How do i clean Bosch WAE20261AU front loader washing machine
Hi, we have used the Bosch WAE20261AU front loader for 4 years now and it works wonderfully. However the rubber seal where the door shuts is almost black (original colour is grey) due to grime. How can I clean this. Also, is there a way to remove the lint that may have accumulated in the washing machine. Thanks for your advice.
  • abas_k Apr 27, 2013
    Hi, thanks for your comments. I will try a mould remover. However i can't seem to find the lint filter on this frontloader. I actually am not sure if a lint remover exists on this one !!
    Top Expert:
  • Washing Mach... Master
  • 42,713 Answers
The lint will be in a removable filter and as for cleaning the rubber seal the black grime will most likely be mould. Try a good mould remover.
Posted on Apr 27, 2013
Testimonial: "thanks."
  • Bill Boyd Apr 27, 2013
    contact Bosch washing machines on line and enquire about the lint filter position stating the make and model of the machine
barkencoa
  • 3463 Answers
SOURCE: black marks all over the rubber seal at the front of machine.
The mould you are referrng to is actually bacteria that is building up because you are doing too many low temp washes.
What you must do is a high temp wash periodically,with powder in but no washing.
Do this 3 or 4 times a year, more if you do a lot of wahing.
It is called a maintenance wash, and helps kill off the bacteria.
With a scouring pad or steel wool pad, clean as much scum as you can off the door seal. particularly in the folds of the seal.
You will probably be left with stains in the rubber, but as long as you have got the worst off, it should be o/k.
Please rate my solution.
Thanks.
Posted on Jan 21, 2009
57 varieties
  • 1653 Answers
SOURCE: I have a dirty rubber inner Bosch Maxx 1200 Front Loading Washing
First clean around the rubber with some mould and mildew cleaner for bathrooms - available from most supermarkets.
This is a natural accumulation of waste detergent, fabric softener, fibres and dirt build up that is being attacked by bacteria and eventually decomposes into a sludge / goo and then eventually starts smelling bad as well.
To keep the machine clean of waste build up and to keep any bad odours away:
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Posted on Oct 02, 2009
  • 209 Answers
SOURCE: front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Posted on Sep 19, 2007
  • 41 Answers
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
Posted on Feb 29, 2008
SOURCE: BOSCH Washing Machine -Door Seal
1) remove the tension ring under the rim of the seal at the front
2) flip the whole seal into the drum so that you can get at the inside of the seal
3) remove the tension ring hold the seal to the outer tub
4) reverse of the process to put in the new seal
Its as simple as that.
Posted on May 23, 2008
Bosch avantixx front loader leaking underneath machine? machine only 2 years old
  • You will find a small door on the front bottom of the washing machine.
  • Open it.
  • Unscrew the filter and rinse it with running water.
  • Put it back in place and repeat the above steps in reverse order.
This should solve your leakage problem.
Aug 03, 2014 | Bosch Washing Machines
I have a Maxx Classic WAE20261AU/01 front loader. The machine won't start because the door won't lock. The door has been playing up a bit for about 2 months, but now it won't lock at all. It is...
Sorry. It seems that I have fixed it by using your solutions!
I drained it and cleaned the filter thing down in the bottom right hand corner, put it back to gather and then it turned on again!
Interestingly I found a bobby pin down there!
Thanks for your assistance John_Cross!!
Jun 21, 2011 | Bosch Washing Machines
What is the best thing to use to clean the inside of the front door seal that has sludge in it.
Bosch Classixx WFC 2465 Front Load Washer how to
clean door seal.
This video will show you
how to change a door seal on this Bosch front loader washing machine .
we have all bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 22, 2011 | Bosch Classixx WFC 2465 Front Load Washer
How do I clean the mould in the rubber door seal of a Bosch front loader.
This video will show you how to change a door seal on this Bosch front loader washing machine
Apr 01, 2011 | Bosch Washing Machines
HI, I have a Bosch 500 series front loader 3 years old in daily use . My question is, approximately how long do the water hoses last and when should they be replaced? Hoping to hear from you soon...
the water hose will last for years how ever they may need to be removed from the washer and clean out the screens on the fill valves the main supply hoses do not wear out as far as i know.
Feb 12, 2011 | Bosch Washing Machines
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Error Code EO6 - Bosch Front Loader WVT2850
Hi
I have have this same problem for 4 years now and engineers always told me it was becuase something may have been caught in the filter yet I clea my filter weekly and use the decaler they sold me on a monthly basis. Appartantly it is to do with the switch ??
Finally they have written my machine off yippee
Jun 25, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Bosch Axxis Front Load Washer
This video will show you how to change a door seal on this Bosch GLTF2940ES front loader washing machine
You can get seals on eBay
Aug 20, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
348 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
