your question? Are your pictures coming out with the background too bright? Do you want to take pictures of a subject with a bright light in the background? Something else?
Posted on Apr 27, 2013
Testimonial: "Whenever I shoot inside a house with a bright light coming from a window or an open door, the whole room becomes dark. How do you control the backlight from Canon EOS 600D?"
How to turn off backlight on iphone 4
There is no separate "back light" setting like there used to be on some earlier phones.
In the Settings app of your iPhone, there is a section called "Display & Brightness". You can use that to make your phone's display brighter or dimmer, but as you have probably discovered, it dims or brightens both the foreground and the background elements together as one.
You can turn it all the way down, which is very dim and hard to see in normal indoor light conditions, but may be preferable in extreme low light conditions like in a nightclub setting, or in complete darkness.
Why isn't there a separate back light setting?
To fully answer this, I would probably have get into more than you ever wanted to know about displays.
First, there is really no background or foreground on today's smart phone displays. The foreground elements and background elements we see on the iPhone are really a graphic illusion created by lighting individual pixels with different colors. All of these pixels are on the same plane, so nothing is really behind or in front of anything else. It's just artistically drawn to look that way.
Brightness is simply an "intensity" setting applied uniformly across all of the underlying individual pixels within the display matrix, and has no relationship to color. For clarity, let's look at the difference between lightness in colors, versus display brightness:
COLOR LIGHTNESS is a matter of how much WHITE (all the RGB colors summed, for example) is present in a given color. This has nothing to do with display brightness.
DISPLAY BRIGHTNESS is a matter of how much LIGHT INTENSITY is applied uniformly across all pixels in the display matrix.
At zero display brightness, you would not see white any better than black, blue, green, red or any other color. You wouldn't see anything.
Why did you expect to be able to control the back light?
Prior to the smartphone era, the displays on early cell phones and pagers (and lots of other devices that had displays) had a lighted background that contrasted with dark foreground elements.
The background intensity was a separate setting on those devices, but that's because the background was the only thing that had intensity. The foreground elements were solid black LCD (liquid crystal display) segments that were used to form characters and very simple graphics and lines.
Everything we see on today's smartphone displays is dynamically drawn by lighting different pixels with different colors at different times. Individual pixels on a Retina display are nearly microscopic in size--they cannot be separately discerned by the eye.
Imagine a matrix of microscopic light bulbs, each of which can separately change to any of millions of colors and levels of brightness at any time, on command. Just imagine the sheer number and complexity of possible commands to control a Retina display!
Even if Apple wanted to provide a new feature that enabled us to separately control the perceived "back light", it would only be an illusion as well.
Such a feature would require some sort of complex algorithm to determine which pixels are involved in what you perceive as the "foreground" elements at any given time, so it could add intensity only to those pixels considered to be "background" at any given time.
Since "foreground" and "background" elements drastically change shape (and location) at any time, such a feature would be pretty daunting to implement.
You might be better off using a pure black graphic as your background image if your goal is to have more contrast to make the app icons stand out.
Cheers,
-=Cameron
Aug 12, 2014 | Apple iPhone4 4G iPhone 4
On my Dell E193fpc monitor, the background lighting goes off after a few seconds. The actual Screen-image is still there (can be seen in bright sunlight). How can I get the backlighting to work proper
This sounds as though there might be a problem with the inverter (this is a component that supplies a high voltage for a tube(s) that illuminate the screen.
As there are high voltages on inverters, this is really a job for a repair shop.
Dec 11, 2013 | Dell E193FPC 19" TFT LCD Flat Panel...
How do I adjust screen brightness for night use?
The Power/Light is used to turn your GPS on and off as well as to adjust the background and back light. To adjust the back light press the power/light key to access the light and background menu. Use the 4 way cursor key to select light or background. Then use the left to right cursors to change the settings. Then press exit to exit the light/background menu. This should answer your question.
Mar 09, 2011 | Humminbird 1197c GPS Receiver
On lighter backgrounds the pictures have horizontal lines as shown, what is going? This only happens on light objects and backgrounds.
This can happen if the light is too bright. When you capture bright object/background, try to turn off your flash light, see if you'll get better picture.
Hope this help (^_^)
Jan 08, 2011 | Sony Cyber-shot DSC-W180 Digital Camera
Pink sky in background.
Try and use the SCN. Mode.
Bright light is never recommended for any pics.
Contact KODAK they might have more ideas or can arrange a repair for you if needed.
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 25, 2009 | Kodak EASYSHARE M1063 Digital Camera
Screen returned from supplier background bright pink, how do I change to white background.
To check if the video card or the Sharp LCD monitor is faulty, connect a different monitor to the computer. If this monitor displays a normal image then the video card is OK and the Sharp LCD monitor's back-light is faulty. Send it back to the supplier to have it fixed (they should not have reurned it to you in this condition).
If the other monitor also displays a bright pink background then the video card is faulty and needs to be replaced.
Nov 19, 2009 | Sharp Computers & Internet
Why are my pictures so blurry.. HELP PLEASE!!
Hi Lindsay Davi,
First, make sure you have the file size set to the highest size and highest quality. Small file size and low quality settings produce small files with pixelization.
Second, no camera performs as well in low light as it does in bright light. It sounds like you are new to photography, so you should start out by shooting in bright light - outdoors in the sun. Once you know how to take good photos in the sun, then you can try taking photos when it is overcast, or in bright shade (on a sunny day but outside of the direct sunlight). As you develop more experience in taking photos you can try more difficult lighting situations such as indoors.
Flash lighting is difficult because the light "falls off" quickly as the distance from the flash to the subject increases. The camera's flash tries to put out enough light to illuminate both the subject closest to the camera and to also try to light the background, but this is often impossible. So the subject is too bright, and the background remains dark. If your subject is further away, the lighting evens out some. If your subject is close to the background (e.g. standing in front of a light colored wall) the camera will get the flash exposure set to a better value and the photos will come out better.
It would also help to get a book on basic photography.
Dec 26, 2008 | Nikon Coolpix S550 10 Megapixel Digital...
Background is overexposed
So, the problem doesn't seem to be the flash if the actual subject in the foreground is exposed properly. My guess is that the background is being lit by another light source. Typically, your camera uses a flash for dark areas or what it gauges as a dark area. This doesn't adjust the background for additional light sources. For example, if you're standing outside and there's a tree covering someone that you're taking a picture of your flash will adjust to "properly" light that individual. However, because the flash was used for the main subject, the background is actually now overexposed. The overexposed background will show up as a brightly lit area because the camera had to adjust for the foreground. This will actually reverse itself when it's dark out - meaning if the background and foreground are dark, the flash will expose the foreground, but the background will be black. Hopefully, that helps you understand lighting and exposure. Now, to fix this problem when shooting, you would need to consider several options - 1. SLR camera with aperture and f-stop settings as well as compensation controls. This will allow you to control every element of the exposure, but you still need to be aware of the lighting behind the "subject" to properly expose your shots. 2. backlighting compensation - common settings on both SLR and point and shoot cameras that makes auto lighting conversions for backlighting and other common lighting issues. Test whatever options are on your camera to see what works best for your specific problem. 3. Photoshop retouching - you may take one shot with your subject exposed properly and a second shot with the background then merge the images together. 4. using a tripod to shoot without using the flash - this may give you the closest exposure to exactly what you see when looking at your subject.
Dec 19, 2008 | Polaroid i733LP Digital Camera
Strange silhouetting and a vertical strip
If A vertical strip appears on the screen when recording a dark background or the subject is blooming or silhouetting, you need to adjust the BLC. * The contrast between the subject and the background is too great for the camcorder to operate normally. * Make the background brighter to reduce the contrast or use the BLC function while you are recording in a brighter environment. BLC (Back light Compensation) * BLC works in CAMERA/M.REC mode.B * Back lighting exists when the subject is darker than the background: 1. The subject is in front of a window. 2. The person to be recorded is wearing white or shiny clothes and is placed against a bright background; the person?s face is too dark to distinguish his/her features. 3. The subject is outdoors and the background is overcast. 4. The light sources are too bright. 5. The subject is against a snowy background. 1. Set the power switch to CAMERA mode. 2. Press the BLC button. Normal - BLC - Normal BLC enhances the subject. Notes: * When NITE PIX to set to ON, the BLC function does not work. * The BLC function will not operate in EASY mode.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Canon EOS 600D Rebel T3i Digital Camera Logo
26 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
