Draining problem in samsung washing machine sw65v5
Samsung sw65v5 does not drain after washing the carpet. it wash but does not drain
SOURCE: Our samsung j845 front load washing machine won't
SAME THING HAPPEND TO ME, SORRY BUT YOU NEED A NEW WATERPUMP, THEY GO ON THEM WASHERS ALL TIME. I REPLACED 2 AND HAD MY WASHER JUST OVER A YEAR. NOW ITS THE DOOR
Posted on Sep 29, 2009
Benimur
  • 6966 Answers
SOURCE: repair of samsung (karisma ) washing machine
Water draining is indicative that the drain valve is left open allowing water to escape even during regular/wash cycle and not only on drain/wash cycle completion. this could be brought about by:
1. laundry material, debris, safety pin, clips or some other foreign material has lodged itself prohibiting the drain valve in closing properly; or
2. the mechanism (solenoid) closing the valve is jammed in the open position.
Corrective measure calls for inspection and possibly cleaning or solenoid/control mechanism repair or replacement. Often these can be found at the bottom or near bottom of the machine below the tub.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 21, 2008
  • 3230 Answers
SOURCE: G.E. washing machine will not drain completely
It won't drain
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
good luck.....
Posted on Mar 28, 2009
  • 5 Answers
SOURCE: the washer will not drain or spin
more than likely the pump needs replacing, first of all remove the outlet drain hose from the the place it discharges and lower it into a bucket,this should allow it to syphon away,you may need to empyt the bucket a few times once the machine is empty you should be able to put it on its spin cycle once it has spun locate and remove the filter to remove any objects or lint, fill machine with warm water and try to drain and spin via the programme,if this do not work fit a new pump
Posted on May 29, 2009
mgprice
  • 744 Answers
SOURCE: Miele Washing Machine Code: Check drain
This means that the drain attached to the pump is clogged, remove the drain plug check fro debris and replace...you should be good to go.
Posted on Jun 23, 2009
E2 Code - Samsung SW50ASP Washing machine
Water drainage issue. Water is not draining from appliance.
·Check drainage pump filter for blockages (e.g. lint, coins hair, clips)
·Check drain hose and waste connection for kinks and blockages.
Then select a spin cycle to drain
the remaining water in the appliance.
·If problem persists please call CustomerCareline. *
Helpline Contact Samsung UK
Dec 08, 2016 | Samsung Washing Machines
What is the meaning of 4Eerror code in samsung SW55V3 washing machine
When the pump keeps running, you have a 'slow drain problem'. The machine knows it should empty in a certain amount of time. If it doesn't it runs the pump all the time. You can usually reset it by just unplugging it and counting to 10 before reconnecting.
It is usually caused by blockages in the filter or in the pump itself.
http://landersappliance.com/Blog/ArtMID/1641/ArticleID/43/Samsung-Washer-Service-Problem---slow-draining
and this video.
How to Diagnose Washing Machine Drain and Pump Problems
Jan 09, 2016 | Samsung Washing Machines
Indesit WDG1295W. Why doesn't it drain?
The pump and connecting lines could be choked with debris the filter didn't catch.
Dec 26, 2015 | Washing Machines
Samsung washing machines water drains continously
The drain hose is too low, you need to lift the height of the drain hose as it is siphoning and won't be able to fill to the required level.
Mar 05, 2012 | Washing Machines
Washing machine stop draining and not spin drying
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 21, 2011 | Samsung Washing Machines
While moving my samsung top washing machine, I think my drain hose pipe has moved down the water level. Now machine is not able to retain the water while washing/soaking. I need to pull the drain hose pipe...
Although a few modern washing machines can operate with the drain pipe at any height, most machines will drain the water as soon as the drain pipe is placed below the machine water level.
The simplest solution for your problem would be to ask somebody with some handy man skills or hire a plumber to add a 2 inch PVC pipe to your drainage pipe which extends to a point behind your washing machine & then points upwards, making sure it is long enough to be at a higher point than your machines fullest water level.
This should be a relatively inexpensive alteration & will ensure that water does not drain unless the machine is on its drain cycle.
Please let me know if you need any further assistance.
Best wishes,
Graeme
Mar 10, 2011 | Samsung SW62ASP Top Load Washer
My washing machine isn't draining
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Jan 22, 2011 | Samsung WF203ANW Front Load Washer
My samsung vrt front loader will not drain or spin and showing nd code
heatman101
Aug 28, 2010 | Samsung Washing Machines
Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Sep 30, 2009 | Samsung Washing Machines
Washing Machines Logo
76 people viewed this question
Top Washing Machines Experts
