Question about Garden
Not getting spark - Garden
    Top Expert:
  • Garden Master
  • 42,583 Answers
Check that the stop button is not shorting out causing a shut down effect.
Posted on Apr 27, 2013
No fuel in one cylinder 1998 ford ranger
Either has a bad injector or the wiring to that particular injector has been pinched or skinned and grounded somewhere.
Feb 20, 2015 | 1998 Ford Ranger
What do u do when spark is weak on Yamaha blaster
Check battery voltage, remove spark plug suppressor cap from HT lead and see if spark is good by holding lead in a gloved hand and placing the lead end near the engine. If spark good get a new suppressor cap. Check the plug shows a good spark in the new cap by holding the screw thread to the engine. Poor spark change spark plug. If you get a poor spark from the HT lead then get the ignition coil checked.
Oct 06, 2014 | Yamaha Motorcycles
Why my 1996 cadillac fleetwood brougham not getting any fire to the engine?
Your question needs some additional details. Are you sure that it is not getting fire to the cylinders or are you just using the term "not getting fire" because you are not getting any response from the engine when trying to start the car? Does the engine turn over? I would assume that it probably does based on your question. If your engine turns over then the first diagnostic step to see if you are getting "fire" (spark) to the cylinders is:
- Remove a spark plug wire and remove the corresponding spark plug.
- Put the spark plug wire back on the spark plug.
- Now hold the spark plug thread against a metal part of the engine
- You may want to use rubber gripped pliers to hold the spark plug
- Have someone turn over the engine.
- Watch the end of the plug to see if you are getting a spark jumping the gap to the ground electrode (little metal arm suspended in the air at the end of the spark plug).
- If you are getting spark then you are getting fire and your issue is most likely fuel related or timing (spark synchronization to the cylinder cycle).
- If you are not getting spark, then you have electronic/electrical issues
Let me know what you find out...
Aug 08, 2014 | Vehicle Parts & Accessories
How do i get a blue spark
The issue is spark yes/no. The color is not really relevant. Any spark will usually fire the mixture.
Sep 13, 2012 | Ford 8N Tractor
Getting power to spark plug but no spark
if you get a shock holding it put no spark at the plug the coil might be week
Apr 07, 2012 | Garden
I have a swisher 13 hp briggs trailmower. i am not getting spark to the plug. how do i check to see if trhe module is bad
(Make sure you have a working spark plug.)
Take the spark plug out. Hold the plug, or have a friend hold the plug, to the engine. Pull the rope and see if you get spark to the plug. You may need to get in a dark area so the spark can be seen. If you get a blue spark, that is good. If you get a white spark, that means the module is weak. And if you get no spark, that means it is bad.
Good Luck!
Jim
Jul 30, 2011 | Swisher 60" 13 Hp Trailmower #T1360h
My 5700 watt 11 HP McCullough generator wont start. I'm getting good gas to the plug but no spark.
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
Oct 25, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
I want to change my spark plugs
First get the spark plugs, then get the right swivel socket for the spark plugs and a gapper for the gap of the spark plugs.
Remove the boot, from the first spark plug, and..
Unscrew each spark plug one at a time (making sure not to mix up the spark plug wires) using a ratchet and extension, and the swivel spark plug socket by turning counter clockwise.
Carefully gap each spark plug, if needed, and insert by hand and slowly screw in each spark plug, making sure not to cross thread.
Put the boot back on to each spark plug, making sure that you squeeze down the connector a little bit to ensure a good tight connection.
Remember, replace one spark plug at a time and replace the boot in order to not get the firing order mixed up.
Aug 27, 2010 | 2000 Renault Sportwagon
Stalled out does not seem to get spark
First, you must find out if your getting spark or not. Remove plug, and ground it to the motor and pull cord, see if your getting spark. If you are, then your problem is your not getting fuel. If your not getting spark there are a couple of things that can cause this. !st, defective spark plug, Second, cable from control handle to engine may have stretched and is not releasing the kill switch. Disconnect the kill switch wire and check to see if you have spark, if you have spark, replace engine control cable. If with kill switch wire disconnected you still have no spark, you would have a defective magnito coil, which is rare, but does happen. This engine control cable kills the spark when you release the handle and also is the engine brake, It serves two functions.
May 25, 2010 | Toro Lawn Mower With Toro Power Tools
98 dode ram wont crank no spark
May have no spark due to a bad crank sensor, which is responsible for spark when it gets a pulse through the cars' computer.
Apr 24, 2009 | Dodge Ram 1500 Cars & Trucks
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
