Made Model Year lxr9245eq1
Washing machine what year made
  • 223 Answers
SOURCE: my washing machine will not spin or agitate
Does the washing machine empty as normal? I am assuming it does and think the brushes on the motor could be worn. Hope this helps.
Posted on Jan 20, 2009
smartr10U
  • 1305 Answers
SOURCE: What year was my washing machine made?
Looks like it was in the 16th week of 1996 so that would be around in April 1996... according to your serial number... btw it was actually made by Whirlpool for the Kenmore line at Sears..
Posted on Jun 05, 2009
jsrock516
  • 5911 Answers
SOURCE: HOW CAN YOU TELL YEAR OF WASHING MACHINE
The date of manufacture is determined by the SERIAL NUMBER on the appliance. If this is a Kenmore washer, it was probably manufactured by Whirlpool. The following link explains how to determine the age of an appliance manufactured by Whirlpool:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
The second digit in the serial number represents the YEAR it was manufactured. The first two numbers after that digit, represent the WEEK it was manufactured (52 weeks in a year).
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: For future reference, please post a MODEL NUMBER and/or SERIAL NUMBER when submitting questions to get quicker and more accurate responses.
Posted on Feb 21, 2010
  • 534 Answers
SOURCE: model Lxr9245EQ1 stopped in mid wash cycle.
transmission has gone out. You need to have this looked at before using due to motor burn out. The transmission connects to the motor and operates tthe spin cycle.
Dave
Posted on Mar 19, 2010
blueextc3221
  • 15935 Answers
SOURCE: washing machine control knob replacement
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
HOW TO REMOVE TIMER 3949208C WHIRLPOOL WASHING MACHINE MODEL LXR9245EQ1
http://www.appliancepartspros.com/whirlpool-timer-3949208-ap3019342.html
Mar 25, 2016 | Washing Machines
Agitator ratchet not catching on model lxr924eq1
USING A SOCKET WRENCH THE SCREW IN THE AGITATOR IS 7/16 REMOVE IT THEN U CAN LIFT UP THE TOP AGITATOR, UNDER IT U WILL FIND THE TRUST WASHER AND THE CAM DOGS THAT NEED REPLACING
Jul 25, 2014 | Whirlpool Washing Machines
Model Lxr9245EQ1 stopped in mid wash cycle. neither agitator nor drum turn freely,but motor hums
Dave
Mar 19, 2010 | Washing Machines
Feb 20, 2010 | Kenmore Washing Machines
The water level does not stop where it is set-also as soon as you turn washer on the water start flowing in-Model-LXR9245EQ1-what part do I need thanks bill
Wow the water level switch could be bad or the hose going to it might be clogged. You need to know how to access this stuff. MANUAL
Aug 31, 2009 | Washing Machines
Washer will not spin out it makes noise trying to .
sounds like the clutch coupling located behind the
motor
May 02, 2009 | Washing Machines
Leaking water washing machine -lxr9245eq1
sounds like a levelin problem check it in both directions and post back, also post model number TY
Apr 06, 2009 | Whirlpool LSR5132PQ Top Load Washer
Agitator halves are not in sync
yes it is replce them usually 4 and you'll be as good as new
Apr 03, 2009 | Whirlpool Washing Machines
Spin cycle not working, agitator does not move
If it there is no agitation or spin, check the motor coupling. The motor coupling connects the motor to the transmission. Replace it if it is broken.
The part number is 285753A
Let me know if you need instructions on how to replace it.
If it's not broken, you may have a problem with the transmission/gearcase (10 year warranty, get it replaced!)
Mar 21, 2009 | Whirlpool Washing Machines
Spring not hooked on to fram
is this the spring in the back if so look in the very back center bottom and you will see where the hole use to be but it probably rusted out just take like 1/4" drill bit and make another hole Please rate my solution
Jan 05, 2009 | Washing Machines
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
