Question about Microwave Ovens
Emerson microwave Model MW9339SB
Some of the keypad wont work. Microwave works
MicrowaveSvc
  • 9047 Answers
SOURCE: keypad on microwave wont work
This may have already been dealt with, but others can benefit from an accurate, thoughtful reply to this problem.
Is it possible that some spray cleaner got into the controls?
I always recommend that users instead spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 26, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: How to replace keypad on LG Microwave
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
It's at http://www.microwavedisplay.com/keypad_replacement.pdf
Posted on Jun 23, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave Sharp carousel Model R3A36 keypad not working
Your keypad has failed.
It would need a new control panel frame, which comes with the keypad.
You simply remove the circuit board and plug it into the new frame.
It is part # FPNLCB070WRK0 and the best place to order Sharp parts is Tritronics.
Posted on Sep 06, 2008
SOURCE: Emerson microwave: Control buttons work microwave does not
sounds like the primary switch on the door latch is no good .had the same problem change it out and it works fine now.
Posted on Dec 27, 2008
WGCowen
  • 5 Answers
SOURCE: Emerson Microwave stopped working
Have 1 of 2 choices, the main fuse or the control board for the front switches and clock. primary of the small power transformer has opened. Unplug the unit and take case off and measure the fuse with an ohm meter. if u read 1 ohm or less then fuse is good. then measure across the main power plug tips. If read open then the power transformer is bad. Need to replace the board as not sure if transformer is available.
Posted on Jul 26, 2009
How do I correct a microwave that runs automatically with a display when connected to power outlet but does not heat up anything. The kitchen timer,clock and all other buttons works except express coo
Check and replace magnitron with one of the same number or equivalent.High tension transformer fuse may be blown or high voltage diode and or capacitor shorted. N.B. Please disconnect applance from mains and discharge large capacitor before carrying any DIY on any microwave,
Nov 07, 2014 | Emerson Microwave Ovens
How do i replace the light bulb in emerson microwave model number mw9339sb
Check if it has a cover screwed in side the unit , it should be behind that.
Nov 01, 2014 | Emerson Microwave Ovens
MW9339SB broken door latch
There are no user serviceable parts on microwave ovens, due to the danger of running one without the door in place. You will need to take it to a service centre. All of the screws are security screws that you need a special tool to remove.
Feb 20, 2014 | Emerson MW8987B/W Microwave Oven
Emerson microwave oven model mw9339sb has an arcing magnetron
The magnetron is supposed to make an arc to work but when it is getting out of hand it will sound wrong. At that point it is time to change the large capacitor and the magnetron. If there is an arcing inside the cabinet then you have to look for missing powder paint. Don't use any metal racks in a microwave or they will arc.
Dec 01, 2013 | Emerson Mw9339sb Microwave Ovens
Runs but not heating
if turntable does not turn it may be a issue with a safety switch--no heat can also mean inverter board (power) or Magnetron unit bad---both are pricy parts.
Nov 04, 2012 | Emerson Mw9339sb Microwave Ovens
Can't use the microwave at all
you have either a bad keypad or control board.
If you have operation of some buttons and not others its the keypad. if you have no operation out of the buttons at all you have a bad control board.
If you turn your microwave on and it sets and the timer counts down you have a bad interlock switch..
please let me know exactly what your microwave does when you set the cook time
Jan 08, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson microwave 900w
i believe majority of emerson got programmin ERROR intheir KEYPAD.. my emerson microwave got similar issue ..its a brand new one abt few monts old..it started actin weird way ..its keypad wont work..tried many thing unplug it pluge it back in everthing tht necessary..but still keypad is locked..no not the child procted locked..it locked with a digits 00.00 ...sometimes it work sometimes it dont...so no clue wat to do ...
Feb 17, 2008 | Emerson Black Microwave Oven
Microwave Ovens Logo
16 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
