Question about Friedrich SL24J30 Air Conditioner
Fan not working
Friedrich quietmaster model number : SL24J30 MY FAN DOESN'T WORK UNLESS I JUMP START IT BY SPINNING IT AND FLIPPING THE SWITCH TO THE ON POSITON. IT THEN WORKS FOR ONLY ABOUT 20 MINUTES AND I HAVE TO DO AGAIN AND AGAIN. IS IT POSSIBLY THE FAN MOTOR? IF SO, HOW CAN I REPAIR IT MYSELF?
Some fan motors have a start capasitor, some have a run capasitor and some have both. if you take out the capasitors (normally in the junction box) take note of which wires go where and head to a refrigeration spare parts wholesalers they should be able to give you the right ones then replace them. this shouldnt cost any more than $20 if that doesnt work you will need to replace the motor.
Posted on Aug 07, 2007
Fan will not work.
Hello, if the fan does not work it is most likely a bad capacitor or bad fan motor. Replace the capaitor first since it is inexpensive
May 25, 2011 | Friedrich QuietMaster Electric SS10J10AR...
SL24J30 KILLING CIRCUIT BREAKER
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Jun 24, 2010 | Friedrich SL24J30 Air Conditioner
Friedrich model ss12j10 --compressor does not go on. Any possible
the refrigerant leaks or the thermostat is not working. i also got the same same problem and have the thermostat replaced by a technician
Aug 21, 2009 | Friedrich SL24J30 Air Conditioner
Friedrich quietmaster fan does not come on and compressor sounds like it might be laboring when switch is turned to high,medium,low cool. The airconditioner does work if the money saver switch in on. Once...
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Jul 29, 2009 | Friedrich QuietMaster SL36L30 Air...
The switch on my Friedrich Quietmaster panel is
you can find them at any A/C supply house for window unites or on line. try Sears
Jul 14, 2009 | Friedrich QuietMaster SL36L30 Air...
Fan working but thermostat is not
You can judge if your thermostat is working by listening for a click when you rotate the knob.
Feb 17, 2009 | Friedrich QuietMaster Electronic SS12J30D...
Fan not working
Yes the bearings in the fan motor are bad you get at an a/c supply house for $ 150 to $200
Oct 06, 2008 | Friedrich SL24J30 Air Conditioner
A/c fan not working=thermostat is working(central a/c system)a/c
The fan on the outside unit is powered from it's 240 volt source. Check that the breaker for the outside unit is not tripped. Also, a contactor is inside the outer unit that starts the fan - it may be faulty.
Jul 26, 2008 | Friedrich QuietMaster Electronic SS12J30D...
Friedrich SL24J30 Air Conditioner Logo
195 people viewed this question
Top Friedrich Heating & Cooling Experts
Bill Long
acidjazzok
acidjazzok
Dennis Boxerman
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
