Question about Weiser Lock ED1460X3VKD Powerbolt 1000 Electronic Deadbolt
The T-turn is reversed
When the t-turn is up it is locked, but it should unlocked
    New Friend:
I my mind the actual lock bolt was assembled wrong. You need to gently twist the length adjusting unit /bolt directly out of its housing and then gentle separate the two pieces though fully separating them and then "flip" the actual little toggling metal piece that has the "U shaped and half circle looking hub that the lock shaft slides into, around from it currently position ... ie. reversing its throw. You may need to also adjust the spring metal piece underneath it as it run in a slot as well.
This worked for me ... when t-turn key is horizontal the dead bolt is extended ie. in locked position.
Posted on May 04, 2014
Power locks wont lock doors with switch
All doors? Check the fuse...see owner's manual for info. Also verify that it is the vehicle's lock switches...or the keyless entry fob. If it is a single door, this can be a tricky difficult ordeal to find the "source" of the problem.
The difficulty is due to the fact that the negative/positive wires reverse polarity at door lock relays each time the lock is electrically exercised. The locks are activated by an electromagnet solenoid, which reverse when the supply current reverses polarity. For example, you may be able to lock a door with the switch then not be able to unlock it...or vice versa. If one of the wires has a fault, and the door locked [or unlocked], the relay was also "tripped/switched" with the "good" wire. When that happened, the relay effectively reversed the wire polarities...meaning that the faulty wire cannot energize the relay/solenoid to activate the lock-unlocking mechanism to reverse the process..
Simply, put...this is not likely a do-it-yourself fix, unless you have fair DC electrical skills, and a shop manual with complete wiring diagrams. The problem could be a poor wire connection, a broken wire, a faulty relay, a faulty solenoid, or a combination of these...or even a physical fault in the mechanical linkage for the lock.
If your vehicle has a locking lifting hatch back...and this is the "door" that won't operate, this can be very aggravating as there is no manual override, without removing the door/hatch trim and manually moving the linkage.
Hopefully it is the fuse.....good luck.
Mar 07, 2014 | 2002 Chevrolet Venture Passanger
Schlage BE365 - How do I remove the key? It will lock/unlock door but cannot be removed from lock.
Recommend resetting the lock back to factory settings and try reprogramming. Also if you don't hold the latch while turning the key to lock/unlock the door it may not be recognizing the keys inserted and this will keep the key in place. Try that before resetting to factory just make sure you hold latch and turn key until it wont turn anymore.
Dec 01, 2013 | Schlage Camelot Deadbolt Keypad, Satin...
2005 Chevrolet Tahoe Power Windows and Power Locks not working.
The power windows an power locks are controlled by a module , DDM - driver door module . As far as the locks locking when you put the vehicle into reverse an unlocking when you put the vehicle into park , that's how there are suppose to work , automatic lock an unlock feature . When you put the vehicle into any gear from park the locks should lock . Did she hit window lockout function ?
The power door lock system consists of the following components:
• The driver door module (DDM)
• The passenger door module (PDM)
• The body control module (BCM)
• The driver information center (DIC)
• The rear door lock switch
• The door lock relay
• The door unlock relay
• The liftgate lock relay--utility vehicles with liftgate only
• The reversible door lock actuators in each of the doors and liftgate
• LOCKS 20A fuse (rear lock/unlock relay supply voltage)
• ECC 10A fuse (liftgate lock relay supply voltage .
Programmable Automatic Door Locks
The automatic door lock feature can be programmed to control the door lock system. The automatic door lock feature is factory programmed to have all doors lock and unlock. For detailed instructions on programming the automatic door locks, refer to Vehicle Personalization in Personalization.
When the automatic door lock feature is programmed to control the door lock system, the driver door module (DDM), passenger door module (PDM) and body control module (BCM) will lock the vehicle doors if the following inputs are true:
• Ignition 1 input is active.
• All door jamb switch inputs are inactive.
• Cargo door or liftgate/liftglass ajar inputs are inactive.
• Transmission is shifted out of park.
This automatic door lock function will only occur once per ignition cycle unless, a door jamb switch input changes state to active and back to inactive. Then the DDM, PDM and BCM will lock all doors again.
Once the automatic door lock feature has locked the doors, the BCM will then unlock all the doors when the transmission is shifted into park.
Driver, Passenger and Cargo Door Lock System Operation
The front power door lock switches are integral components of the driver door module (DDM) and passenger door module (PDM). The switches are two position normally open rocker switches. When placed in either the lock or unlock positions, the switches provide a direct input to the DDM or PDM. The DDM or PDM monitors these inputs and sends a Class 2 message indicating a change in the switch's respective position. Modules which activate the power door lock motors receive the Class 2 message and activate the motor in the appropriate direction to lock or unlock the vehicle's doors and liftgate. The rear door lock switch provides a lock and unlock signal to the body control module (BCM). The BCM upon receipt of a lock or unlock signal will control the rear door lock relays and also send a Class 2 message to the DDM and PDM to perform the appropriate function.
The modules which activate the power lock motors are:
• The DDM (driver door lock actuator).
• The PDM (passenger front door lock actuator).
• The BCM (both rear door lock actuators and cargo door/liftgate).
The DDM and PDM are directly connected to the respective door lock actuator through the door lock motor lock and unlock circuits. Once a door lock or unlock request has been received, the module will supply battery voltage to one side of the actuator and ground the other causing the doors to lock or unlock.
The rear passenger and cargo doors differ slightly in that they use lock and unlock relays. The relays supply and coil sides receive a constant voltage through the battery voltage supply circuit. The normally closed contacts are connected to ground and the control side is connected to the BCM. Once a door lock or unlock request has been received by the BCM, the BCM will ground the control side of the appropriate relay. This energizes the relay and allows voltage to be applied to either the door lock motor lock or unlock circuits. since the other side of the door lock actuator is connected to the normally closed contacts of the opposing relay to ground, the doors lock or unlock.
Mar 16, 2017 | 2005 Chevrolet Tahoe
Door lock switches will unlock but not lock
I tried the DIY service and repair manuals from a website and it actually
helped me repair transmission problem in my ford explorer. it wont move forward or reverse, engine is good both solenoids for forward and reverse work.
I don't have much technical knowledge but I just followed it step-wise, and works perfect! got it from www.reliable-store.com
Feb 25, 2018 | 2000 Lexus LX470
The central locking system on my jeep Cherokee sports 1997 keeps blowing the 30A fuze but only during the lock cycle. It doesn't occur during unlock?
One leg of the 2 wires connecting to the various door servo's most likely has a short to ground.
Ensure neither leg is permanently grounded.
(The battery feed polarity to the servo motors is reversed by the controller so they run forward (/ reverse), to lock (/ to unlock))
Aug 03, 2009 | 1997 Jeep Cherokee
Shifter handle is lock in reverse. will not move to forward. or engage tines in eitherer directions.it stays reverse travel. shifted fine then went to move it then i couldn't move it. but in reverse
The gears are crossed up in the transmission.
You may get lucky if you try with the engine OFF,turning the trans pulley in the direction opposite of which the motor turns. This might unlock the internal gears.
Sorry for your problem. I know it is time to get the ground ready.
Jul 12, 2009 | Craftsman Rear Mount Tiller
Lock button is to unlock and unlock is to lock
The lock/unlock outputs from the main unit are reversed. There are two negative output wires from the unit that control the doorlocks, if you just switch them around, they will function correctly.
May 16, 2009 | Gmc Dodge Ford Reverse Back-up Sensor...
How do I lock up my Hoveround MPV5? The tech that delivered my chair shown me a way to lock up the joy stick & wheels, I don't remember how he did it and can't find my manual.
1. Turn the controller on.
2. To lock the chair, depress and hold the ON/OFF button. After one second the controller will beep. Release the ON/OFF button. Move the joystick forward until the control beeps. Move the joystick in reverse until the control beeps. Release the joystick. There will be a long beep that indicates the controller is locked.
3. To unlock, turn the control system on. The speed/response indicator will be rippling up and down. Move the joystick forward until the control beeps. Then move the joystick in reverse until the control beeps. Release the joystick. There will be a long beep that indicates the controller is unlocked.
This is from the manual, I hope it helps you.
May 06, 2009 | NRS Hoveround MPV 5 - Used Power...
My AOC LCD MONITOR on OSD LOCKED, How to unlocked it?
Press the left and right buttons on the monitor (simultaneously) while you turn the monitor on.
This should unlock it for you, this also works in reverse
Jan 28, 2009 | Computers & Internet
Rear side windows
This may be just a case of inadvertently hitting the window lock out n th driver door window switch by mistake. Check that first. Here's some background on window operation
Principles of Operation
The driver power window regulator motor is controlled directly by the master window/door lock/unlock switch (and its integrated "auto down" module). Power is supplied to the power window relay and the master window/door lock/unlock switch, and the passenger power window switch when the SEC/timer module grounds the coil side of the power window relay. The SEC/timer module will ground this relay when the ignition is in the ON position and will remain energized for approximately 15 minutes or until the driver or passenger door is opened.
The driver power window regulator motor is a reversible motor that is operated by applying power and ground to the motor leads to lower the window, and then reversing polarity on those leads to raise the window.
The passenger power window regulator motor is controlled directly by the passenger power window switch and can also be controlled by the master window/door lock/unlock switch. Power is supplied to the power window relay and the master window/door lock/unlock switch, and the passenger power window switch when the SEC/timer module grounds the coil side of the power window relay. The SEC/timer module will ground this relay when the ignition is in the ON position and will remain energized for approximately 15 minutes or until the driver or passenger door is opened.
The passenger power window regulator motor is a reversible motor, which is operated by applying power and ground to the motor leads to lower the window, and then reversing polarity on those leads to raise the window.
The power rear quarter glass is also directly controlled by the master window/door lock/unlock switch. The power rear quarter glass power latches also utilize reversible motors. The power rear quarter glass power latches are operated by applying power and ground to the motor leads to open the window, and then reversing polarity on those same leads to close the window.
Symptom Chart Condition Possible Sources Action
  • All windows are inoperative
  • BJB Fuse:
    • F20.
  • Circuit.
  • Power window relay.
  • Front door power window switch.
  • GO to Pinpoint Test A .
  • Single power window is inoperative
  • Front door power window regulator.
  • Circuit.
  • Driver door power window switch.
  • GO to Pinpoint Test B .
  • Vent power window is inoperative — quarter window glass power latch
  • Circuit.
  • Quarter window glass switch.
  • Quarter window glass power latch.
  • GO to Pinpoint Test C .
  • The one touch down feature is inoperative
  • Master window regulator and door lock switch.
  • INSTALL a new master window/door lock/unlock switch. REFER to Switch—Master Window Door Lock/Unlock .
  • The back window will not defrost
  • CJB Fuses:
    • F30 (10A).
    • F32 (20A).
    • F34 (20A).
  • BJB Fuse:
    • F27 (45A)
  • Circuit.
  • Heated back window switch.
  • SEC/timer module.
  • Rear window defrost relay.
  • GO to Pinpoint Test D .
  • The back window defrost will not shut off automatically
  • SEC/timer module.
  • Circuit.
  • GO to Pinpoint Test E .
Jan 28, 2009 | 1999 Mercury Villager
Weiser Lock ED1460X3VKD Powerbolt 1000 Electronic Deadbolt Logo
202 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
