Question about Pool & Spa
Arctic spa error code PSF
After my kids were in the hottub today It is now flashing PSF.
4 Suggested Answers
Ian  Hot Tub
  • 77 Answers
SOURCE: Calcium build up in my Arctic Spa Hot Tub
The worst calcium build-up I have seen on an Acrylic shell was actually caused by incorrect use of chemicals by the owner. The owner was dosing in very large quantities which was the cause of their issues. Little and often is the best way to go when adding any chemicals to a hot tub.
I don't rate Aqua Finesse at all. I have seen cirulation lines partially blocked due to similar products, I wont recommend it to any of my customers or use it myself.
If you were my customer, I'd be running through your chemical routine and the quantities that you add at any one time. It's possible that you are over-dosing and causing the problem to get worse.
Kind Regards,
Ian Kime.
http://hottub.synthasite.com
Posted on May 15, 2010
  • 990 Answers
SOURCE: on the sundance spa optima the watchdog error came
You probably just have an air lock at the pump. This will keep it from pumping water. You just need to open the drain valve for a few seconds to relieve the air. when it runs water you should be good to go.
Posted on Nov 28, 2010
SOURCE: 2001 arctic spa is showing error code FLO
FLO is for not enough water flow
This is a filter issue or pump issue. Remove filters and see if it goes away. If it does get some new filters here: http://www.hottubworks.com/
If it does not go away call us and we will walk you through trouble shooting. Most likely a circ pump if not filters.
Posted on Oct 26, 2012
How do I reset error code on imperial hottub..?
Flo code is not a resettable message. That means you have a problem. Is it flashing (interactive with temp) or is it solid (only the Flo Code) ?
Both of these are two different problems, and they have to be corrected before the message will clear.
Try cleaning the filter, or if it is older than 18 months, replace it.
Nov 21, 2013 | Imperial 7 Person Hot Tub Spa
PSF error code on my artic spa drifter
pressure switch failure check recirculation pump and filters and pressure switch
Apr 27, 2013 | Qca Spas Majestic Series Aruba Xl Hot Tub
Error code PIER on arctic spa. What does this mean??
There is no such code. PRR means a problem with the temp sensor.
PRH means a problem with the high limit
Nov 20, 2010 | Arctic Above Ground Rugged Mesh Winter...
Have hot tub with Spabuilders heating unit not functioning and getting two messages (1) FF 04 & (2) Fd 02
FF 04 and FD 02 might not be error codes.
In the UK, 'FD' stands for either 'Filtration Duration' or 'Filtration Delay'. As I'm not in the office right now I don't have a manual at hand.
Why isn't the hot tub functioning correctly??
Common Spa Builders (Gecko) error messages are, OHH, FLO, FLC, Sn1 and Sn2. Also they have three flashing dots which can appear on the display.
Kind Regards,
Ian Kime, from: http://hottub.synthasite.com
May 26, 2010 | Pool & Spa
Spa light and pump motor dont work system says sn3
sn3 is an error code relating to the temperature sensors.
Regards,
Ian.
Apr 09, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Reads OH but still cold
you either have a bad temperature sensor (check the wires for damage) or a bad circuit board. I would recommend replacing the temp sensor first. If that doesn't work, pull the board and take it and have it tested.
Mar 18, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
WHAT IS THE MODE BUTTON FOR?
EC stands for Economy. Change the mode until you reach ST and then it will stop flashing and function as normal.
Economy mode only allows the heater to function when the hot tub is on its filtration cycle.
Regards,
Ian.
Jan 04, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
Arctic Spa refill and a heater alarm ''HL''
HL is an error code. You will want to check out the link below to the mfg wesite. Balboa Water Group
Dec 28, 2008 | Arctic Above Ground Rugged Mesh Winter...
Pool & Spa Logo
211 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
