Question about Motorola Mobility RAZR V3c Cellular Phone
Bluetooth i had to replace my razor and now my bluetooth wont work with my new razor how can i get it to connect to my new phone?
  • tina ronning Aug 07, 2007
    it worked...
    i had tried everything
    thank you sooo much
    have a good day
  • 58 Answers
You have to sync it with other device. Open the bluetooth settings on your phone and enabling (turn on) it. The universal code is 4 zero's (0000) to sync. Make sure the other device the bluetooth is turned on too. Good luck
Posted on Aug 06, 2007
SOURCE:
Can not connect bluetooth to MY65T Navman
I've got MY65T working on an iPhone 3GS. I previously had the problem where it would pair and retrieve phone book, but not transmit or receive voice from my iPhone when making a call.
The last thing I did that fixed it was to remove the bluetooth pairings and "reinstall software on your navman". I don't know if this may remove some of your settings / POI / etc. This was a new purchase so I didn't have anything to lose.
Before doing this I had upgraded the navdesk software to 7.30, and installed the latest firmware for MY65T. Firmware is located at http://www.navmansupport.com.au/Software/My%20Series/MY65T/MY250___352.htm
Details:
-remove the phone bluetooth pairing from the Navman from Settings / Bluetooth / My Paired Devices / [your phone] / delete
-remove the bluetooth pairing from your phone's settings
-connect navman to PC and launch navdesk
-click "My Navman" / "Reinstall software on your Navman"
-download the install file if prompted
-accept the reinstallation prompts and complete reinstallation
-set your phone to discoverable over bluetooth (just keep it on the Bluetooth settings screen on iPhone)
-go to Settings / Bluetooth /" Search new devices" on your Navman
-click your phone's name on the navman's discovered devices
-enter the PIN onto your phone when prompted and accept the pairing. This takes a little while.
-test handsfree!
Nov 29, 2010 | Apple iPhone 3G
I have a jabra ote3 bluetooth. i don't have the manual. can i connect the bluetooth to a verizon motorola razor?
Yes,You can connect the Jabra head set to motorola razor.
Please follow the steps to connect it to motorola razor
1. Turn headset off. Press and hold until solid light comes on.
2. Activate Bluetooth on your phone.
3. Search for Bluetooth devices and select Jabra BT2070.
4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 .
Thank You
Aug 11, 2010 | Cell Phones
I have a motorola razor v3 and I'm trying to connect my bluetooth (which is a motorola H680)
when you place the bluetooth in pairing mode and search for it from your phone it should automatically connect
if it asks for a passcode then press 0000
if this does not work try it with another phone or try to connect another bluetooth to this phone to see if there is an issue with the bluetooth on your phone
Nov 10, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Can't get existing bluetooth headset to work with new phone
I had that problem when I changed handsets. You need to:
  1. ensure the bluetooth setting is turned on on the handset
  2. switch on the scala 500
  3. press and hold the scala 500 power button until the red and blue lights are both flashing (you have to hold the button in for quite a few seconds)
  4. now you can search for new bluetooth devices from your handset and it should find it to enable you to connect
Jan 27, 2009 | Cardo scala-500 Wireless Headset
I can not pair my razor v3
Go to menu. Then to Connection. Click on Bluetooth link. Go to setup. Then click on find me. Then you should be able to sync your phone to his. For him to sync to you quicker, he can click on sync under connections in the menu. Then you should be able to send your pics, phonebook, the whole nine yards! The default pin to conect them is four zero's.
Jan 10, 2009 | Motorola Mobility HS810 Consumer Headset
Jabra BT 350 has stopped connecting
Hey everyone! I had the same problem, and I actually got it to work again! I hope these directions will help you get yours to work (from the manual):
1. Put the headset in pairing mode
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on. <== THIS IS VERY IMPORTANT! HOLD THE BUTTON UNTIL YOU SEE A SOLID NON-BLINKING LIGHT! (This is where I was going wrong with the directions.)
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros).
Nov 30, 2007 | Jabra BT350 Bluetooth Headset Headset
Infrared feat. on razors?
Hate to break it to you but razrs don't have infrared. Infrared has been replaced by bluetooth. I don't know how much you know about bluetooth but you might want to look into it.
Nov 15, 2007 | Motorola Mobility RAZR V3
Razr and bluetooth
IN SETTING GO TO BLUETOOTH AND ENABLE IT THEN TRY
GOOD DAY
KZ
Aug 21, 2007 | Motorola Mobility RAZR V3
H700 unable to pair up 'service not supported'
The term "service" refers to other types of services supported by bluetooth technology like keyboards, mice, etc. There's a lot more than just headsets now. I suggest checking the bluetooth options on your phone to see if there is a refresh service or other option....there is one like that on my blackberry that I once had to use to solve a similar issue. Have you tried disabling bluetooth, rebooting phone, enabling bluetooth, and rebooting phone before pairing? Also, look to see if there is an encryption on/off option on the phone...this could be causing an echo in either state due to interference...try switching encryption on/off. Also, check your update options on the phone, you didn't say which kind of phone it is but some can get firmware updates that may be needed for bluetooth to work well. Finally, you may get results by deleting the device on the phone and re-adding it thru discovery.
Jun 23, 2007 | Motorola Mobility H700 Wireless Headset
My H700 does not connect. When I attempt to connect it shows the disconnect option but it isn't connected
My bluetooth does not work at all. Have had it on charger for days. It does turn purple, but does not work when I put it in my ear. Have checked the connection. It just seems dead. Bought it last November, but first time I've had a problem. Can you help? Barbara
Jun 20, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility RAZR V3c Cellular Phone Logo
132 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
