Garden Logo
A
Anonymous Posted on Apr 27, 2013
Change gas tank john deere LT 150 - John Deere Garden
5 Related Answers
Anonymous
  • Posted on Jun 02, 2009
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Anonymous
  • 138 Answers
  • Posted on Sep 06, 2009
SOURCE: need an owners manual for a john deere lawn LT-133
you can go to www.deere.com and then click on residential equipment on the next page click on services and support and then enter your model number you will need your machines serial number to choose which model you have. here you view on online or order a new copy on cd
Anonymous
  • 389 Answers
  • Posted on Sep 14, 2009
SOURCE: I need to replace the fuel line on my John Deere
Remove the seat and the fender/platform from the operator station this should expose everything you need to get at
nova2nv
Bill Linda Rivard
  • 197 Answers
  • Posted on Nov 14, 2009
SOURCE: I have a John Deere LT 1`33 lawn tractor with a 13
I believe they are 8mmX35mm.
Anonymous
  • Posted on Apr 07, 2010
SOURCE: how do I change the gas tank on my John Deere L110
Howdy, I have a jd L110 automatic with 179 hours on it...some times when starting with the brake held down it will not crank...some times it will... I am not sure if it is the switch on the brake or the starting system...Is there any way with out buying a new switch to wire jump the switch to see if it is in the switch or not? thanx, Dan
How do I chang the gas tank window on my 100 series john deere riding mower?
probably have to replace the whole tank. look the parts up on a john deere site and see if it's available separately
I need the metal fuel line thats inside the gas tank on a john deere lt 155
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
1helpful
My lt 133 john deere mower has gas in oil and back fires. runs 5 min and stops.
It's going to need a carb kit to fix the problem. Make sure your gas cap is venting ok, because gas expands in the summer and can force gas to pass thru carburetor and flood the cylinder then passing down into the oil. Depending on the age of your mower, the carburetor may have a gas shutoff solenoid on the bottom and this may have malfunctioned. Another is a bad float or needle valve which a carburetor kit would fix. A needle kit with bowl gasket may be all it will need. Hope this will help.
2helpful
I have a john deere LT 150 that will not start. When you turn the key nothing happens. I've checked the seat switch , the mower engage switch and a new brake/clutch switch. Battery is good. You ca
you have a safty switch problem you have 4 to 6 switchs the easest way to test them ,startin with the seat get a ohms metter they are open or noramly closed
1helpful
Change rear tire on john deere lawn tractor lt-150
i guess the wheels are stuck you will damage the wheels and axle trying to get them off just pop the beads and change it right on the mower
4answers
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Need diagram for belt replacemnt for \lt 150 \john Deere \lawn Tractor
Hi and welcome to FixYa, I am Kelly.
See this link and locate your deck:
http://opebycrigby.tripod.com/decks/jddeck.html
Thanks for choosing FixYa,
Kelly
Need to siphon gas from gas tank of a John Deere
Go to the store and buy a siphon you would use for a kerosene heater.
You can get the fuel out with this item. When you fill it back up add some "Seafoam" fuel additive. It will help keeps it running better.
Good Day.
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
